Old 02-27-2004, 11:32 AM   #1
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
What happens when different oils are used?
The other night I was doing an oil change on my friends 240SX and my friend made a mistake and got 3 quarts of 10W-30 and 1 quarts of 10W-40 and I found this out after I've put in the oil. Should my friend drain and fill it up with 4 quarts of the same oil or it's not a big deal?
By the way, What does the numbers stand for?
HKrpS13 is offline   Reply With Quote
Old 02-27-2004, 04:44 PM   #2
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
Its fine
thier both the same weight
10w(weight) 30/ 40 has to do with temperature differences from what I remeber.
you'll be fine untill your next oil change.
autobahNESSA is offline   Reply With Quote
Old 02-27-2004, 05:14 PM   #3
HiPSI
HiPSI is an unknown quantity at this point
Send a message via AIM to HiPSI Send a message via Yahoo to HiPSI
no problem with mixing, your engine will mix it all together nicely, lol
SR motor set/clip $2500+, FMIC kit $700+, Downpipe $100+, 3" exhaust $500+, Misc install parts $100+, Shop labor for install $1000+ and you still only make 220rwhp for $5000
so what's so CHEAP about the SR swap again?
HiPSI is offline   Reply With Quote
Old 02-27-2004, 06:30 PM   #4
HKrpS13
thanks for your help. saved me from getting dirty.
what if the numbers on the _W was different?
Old 02-27-2004, 07:17 PM   #5
pr240sx
pr240sx is an unknown quantity at this point
You can safely mix all kinds of weights, no engine seizure or malfunction will occur
But dont make this mistake too often,
Now, mixing different brands with different weight could cause a problem. Some oil companies add additives and detergents that could break down harmfully in your engine.
But in case of emergency, different oil is better than no oil at all!!
pr240sx is offline   Reply With Quote
Old 02-27-2004, 07:24 PM   #6
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
it's 10W-37.5
Custom blend. I like it.
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
