Old 06-29-2011, 09:28 PM   #1
891via
891via's Avatar
891via is an unknown quantity at this point
KA24E engine ticking.. HELP
I started getting a ticking noise coming from the engine. I'm not entirely sure if it's a valve, or lifter or rocker just yet.
any help would be appreciated.
and thanks in advance !
VIDEO: YouTube - ‪1989 240sx KA24E ticking.‬‏
891via is offline   Reply With Quote
Old 06-29-2011, 09:30 PM   #2
jesse_s13
jesse_s13's Avatar
Sounds bad man=(
jesse_s13 is offline   Reply With Quote
Old 06-30-2011, 10:40 PM   #3
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Check your oil level, how old is the oil in the car?
Mishkin_707 is offline   Reply With Quote
Old 06-30-2011, 11:10 PM   #4
FRpilot
FRpilot's Avatar
dammit my ka24de sounds just like this right now... to the point where i took tomorrow off so that I can have 4 days to do an emergency engine swap.
would like input too. otherwise, i'm going to take off belts off certain accessories and test to hope it is just a bearing before i pull the motor out.
FRpilot is offline   Reply With Quote
Old 06-30-2011, 11:14 PM   #5
corry29
corry29's Avatar
corry29 is an unknown quantity at this point
Send a message via AIM to corry29
Might be wrong, but is that the infamous timing guide thing?
corry29 is offline   Reply With Quote
Old 06-30-2011, 11:22 PM   #6
891via
891via's Avatar
checked my oil, its about half way. im gunna put oil in it tomorrow asap and see if it stops ticking and will input you guys on the outcome.
Old 07-01-2011, 12:43 PM   #7
891via
891via's Avatar
I put in 1 quart of full synthetic oil and the ticking has stopped ! Thanks alot I gotta fix my oil pan leak, lol. O had a feeling it had to do with my oil pan.
Old 07-01-2011, 01:29 PM   #8
iveexcaped3
iveexcaped3's Avatar
iveexcaped3 is an unknown quantity at this point
dont rule it out. i got my ka24e torn apart right now that i thought had that same tick. did my oil change and it went away. then it came back really bad when i ran the car hard. replaced the timing chain the tick went away but heard a valve knock. pulled my head come to find out the guy before me did oversized valves but didnt do the work to the head. so it might be different in your case but mine was the timing chain. good luck if it comes back start to think about the timing chain
iveexcaped3 is offline   Reply With Quote
Old 07-01-2011, 01:35 PM   #9
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
that def doesnt sound like the timing tick. That sounds like something metal on metal. I had the KA tick sounded like a aggressive cam that tick sounds like a knock or something since it ticks, pauses, then ticks again.
SLiDe_WaYz is offline   Reply With Quote
Old 07-01-2011, 01:48 PM   #10
el_panduh
el_panduh's Avatar
el_panduh is an unknown quantity at this point
dude!!!!!! thats what my sohc does its so dumb. that noise comes and goes in my engine even when i have oil in car still does it and i dont lose power at all which is the weird part. so you find a solution to fix the problem??
el_panduh is offline   Reply With Quote
Old 07-12-2011, 04:53 PM   #11
VG30Drift
VG30Drift's Avatar
VG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymore
It's most likely just the lifters needing to be bled. 260K on my sohc and i run it hard every day with that issue. Bleed them, or don't; probably wont cause any issues.
'94 NA Z----------------'90 S13 Base Coupe
VG30Drift is offline   Reply With Quote
Old 07-13-2011, 03:21 AM   #12
iveexcaped3
sohc dont have lifters just rockers
Old 07-13-2011, 09:17 AM   #13
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
I may use this as my sig for awhile.
For the OP..
This link migh help.. http://www.nicoclub.com/archives/ka2...rs-repair.html
GroundPerformance is offline   Reply With Quote
Old 07-13-2011, 11:37 AM   #14
iveexcaped3
So that little pin in the rocker arm is considered the "lifter"
Old 07-13-2011, 04:19 PM   #15
GroundPerformance
Trader Rating: (44)
There you go...
Old 07-13-2011, 04:51 PM   #16
iveexcaped3
then i stand corrected sir...
Old 07-14-2011, 01:23 PM   #17
VG30Drift
VG30Drift's Avatar
Originally Posted by GroundPerformance View Post
For the OP..
This link migh help.. KA24E Ticking Lifters Repair
This is it!
s13 240sx ka24de ka24e
