Old 04-11-2011, 12:49 PM   #1
Sideways_blksr20
Sideways_blksr20's Avatar
Trader Rating: (38)
Sideways_blksr20 is an unknown quantity at this point
Feedback Score: 38 reviews
Send a message via MSN to Sideways_blksr20
Bee R LIMITER
Selling my bee r limited
Almost brand new works great I just need cash lmk
7147213655
$240
This is an electronic rev limiter launch control system for Japanese cars (except Honda), it may work on other vehicles but you are responsible for doing the research. It works by altering the ignition restricting the rpm range in two steps. The first limiter is set to the max rpm that you want your engine to rev to. The second limiter is engaged when you press in the clutch or brake (your choice). This allows your to do two different things. When you are ready to launch you simple press the clutch and the throttle to the floor. The engine will rev to whatever you set the second control to and stay there. This is great for building boost on turbo cars. The second advantage is when installed you are able to shift gears without ever letting off the throttle. As soon as you press the clutch to shift the rpm limit is dropped back to the number two setting, keeping up boost and power while shifting. This system is know to lower quarter mile times as much as .3-.5 seconds. This is also the system know for shooting flames out the exhaust system. This occurs because unlike traditional rev limiters that cut the fuel supply, the bee r limiter cuts the ignition allowing air and fuel to flow out of the engine later igniting. The instructions that I have are in japanese but it shows what ecu pins are used. I can explain the wiring to the winner, however it is a very simple 5 wire system.
No English instructions, I can explain the 5 wire installation but you need a wiring schematic for your vehicle
Cuts ignition instead of fuel preventing the engine from going lean and most often causing flames to come out the exhaust pipes
Used for wrc rally racing, drifting, and drag racing among other motor sports
Allows for faster and more consistent launches off the line
Allows you to shift without letting off the throttle
Used as an anti-lag unit for your turbocharger, get the boost faster and keep it going on shifts and decel
Sideways_blksr20 is offline   Reply With Quote
Old 04-11-2011, 12:50 PM   #2
Sideways_blksr20
Trader Rating: (38)
I will also trade for a bucket seat
Old 04-15-2011, 01:41 AM   #3
Sideways_blksr20
Trader Rating: (38)
Bumpppppppp
Old 04-16-2011, 12:27 AM   #4
THeokaYsLider
THeokaYsLider's Avatar
THeokaYsLider is an unknown quantity at this point
When you decided to let it go for 170 I will get it lol for reals though
THeokaYsLider is offline   Reply With Quote
Old 04-17-2011, 12:09 PM   #5
Sideways_blksr20
Trader Rating: (38)
200 firmmmmmmmmmmmmmmmmmmmmm
Old 04-17-2011, 01:15 PM   #6
Propaganda
Propaganda's Avatar
Propaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enoughPropaganda will become famous soon enough
got sum picks?
Propaganda is offline   Reply With Quote
Old 04-17-2011, 02:06 PM   #7
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
You explained how it works perfectly.
Old 04-17-2011, 02:46 PM   #8
sr20time
sr20time is an unknown quantity at this point
i sold mine not on here but for 200. thats probably all you will get.
sr20time is offline   Reply With Quote
Old 04-17-2011, 04:38 PM   #9
SilviaAura
SilviaAura's Avatar
SilviaAura is an unknown quantity at this point
I want one of these so bad.....too bad im broke =[ lol
GLWS
Originally Posted by Weedm View Post
500hp is what you need to power an s-chassis into space.
SilviaAura is offline   Reply With Quote
Old 04-17-2011, 05:03 PM   #10
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
I seriously want this. Looking for anything else? And yeah you explained it very well.
smoked240 is offline   Reply With Quote
Old 04-17-2011, 11:18 PM   #11
Sideways_blksr20
Trader Rating: (38)
Most like it a bucket seat or aftemarket steering wheel plus quick release
Old 04-17-2011, 11:33 PM   #12
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
I have a nice momo seat I will trade you pm me
s13 @ fullboost is offline   Reply With Quote
Old 04-24-2011, 03:39 PM   #13
Sideways_blksr20
Trader Rating: (38)
Solddddddddddd !!!!!!!!!!
