![]() Join Date: Feb 2010
![]() ![]() Feedback Score: 20 reviews
http://zilvia.net/f/chat/297481-smal...w-threads.html
http://zilvia.net/f/chat/174916-identify-thread.html
@MMyriad |
![]() Join Date: May 2009
if it is a Z32, it's a 1" or 1 1/16" master cylinder. it depends on the build date and such.
46010-30P01 Manufacture date 2/89 – 7/90 (17/16" NA Tokico) 46010-30P02 Manufacture date 7/89 – 7/90 (17/16" TT Tokico) 46010-30P02 Manufacture date 7/90 – 2/91 (17/16" NA & TT Tokico) 46010-30P10 Manufacture date 2/89 – 7/90 (15/16" NA Nabco non-ABS) 46010-30P21 Manufacture date 2/89 – 7/90 (17/16" NA Nabco) 46010-30P22 Manufacture date 7/89 – 7/90 (17/16" TT Nabco) 46010-30P22 Manufacture date 7/90 – 2/91 (17/16" NA & TT Nabco) 46010-45P00 Manufacture date 9/91 – 9/93 (1" NA TT Tokico) 46010-45P00 Manufacture date 2/91 – 9/91 (1" NA & TT Tokico) 46010-45P20 Manufacture date 9/91 – 9/93 (1" NA & TT Nabco) 46010-45P20 Manufacture date 9/93 – Up (1" NA & TT Nabco) Last edited by datsunnazi; 05-25-2011 at 03:14 PM.. Reason: updated info |
![]() Join Date: Feb 2007
Trader Rating: (83)
![]() Feedback Score: 83 reviews
Here you go, I hope this helps.
Master Cylinders: 46010-30P01 Manufacture date 2/89 – 7/90 (17/16" NA Tokico) 46010-30P02 Manufacture date 7/89 – 7/90 (17/16" TT Tokico) 46010-30P02 Manufacture date 7/90 – 2/91 (17/16" NA & TT Tokico) 46010-30P10 Manufacture date 2/89 – 7/90 (15/16" NA Nabco non-ABS) 46010-30P21 Manufacture date 2/89 – 7/90 (17/16" NA Nabco) 46010-30P22 Manufacture date 7/89 – 7/90 (17/16" TT Nabco) 46010-30P22 Manufacture date 7/90 – 2/91 (17/16" NA & TT Nabco) 46010-45P00 Manufacture date 9/91 – 9/93 (1" NA TT Tokico) 46010-45P00 Manufacture date 2/91 – 9/91 (1" NA & TT Tokico) 46010-45P20 Manufacture date 9/91 – 9/93 (1" NA & TT Nabco) 46010-45P20 Manufacture date 9/93 – Up (1" NA & TT Nabco) I can barely read that number on the side so check this if its on the list. If not, mostly likely its not a z32 bmc |
damn yeah i don't see those part numbers anywhere on this BMC, only part number on it is 30173-AC, but can't you tell if its a z32 brake master cylinder by looking at the fittings?
Trader Rating: (83)
found it i guess here's your answer:
Quoted from a different site: I'm having a similar problem. I have a AC delco reman. 1-1/16 300ZX MC. I took the flair fitting out of my old 240 nabco MC. The fitting doesn't press into my new MC, if I turn it upside down it falls right out. Not sure if the the MC is a tokico or nabco, all it has on it is these two numbers 30173-AC 1028989A Am I supposed to get the flair fitting from a 240 with a tokic MC? |
is there a difference between OEM and w/e i have? i just don't want a shitty pedal feel, i already drained enough money on pads/rebuild on my brakes, lol think the pedal will feel nice and firm with this BMC?
thanks a bunch for your input blktop. |
Trader Rating: (83)
From what i found out pedal feel is the same as the oem counterpart of it. Issue is what nipple fitting can go in the center. I guess if you have one pressed in, watch for leaks. Since this bmc was not design to have a 3rd fitting. Goodluck
