Old 02-29-2004, 06:30 PM   #1
XXX4life
XXX4life is an unknown quantity at this point
Send a message via AIM to XXX4life
j30 vlsd with abs into my 90 240 fastback
ok i already searched and i couldn't find an answer to this, will a 95 j30 vlsd with aba sensor work on my 90 240 fastback with no abs? or do i need a non abs vlsd?
thanks
04 Scion xb
90 240sx (ka24de)
www.entrustclothing.com
XXX4life is offline   Reply With Quote
Old 02-29-2004, 06:37 PM   #2
NISMO_drift
NISMO_drift's Avatar
NISMO_drift is an unknown quantity at this point
Send a message via AIM to NISMO_drift
the lsd part is mechanical and has nothing to do w/ a sensor. As long as leavin the sensor unplugged doesn't cause anyleaks, i'm guess it'll work just fine.
I'm assumin you've researched it and know whether or not the j30 diff will bolt onto the 240?
92 White Pearl Sileighty
~S15 Front
~180SX Kouki tail lights
~S13 Blacktop SR20DET
NISMO_drift is offline   Reply With Quote
Old 02-29-2004, 09:06 PM   #3
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
thanks
It will bolt up and it will work. You'll need to swap your S13 open diff cover onto it and you'll need to install the 4 driveshaft to VLSD bolts backwards (bolt head facing the front instead of the rear). You'll also need longer bolts for the diff bushing mounts.....14mm x 1.5 pitch x 80mm long I believe.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 02-29-2004, 11:09 PM   #4
XXX4life
-m
what about the actual diff being longer? does that effect the driveshaft or anything?
04 Scion xb
90 240sx (ka24de)
Old 03-01-2004, 03:44 PM   #5
jrou111
jrou111's Avatar
jrou111 is an unknown quantity at this point
Are you sure you searched? cause I posted on this last week.
anyways,
I have a 91 and put in a 95 j30 vlsd
1. take out old diff
2. swap covers(make sure to get a new gasket
3. put new diff back in, use the two longer bolts for the front mounts (previously mentioned)
4. bolt up axles, then push driveshaft foreward, it'll go in with effort
5. check and re-check everything
that's it
you'll need 12, 14, and 17 mm wrenches(highly recommend ratcheting) and sockets, and someone to hang around and pull/release the e-brake
I did it by myself in about 2 hrs in the pouring rain, and most of that time was looking for those two longer bolts, and getting out from under the car to pull/release the e-brake.
It's a breezeif you have some mechanical ability,
James
91 240sx FB
-I/E, Tein HE's, J30 vlsd, leather, working hatch struts
-NEW 1/8 TIME - 9.4@67
95 Eagle Talon TSi
-I/E, 15psi, 14b, HKS SSQV
jrou111 is offline   Reply With Quote
Old 03-01-2004, 04:07 PM   #6
XXX4life
anyways,
that's it
but will that hurt anything using the longer driveshaft??
04 Scion xb
90 240sx (ka24de)
Old 03-01-2004, 04:22 PM   #7
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
to answer your question
some had problems so yes, but others never had problems so no, depends on who you ask, technically it would be better if you got the correct driveshaft (abs) shorter by half inch,
i've had no problems (vlsd with abs sensor and nonabs driveshaft).
Wei240 is offline   Reply With Quote
Old 03-01-2004, 04:40 PM   #8
XXX4life
what about putting a stock vlsd into my open diff pumpkin? will that work?
04 Scion xb
90 240sx (ka24de)
Old 03-01-2004, 08:03 PM   #9
jrou111
jrou111's Avatar
It's possible, but its a bunch of work to do, because you have to shim/align gears to have them meshed properly.
The driveshaft is ~ .5" longer, there is usually enough play for it to be just fine.
btw, my driveshaft lined up just right, with no pushing or anything.
With a friend it's possible to do the swap in 1-3 hours, where as you're looking at alot longer to swap internals.
Peace,
James
91 240sx FB
95 Eagle Talon TSi
