Old 04-24-2011, 11:11 AM   #1
DRIFTO16
DRIFTO16's Avatar
DRIFTO16 is an unknown quantity at this point
Rubbing noise from center support bearing!
so i replaced the clutch setup on my car a removed everything while doing so i noticed
the rings on my center support bearing where very lobsided and bent so
i assumed that might have caused the noise i would hear when releasing the gas at 3k rmp
so i was happy to replace the center support bearing with a new one
i threw everything back on
and the car started fine but when trying to reverse the car outta the shop
i heard rubbing but it had nothing to do with cluth it felt great i knew it would be the center support bearing
even when car is off
and in neatral and i push it feels realy hard to push
as if the driveshaft isnt moving easy enough
and at that same moment i hear that noise i lifted the car again and well idk the driveshaft doesnt seem to move easy with my hand like it should
any help would make my day =]
and nooooooo the e brake wasnt on lol
drifto magic!
DRIFTO16 is offline   Reply With Quote
Old 04-24-2011, 12:53 PM   #2
DRIFTO16
DRIFTO16's Avatar
Any help or suggestions??
drifto magic!
Old 04-24-2011, 01:04 PM   #3
sr23det
sr23det is an unknown quantity at this point
iirc the center support assembly has a offset
sr23det is offline   Reply With Quote
Old 04-24-2011, 01:07 PM   #4
DRIFTO16
DRIFTO16's Avatar
Ok so i think ur on to something but i dnt understand what iirc is
and whats the offse on it?
How can i change the offset thnx bud
drifto magic!
Old 04-24-2011, 01:24 PM   #5
sr23det
look at the 2 halves of the retainer that bolts to the car that should give you a idea of what i'm getting at. i'm not good explaining in writen words
