Old 06-06-2011, 03:02 AM   #1
ZRiotFloorin'
ZRiotFloorin' is an unknown quantity at this point
effective ways to bleed hydro ebrake?
This is the way i do:
"I do bleed the handbrake itself after I bleed the brakes as normal, I bleed a fair bit of fluid through the system in the normal way and then I bleed the handbrake itself just as you would the normal brakes. Pull three times and hold the lever and crack the nipple, close it before releasing the lever"
I followed this procedure a couple of times but i feel like there's still air in the system. Rear won't lock up.
i start with right rear. keep bleeding using the ebrake until i FEEL like i'm done. THen i go to the left side. Is this way OK? or should i be bleeding right side once, left once, right, left and so on?
Also, do you recommend pumping the brake/ebrake three times before opening the bleeder valve?
CNC states 'Pumping will only aerate the fluid and prevent complete bleeding."
thanks in advance.
FS: (4) NEW 17x8.5 +40 Gram Lights 57s GOLD 5x114.3
ZRiotFloorin' is offline   Reply With Quote
