Old 05-26-2011, 10:16 PM   #1
Exiled 240
Exiled 240 can only hope to improve
s13 Running Rough
Alright so i bought my 89 240sx a few months ago and it has always been running rough. it doesnt start all of the time and it idles rough (normally around 1250rpm-2000rpm). when you rev the engine it sputters and sounds like it is about to stall. now i was just gunna forget about fixing this motor and just rebuild the ka24de i have in my garage but the parts will be awhile till they r available.
Does anyone have an idea on what would cause this issue?
Not sure if this matters at all but whenever i disconnect the MAF it idles normal but stalls when ever i try going anywhere.
Thanks for the help
Exiled 240 is offline   Reply With Quote
Old 05-26-2011, 10:17 PM   #2
BestOneLeft
BestOneLeft is an unknown quantity at this point
Id try the maf first, At least clean it with some brake cleaner/starter fluid
BestOneLeft is offline   Reply With Quote
Old 05-26-2011, 10:19 PM   #3
Exiled 240
Srry should have stated that i did clean it with MAF sensor cleaner. im hoping the whole sensor isnt bad
Old 05-27-2011, 12:38 AM   #4
NIZzS13
NIZzS13 is an unknown quantity at this point
You had the answer from the begining when u said it idles normal with the maf disconnected. MAF is no good, its idles ok because the computer is pre programmed to know how much air is coming in at idle and the amount of fuel to use, but once u open the throttle it no longer knows how much gas to add so it quickly dumps fuel cause the car to stall. Also check for intake leaks after the MAF sensor. But if you have no leaks then the sensor is garbage. Cleaning them only works 50% of the time.
NIZzS13 is offline   Reply With Quote
Old 05-27-2011, 05:19 AM   #5
Exiled 240
Alright kool. Then I guess it is time for a new MAF and hopefully I can get the car running for awhile till the rebuild parts are available.
