Old 04-02-2011, 11:29 PM   #1
rbsilvias14
rbsilvias14's Avatar
rbsilvias14 is an unknown quantity at this point
Sr20 won't crank
I got the swap in and when I go to start it up the starter just clicks. it is the starter clicking not the relay. The battery is old and could bef the issue, my clock and radio lights shut off or dim when I try to start the sr and the starter clicks continuesly. Is this a battery, ground or starter issue? Im going to try a
new battery tomorrow but wanted to see if anyome else had the same issue
Thanks in advance
rbsilvias14 is offline   Reply With Quote
Old 04-02-2011, 11:31 PM   #2
Sileighty_85
Sileighty_85's Avatar
sounds like battery and or bad grounds, check both
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-03-2011, 01:33 AM   #3
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
+1....i'ts most likely your battery for sure. But definately check all your grounds and harness grounds while your at it.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 04-03-2011, 01:35 AM   #4
cordobes
cordobes is an unknown quantity at this point
start replacing ur battery Dudeeeeeeeeeeeeeeeee
cordobes is offline   Reply With Quote
Old 04-03-2011, 09:19 AM   #5
240driftr
240driftr's Avatar
240driftr is an unknown quantity at this point
s13
Def sounds like ur battery
240driftr is offline   Reply With Quote
Old 04-03-2011, 06:27 PM   #6
rbsilvias14
okay so picked up a brand new battery today, put it in checked all grounds and cleaned them all up. still will not start... we push started it for the very first startup and the car fired right up. the starter just clicks continuesly and does not turn the engine over.. im guessing i need a new starter any other ides?
thank
Old 04-03-2011, 07:17 PM   #7
240driftr
240driftr's Avatar
SR
check your power wire to your starter an the other wires. if that doesnt work than pull the starter an have it tested. i had the same problem. wound up being wires
Old 04-03-2011, 08:57 PM   #8
rbsilvias14
okay i lied hah i tried running a ground from the starter motor to the chassis and it turned over? i guess i just needed another ground but i didnt think i would have to add one that isnt in the harness
Old 04-03-2011, 11:25 PM   #9
JuMPiiN
JuMPiiN is an unknown quantity at this point
See if your power wire to the starter is connected, mine falls off randomly.
(EDIT) saw you made a ground, just check ALL your grounds and maybe add a extra one or 2.
JuMPiiN is offline   Reply With Quote
Old 04-04-2011, 08:06 AM   #10
rbsilvias14
im going to add a few body grounds things should work now
thanks
crank, sr20, starter
