Things that have been done, DIY saves lots of money...
Purchase lighter rims (O.Z. SUPERLEGGARA for example) Dropped the spare tire Removed Airbag system Custom fiberglass hood Custom Lexan glass on the doors Removed rear wing Custom aluminum seat brackets with aftermarket seats (Sparco Torinos) Cutout the entire trunk area and weld in aluminum sheet metal .25" thick Removed factory stereo system including amps and replaced with some 7oz. max weights all around with a cheap deck that has high power Custom aluminum drive shaft Fiberglass fenders Aluminum radiator (single core 1 in.) 300ZX 30mm. calipers (alum.) Remove the A/C System Light weight motor mounts to list a few. Think about it...If you are inexperienced, it may not be worth it. That would be a matter of opinion and available funds however... |
![]() Join Date: Sep 2001
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
the 30mm Z32 calipers ARE lighter but the rotor is heavier than stock so it washes out the weight savings there. And Sparco Torinos are heavy as shit.
![]() ----Gone---- |
#5 | |
![]() Join Date: Feb 2004
im pretty sure most of the corbeaus are lighter than the sparco seats. I don't have an exact number but some people say that corbeaus don't have as good of support
![]() Join Date: Jan 2003
heres a good way to loos wieght, this is my interior, also you can take off the sound deadening material and save a lot of wieght. You can also take all the washer fluid out of you resivior tank, you may say "that is stupid its prob only 5lbs blah blah" but all those "just 5lbs" will start to add up!!
FRontline (marinating since 02) ![]() |
#9 | |
I hate you too...
![]() Join Date: Jul 2001
![]() -Jeff
Whatup? |
Remove all the glass on your car, windshield and etcs and replace w/ Lexan.
Carbon fiber hood and trunk lid. Cut out the spare tire well and weld a sheet of aluminum over it. Light weight racing wheels. Remove the heater. Remove the windshield wiper motors. Remove the A/C, cruise control and audio system. Remove the headliner, carpet and sound deadening. Remove front and rear bumper support. Carbon composite driveshaft. Utilize a smaller gas tank. Weight makes a big difference..
Trust and I don't mean GReddy. |
![]() Join Date: Feb 2002
Check the laws befor you go doing lexan, air bags, bumper support...
Some of these are just not good ideas for road use. Dont forget full TI exaust... mines only 11lb 4 oz vrs stock 25 lb 11 oz
http://www.cardomain.com/memberpage/509537 http://www.imagestation.com/album/?id=4287415487 http://www.zilvia.net/f/showthread.php?t=21036 |
![]() Join Date: Dec 2002
Ditch the sunroof!
If you're auto, swap to 5 speed. Corbeau seats ARE light (Forza is 16 lbs). C/f Hood makes a noticable difference. RELOCATE THAT BATTERY! And while your at it, get a 51R or smaller. No interior is the best. Ditch the carpet and headliner, passenger sun visor, rear seatbelts (heavy!), floor mats, EVERYTHING. Electric fans. Find all the wires your not using and cut them out (can save 10 lbs). Weight savings makes all the difference when you drive the mountain. Be sure not to ditch any safety equiptment you still use however, this includes airbags, front seatbelts, door reinforcement bars, bumper supports, dash supports, etc. Although these things are HEAVY, its not worth losing somebodies life over. For the hardcore only. Get a smaller cell phone. Shave, and get a haircut Hit the gym. Drive naked.
#14 | |
Ahh very true... Reduce weight and the Rotating mass... S14 flywheel is 21 lbs ?? oz Fadinza is 11 lbs ?? oz thats another 10 lbs ....... And dont forget to take a piss befor you drive...
#15 | |
![]() Go to the bathroom before you hit the track. ![]() No, seriously... You can tear the doors apart. Replace the electric window units with a strap-pull-up version. Remove the passenger seat completely. Don't forget the glovebox = another 5lbs. I mean, you can strip the car down to 4 wheels, a steeringwheel, and a seat if you want to. |
#16 | |
![]() BTW, you were wrong... |
#17 |
I hate you too...
[worthless post]
http://forums.vwvortex.com/zerothread?id=776885 [/worthless post] While we're on the subject of weight reduction. -Jeff
Whatup? |
#18 |
"remove sheet metal and weld aluminum plate"
good idea... just make sure you dont light your car on fire, or cut into your tank ![]() heres my input on weight.... my car weighs about 2400lbs with driver so it gives you an idea of what goin too far looks like.
Kick Ass 2.4Liter Engine! |
#19 | |
How'd you do it? o.O
#21 | |
![]() Join Date: Sep 2003
where did you get the pillar bar? does it have preload(hard to get in place?) does it make a difference? i have almost the same setup as you and i wanna add the pillar bar.
Hi |
#22 | |
#23 | |
i used a 3/4" piece of stainless and welded mounts on either side... no preload.. just kinda sits there and holds tight... you can see it better in this pic:
#24 |
here are some pics of when i gutted my car if it helps anyone..
i spent about 4 hours removing all the sound deadening... i stuck in all in plastic bags and filled a cardboard box... the box weighed 35lbs!
