Off Topic Chat All non related chat goes here. |
![]() Join Date: Feb 2003
rsr besti coils vs apexi exv? any experiences?
i find some reviews here and there about the exv, but more thorough experiences would be greatly appreciated. BUT i find little to none about the rsr coils. . . the few that i find say it's pretty good but which one would you get why???
#2 | |
![]() Join Date: Feb 2008
![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
I've actually never heard of coils by RSR. But then again, I've heard Apexi's are just rebranded Megan's so I dunno.
SPLparts.com * PoweredByMax.net Quote:
![]() Join Date: Nov 2005
yeap rebranded and "better valved" than megans.. the better valving part i highly doubt to be honest.
http://www.nissanroadracing.com/ |
#4 | |
![]() Join Date: Jun 2008
i doubt it, HIGHLY. i had a set of the apexi exv's and they were really really great coils. i've ridden in various cars with megans and their is a metric shit ton of difference between the two. |
#5 | |
Can you comment on the lowering capabilities of the EVX's versus Megans. Or the amount of backspace available from the EXV N1's? Jimmytango00 was able to get this low & fit 17x10+18 up front with EXV Pro's with no spacers under stock fender... Can I fit that same size with the EXV N1's? RIMTUCK.com - Setup ![]() |
I have really been considering the EVX N1's versus Megans for a long time now. Unfortunately, info on the Apexi's is kinda slim around the net. Got any pics of your car with the EVX's? And what was your wheel/tire setup?
I'm trying to find something that will let me fit 17x10+18(ish) without spacers. I know I can get Megan's with extended coilover mounting brackets, but I'd rather go with the more exclusive or uncommon Apexi's if they'll meet my needs... |
You could probably fit it with Silk Roads. The wheel-strut clearance is adjustable. The top spindle mounting hole has a square plate with an offset hole punched int it. You then have 4 different settings for your wheel-to-strut clearance.
#9 | |
Anyway, i have EXV N1s I think. The previous owner bought them but he told me they were EXVs and they say N1 on the adjusting knob. They are alright, but i haven't driven anything with the megans so i can't make a direct comparison. I have heard that the megans and the apexis use the same spring but have different tolerances for the valving (how reliable this statement is i don't know). I plan on switching to Swift springs on this coilover and when i do i can report back on how it affects the ride. Supposedly a better spring can make quite a difference. Also, i will be running 17x9 f and 17x10 rear RPF1s, so when i the 5 lug and brakes done i can test fit the 17x10s on the front and check clearance. I won't have this done for another 2 months though, i dunno what kind of time frame you need a definitive answer by... |
When I bought mine they were $1450, so not that far off from the Apexi's.
Your post, however, is simply a fountain of information. You think you might have one of the models discussed, but aren't sure, and some time in the future you plan on fitting something similar, but not for months, so you don't know.
#11 | |
Man w/ CTSV & a Car Seat
If the Apex'i ones has the same body/outter design as the MRs, I doubt you'd fit 17x10 +18 up front if its slammed. I had MRs and I had to slap 8mm spacers to clear the front strut, while slammed to the ground on 17x10 +12. The inner lip of the rim was basically touching the spring. If you raise the car up where the spring and collar are above the rim, then you might clear.
But at the same time, I'm running Topline Aragostas out here and I have no issue clearing 18x10 +18 up front. Design is alot skinnier than the MRs. My old Kouki with MRs and 17x10 +12 FNs with 8mm spacers up front with 235/40R17: ![]() Topline Aragostas with 18x10 +18 Equips, 225/40R18s: ![]() |
#13 | |
His setup on Rimtuck says he's using Apexi N1 Pro's. Apexi doesn't currently sell a coilover with that name, so I figure it must be a discontinued model. I just wanna know what are the differences between clearance & lowering capabilities of the N1 Type Pro's versus the EVX N1's. I guess I'll just have to find someone at Apexi to ask at some point... And as the the Megan's not clearing 18x10+18 without spacers, I thought thats what their 25mm extended brackets were for... |
#14 | |
#17 |
I've been in the import/export business long enough to know that there is no quality control when it comes to chinese products.
I am not implying that Apexi doesn't quality control their products, but the chinese steel used to make the items are inferior to japanese steel. |
