Old 07-18-2011, 08:05 PM   #1
bentmode360
bentmode360's Avatar
bentmode360 is an unknown quantity at this point
s14 BNIB BC Ram type coilover s14
-have some bc ram type (inverted) coilovers for an s14 looking to get 1200 shipped.
-they have custom spring rates 10 kg fronts/ 8kg rears
-let me know if your interested with a pm or text me at (909)-238-3019 located in so cal if you want to pickup
heres the specs
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
-Inverted Mono-tube shock design
-30 levels of damping force adjustment, adjust compression/rebound
-Pillowball mounts and adjustable camber plates included
-Separate full length height adjustable
-One year warranty
-Rebuildable
bentmode360 is offline   Reply With Quote
Old 07-19-2011, 06:20 PM   #2
bentmode360
bump price is negotiable...
Old 07-20-2011, 10:40 PM   #3
bentmode360
bumppppppppppppppppppppppppppppppppp
Old 07-22-2011, 12:03 AM   #4
Mr Awesome
Mr Awesome is an unknown quantity at this point
check you inbox
Mr Awesome is offline   Reply With Quote
Old 07-23-2011, 07:24 PM   #5
Mr Awesome
SOLD will be here thursday
