#61 |
my fronts are no where near maxed out. im going to go lower and increase camber in the back soon. today i just rolled the rears with a small pull, and in the front i just bent the tabs in the front. more low coming soon and more camber in the rear. ill post pics when its all done
#64 |
hey guys
i picked up 19x9 and 19x10.5 Are the tires sizes 225/40 and 245/40 considered stretched for these rims? i have a 350z and looking to have the rims sticking out of the fender. +1 offset with spacers. Lowered enough that the sidewall touches the fenders |
#66 |
![]() Join Date: Oct 2010
Sup guys, I have a kouki S14 and I think I'm buying 18x9.5 +12 wheels. I've talked to a few people and from what I got, I'm going to have to run -2 camber and get my fenders rolled. Now the only concern I have is if I'm going to be rubbing on the inner wheel wells? I just want the wheels to be flush with the fenders, Have and inch and a half distance between my fenders and wheels and not have to run negative camber, it's my daily.
#67 | |||
![]() Join Date: Jul 2005
![]() Instagram - SJKnoop |
#68 |
i used this website to calculate the stretch
Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch going from 245 to 215 reduces the diamter around .8"..-_- (which mean .8" drop) is this right? if it's true, i gotta go 40 profile |
#69 |
Cool thanks, 95 KA-Turbo. Do you know if negative camber is a must still? Im not trying to be slammed down I want that Two finger gap between the tire and the fender
#70 | ||
#72 |
alright i decided on 18s for my s14. i want to get rota grids i believe but i need to know what offset i can run without spacers or fender modifications and clear the coilovers on front..go easy on me
#73 |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
You didn't specify width, but I believe grids in 18" only came in 9.5" +15.
With that said, 9.5 +15 will fit & they will clear the coilovers. However, the only way you can be low with that size is stretched tires with a slight roll, slight pull, and camber. Matter of fact, here's a pic of Grids 18X9.5" +15 on a S14: He's running 225/40 up front and 245/40 in the rear. You could try running a monster stretch with 215/40 all around or a less extreme stretch with 225/40 all around if you want to get low. ![]() ![]() |
#75 |
![]() Join Date: Jul 2009
![]() Feedback Score: 17 reviews
Depends how low you are. If you slammed a small spacer will help like a 10 mm cuz 25mm with a stretch tire is gonna be a little sunk.
http://thatistupid.tumblr.com/ |
#77 |
Depends on what you are willing to do because 10mm is a effective +15mm which is a roll and small pull, 15mm spacer is about the same but bigger pull and a little bit more camber.
#78 |
A 10 +25 will not clear your coilovers up front. You'll need to space it out around 13mm to clear your coils...that will make it a bit of a bitch to fit up front. S13s don't like wheels over 9.5 up front without tubs or widebody. You can definitely do it, but it'll take some work.
A 10 +25 with a 235 requires a slight pull on S13s out back, so you will not need spacers....unless you're trying to run like neg 4-5 camber. A 9 +15 with a 215 fits just about perfect with -3 camber and a roll. The 10 +25 fits 3mm further out then that...plus a 235 is wider.
#82 |
Do the 9.5 up front with a 5mm spacer and 10 out back with no spacer. 225/40s and 235/40s for a medium stretch, and 215/40s and 225/40s for a more aggressive stretch.
That should clear your front coils no problem and allow for decent clearance. Go for the larger tires if you don't want to slam it too much. Do you have a zenki or kouki S14?
#83 |
Hey guys ive searched but could find the answer I was looking for. I have a s14 I have ait 30mm d1 series front fenders and 30mm rear fender overlays I want to run 18x9.5 +12 offset rota p45r all around I was wondering if this wheel offset would be flush or if I have to run spacer I don't want to much Camber would prefer oem camber specs. Also what tire size would you guys recommend
#85 | |
#87 | |
24s will NOT fit on a S13, they barely 'fit' on a 2000 Mustang, lol. I'd say 21/20 stagger (bigger up front), lower it till the fender is at the wheel lip all around. Then ride in style. Mission accomplished.
#88 | |
Trader Rating: (38)
#90 | |
what the heck are the wheel and tire specs on that hatch?! its flawless. seems to be semi functional and still flush. |
