Old 03-09-2004, 08:12 PM   #1
four
four's Avatar
four is an unknown quantity at this point
Send a message via AIM to four
Suggestions? (t28 wastegate issue)
I got a used t28 off a supposed s15 which could only mean that it had to come from an auto S15 or a s14 sr20det. (the wall divider isnt there)
anyway:
the previous owner had it externally wastegated, therefore the internal wastegate door is welded shut. should I:
Get an external wastegate?
Get a new wastegate door and use the internal gate?
Use a dremel to dremel out the weld?
I also forgot to mention that the stock actuator isnt there, but I can get one easily.
thanks in advance
four is offline   Reply With Quote
Old 03-10-2004, 06:05 AM   #2
four
four's Avatar
--bump--
Old 03-10-2004, 07:59 AM   #3
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
just use an external one sooo much better tial 35mm
you go now
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 03-11-2004, 09:38 AM   #4
four
four's Avatar
do you know how much the tial 35 mm go for? Im trying not to spend over $100
Old 03-11-2004, 10:28 AM   #5
crash153
crash153 is an unknown quantity at this point
four, easiest,smartest, and cheapest thing to do would be to remove that weld. i wonder how high of boost he was running? if you don't have an actuator, and plan on running 12 psi, there is a nice actuator kit made by hks @ phase2motortrend.
crash153 is offline   Reply With Quote
Old 03-11-2004, 11:17 AM   #6
four
four's Avatar
im worried if i remove that weld, the wastegate door wont be opening/closing properly.
Old 03-11-2004, 12:29 PM   #7
crash153
hrmm
worth a try at least. if worst comes to worst, you can always weld it shut again...and go for the tial.
Old 03-11-2004, 01:34 PM   #8
steve shadows
steve shadows's Avatar
Originally Posted by crash153
hrmm
go external... if you want to be pimp pick up one of those stainless hpi manifolds and have the wastegate flange welded on the no 4 runner really close to the merge area and then vent it out under the car very pimp will let the small turbine breath higher in rpms and much more consistant boost levels...
-steve
Like Me on FaceBook !
Old 03-11-2004, 01:39 PM   #9
four
four's Avatar
okay, where can i find an external for about $100
Old 03-11-2004, 02:13 PM   #10
steve shadows
classifieds, ebay, etc, or you can invest in a good one and pick up a tial for about 200 or so. I would say this is worth it, the tial 38 mm will be sufficent for needs up to 400whp range...
Old 03-11-2004, 02:16 PM   #11
four
four's Avatar
is it a bitch to install? i have no clue how to install it
haha
