![]() Join Date: Mar 2010
FS: RED TOP SR20DET motor set. MOTOR, TURBO, TRANS and MUCH MORE! w/ PICS!
![]() UP FOR SALE!! SR20det REDtop! 6x,xxx mi+ on motor. motor was in a S13. THE COMPLETE SWAP IS FOR SALE!!!. What you will buy: -motor/radiator w/ shroud -trans/clutch/short shifter -turbo set up/IC/fuel set up/intake/z32 MAF -harness -EVERYTHING YOU NEED to drop this into your car. DETAILS/MODS Motor: -megan mounts HEAD -BC retainers/springs/272-272 cams(cams arent installed,BNIB) -cosworth head gasket BOTTOM END -stock TURBO set up -borg warner s360 -Compressor wheel - 60.02mm/83.46mm 69lbs/min Turbine wheel - 76mm/68mm Compressor inlet - 4" hose Ported Shroud Compressor outlet - 3" hose Turbine Inlet - Divided T4 .91 A/R Turbine Outlet - 3.5" v band -peakboost ram head exhaust manifold(t3) -38mm EWG w/ dump tube -Powered by Max high mount intercooler -greddy EBC -z32 MAF -z32 jim wolf tech pop charger intake COLD side/fuel set up -freddy intake manifold w/ custom throttle cable bracket. -venom 1000cc injectors -Powered by Max FPR w/ gauge -all new vacuum lines TRANS -SR trans -6 puck ACT sprung clutch -short shifter RADIATOR -SR20 mishimoto aluminum rad -clutch fan shroud. WHAT YOU WILL NEED. -install cams -down pipe -TUNE -testiculos .....should be done and beastial after that... PRICE -$3k If you meet my price. ill throw in some stock parts.. PICS: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() more pics to come. or you can request them. call/txt (619)850-662FOUR. ALL PARTS LOCATED IN SAN DIEGO Last edited by |BOOST|; 04-27-2011 at 12:23 PM.. |
460
