Old 03-04-2004, 07:08 PM   #1
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
remote oil filter, which adapter? thread pitch?
so i m looking to runa oil cooler and remote filter but i dont know what adapter to use, i got a remote filter set up from a blazer so i can use larger filters, i just need to know what part to attach to the engine?? summit has alot but they all look like they are gm/ford/dodge specific
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 03-04-2004, 07:55 PM   #2
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
It depends on which motor you're talking about, IIRC the KA has the same thread pitch as the S13 SR. I got the info below from SRFiveTen from FA.
*S14 SR uses filters with 20-1.5mm thread.
S13 SR uses filters with 3/4"-16 thread.
B14 SR Sentra filter has 20-1.5mm thread.
B13 SR Sentra filter has 3/4"-16 thread.
*info from SRFiveTen
WilloW is offline   Reply With Quote
Old 03-04-2004, 07:57 PM   #3
ryan hagen
ryan hagen's Avatar
ka24de s13 models
Old 03-04-2004, 09:51 PM   #4
TheTimanator
TheTimanator's Avatar
I hope your correct on this. Summit's kits start at $35 which is a ton cheaper than the $150 for the Greddy kit. (which I've heard has really short hoses) I'm tired of busting my knuckles when I change my oil!!!!
Now only if they had kits with braided lines. My engine bay needs somethin' nice looking....
Old 03-04-2004, 09:54 PM   #5
ryan hagen
ryan hagen's Avatar
yah, i wanna get the adapter, run a oil cooler and then get a remote filter set up from a older blazer from the junk yard, i think it might use the same size filter as a 350?
Old 03-04-2004, 09:55 PM   #6
Thunderchicken
Thunderchicken is an unknown quantity at this point
You could check by taking a filter to a hardware store and see which bolt fits in if you aren't sure.
Thunderchicken is offline   Reply With Quote
Old 03-04-2004, 10:12 PM   #7
WilloW
WilloW's Avatar
Make your own kit, I'm going with Earl's components. I wouldn't pay more than $80 for the Greddy kit with the fake anodized hose-ends, I wouldn't even touch it. In some cases that I've heard about, the Greddy kit has some leaking problem.
Old 03-04-2004, 10:16 PM   #8
ryan hagen
ryan hagen's Avatar
i asm cause i got a cooler for free at a junk yard, and a remote filter thing next time i go form a blazer, so all i need to buy is lines and the peice to go where my stock filter goes to branch off into lines.....
Old 03-04-2004, 10:21 PM   #9
WilloW
WilloW's Avatar
You might as well go with the sandwich adaptor too, check out Holley's Earl's. Good luck.
Old 03-04-2004, 11:11 PM   #10
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
3/4 -16 is the thread pitch for ka, it is same as ford v8 btw. Be sure when you get an adapter that it has a female end to mount to original threads. Some have male threads and this will not work with ka.
deviousKA is offline   Reply With Quote
Old 03-05-2004, 12:02 AM   #11
the head
the head's Avatar
Location: in a dark room mastering the art of typing with one hand
the head is making a name for him/her selfthe head is making a name for him/her self
yes the summit kits do work i run a TC motorsports adapter on my S13 SR i no longer have the packaging or i would post the number my filter is now on the passengterside frame rail behind my ladder bar then add some more hose to run the iol up to the front of the car and you got an oil cooler ready setup
i think i spent a total of 250 for my relocation kit braided hoses and ends and a 12x12 B&M oil cooler
the reason i went with a relocation kit as opposed to a sandwich adapter is because getting to the oil filter on an SR is a bitch
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
