Idle suddenly going up and down. Vid included.
On my way home last night suddenly my idle began to fluctuate. I am not sure where to start looking to solve this problem. A link to the video is located below. There you can see the idle fluctuating. Any thoughts or ideas are appreciated
![]() Parts replaced withing the past 6k miles fuel pump, fuel filter, spark plugs and wires, almost all vacuum hoses. YouTube - IMG 0458 |
![]() Join Date: Apr 2010
really hard to tell from inside the car, you may want to get a vid from under the hood..
Normal reasons for the idle going up and down: - vacuum / boost leak - air pockets in the coolant - timing I'd start there, and pull the codes to see if maybe a random sensor took a dump. |
#5 | ||
![]() Join Date: Apr 2008
![]() Feedback Score: 10 reviews
unplug the coolant temp sensor while it is running and see if it makes any difference. if it idles better with the temp sensor out then you need a new one. do the same with the MAF. if this doesnt work then check the IAC. thats where i personally would start. good luck. text me if you need any help.
i had that shit on my rb20det atm
![]() clean your idle valve and replace all hoses if they're hard...i removed my coldstart valve cause it was leaking like an asshole do some pressuretests for your intercooler piping to make it 100%sure, that all helped at me alot |
Just some updates.
Replaced coolant temp sensor and problem persists. Ive always had a very slight air leak but could never find it. Replaced most hoses in attempt to find it. I got nothing. I unplugged the maf and iddle shot up, i unplugged the aicv and it didnt do anything. I then cleaned it and still, nothing. I am going to pick up a few aicv from the junk yard to see if that helps. |
