![]() Join Date: Aug 2006
Weight savings from carbon hood and FRP fenders?
Is there a significant weight savings with carbon hoods and fiberglass fenders?
I know there would be some weight savings but has anyone actually weighed them vs. stock parts for an S13 Silvia? I'm building a drag/street car and trying to make some choices on the front end right now. Thanks
Silvia, built 5.3 turbo, 4l80e, 9.8@142 |
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
well look at it like this. you're going to be adding weight with a roll cage bigger tires and stronger drive train so starting with fiberglass is a great idea. no to cf, it's mostly for show or strength and where you're putting those parts don't require any strength adding. do those and fiberglass doors, trunk and lexan windows will save you quite a bit. if you do it all you could save up to 100lbs or so. so yes they do add up but 1 or 2 won't be significant. good luck sir. plus you need to do a build thread if you do this. we dont see many drag build threads.
![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
headunit, speakers, and rear speaker brackets - 15.4lbs
driver and passenger door panels - 11.8lbs plastic backseat panels - 5.0lbs plastic B-pillar panels to back - 3.0lbs back seats - 20.8lbs hatch wall carpeting, plastic rear speaker panels, and rear floor mats - 20.6lbs rear wiper, motor, grommet, and blade - 3.0lbs jack tools, jack cover cardboard, random gray foam pads - 6.4lbs rear strut covers, miscellaneous brackets & stuff - 2.8lbs shift boot & panel - 0.6lbs hatch area carpeting - 3.2lbs A/C compressor, condenser, reservoir, & some piping - 29.2lbs windshield wiper reservoir (full of fluid), bracket, & associated tubing - 9.0lbs PAIR valve, actuator, bracket, and fasteners - 3.0lbs sound deadening (Round 1) *box was 1 pound* - 10.8lbs main carpet (from floorboard to rear seats) - 11.8lbs glovebox - 3.2lbs gauge cluster bezel - 1.6lbs automatic seatbelts & lapbelt assemblies - 20.0lbs power antenna - 2.0lbs headliner, reading lamps, and shades - 4.0lbs miscellaneous plastic pieces - 3.6lbs plastic passenger floorboard panel (under glovebox) - 1.6lbs center console - 3.0lbs ABS unit mounting bracket - 3.2lbs ABS unit - 15.8lbs PS resevoir - 2.0lbs PS line - 1.4lbs fuel catch can & bracket - 1.8lbs HICAS solenoid - 6.4lbs rear HICAS rack - 10.8lbs rear HICAS distribution block - 5.2lbs clutch loop - 1.41bs battery tray - 1.2lbs SE exhaust & cat - 41.0lbs sound deadening - 29lbs spare tire & wheel - 28.0lbs firewall mat - 18.8lbs sunroof glass - 11.5lbs foam layer on dashboard - 5lbs Total of pounds lost - 377.9 |
Trader Rating: (34)
CF Hoods you will probably save around 20lb, Fenders maybe 5-10lb with FRP.
Theres also other stuff you can change out to lighten your car like Rims, Flywheels, Driveshaft, Windows.. Also you can shave some metal out of certain parts of the chassis to loose that extra weight but i would recommend reinforcing the body with some stitch welds. |
![]() Join Date: Mar 2011
this isnt a hood but when I did my carbon hatch I saved 14lbs if I remember correctly. It got rid of the wiper but added the 3rd brake in the hatch.
I agree with the washer reservior weight thats the same that I got. Thats actually a nice list.
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
AFC #1
![]() Join Date: Oct 2003
CF is lighter. But, most Wet layup carbon out there is only 1 layer of CF and the rest is fiberglass. So they are just Fiberglass with a GF cover.
![]() Join Date: Aug 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
id say get a cf hood... idk how much s13 hoods weigh, but s14 hoods are heavy as fuck.
and if ur baller enough, get a dry carbon hood. that will be lighter than shit.
2016 Nissan 370z |
