Old 08-26-2011, 09:46 PM   #1
zerocoolalmi
zerocoolalmi is an unknown quantity at this point
rb25 overheating
When I'm running my RB25 on idle or High RPM it get's hot real fast. The Upper RAD hose is HOT and
the bottom one is cold... I was not just of what could be broke beetween the Waterpump or the
Thermostat ?
So I took off the thermostat and tried running the engine again. The Temp Gauge don't climb over
the mid bar... so it's perfect ? But after a couple of metal to metal the temp gauge goes back to the
top.. because the coolant does'nt have the time cool down in the rad before going back into the engine
I tried my stock thermostat into boiling water at home... and the thermostat is working.. so I put
everything back in place... and still Temp Gauge goes back in the red"
Someone have any ideas ?
zerocoolalmi is offline   Reply With Quote
Old 08-27-2011, 04:38 AM   #2
Biggamehit
Biggamehit's Avatar
Biggamehit will become famous soon enoughBiggamehit will become famous soon enoughBiggamehit will become famous soon enough
Send a message via AIM to Biggamehit Send a message via MSN to Biggamehit Send a message via Yahoo to Biggamehit
whats your mixture for coolant and water?
are you bleeding the system properly?
what kind of fan are you running?
Facebook: Pink Ranger Drift
Biggamehit is offline   Reply With Quote
Old 08-27-2011, 07:12 AM   #3
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
stock temp gauge? did you put the KA temp sensor on the RB or are you using the RB GAUGE sensor. the small one wire temp sensor needs to be changed to the KA sensor because the skyline temp gauge is different than the KA. if you dont it will not read the correct temperature. it says you are overheated but you really could be running NOT
ch1873857 is offline   Reply With Quote
Old 08-27-2011, 07:49 AM   #4
zerocoolalmi
ooo. may-be is the sensor.. I use a SR sensor..
and I run almost only water
and yes I bleed properly
Old 08-27-2011, 07:50 AM   #5
zerocoolalmi
the probleme is not the fan.. or mixture.. because de rad be cold when I put a thermostat in the system
Old 08-27-2011, 09:52 AM   #6
zerocoolalmi
someone know if the rb25 sensor is exactly the same as a sr20 ?
Old 08-27-2011, 12:23 PM   #7
ch1873857
just stick the ka one in itll take 5 minutes if you have one which im guessing you dont
Old 08-27-2011, 12:45 PM   #8
zerocoolalmi
i have a sr20 sensor on the car right now.. i think is the same as a ka .. because the temp gauge inside was the same.. but i have a old rb25 sensor somewhere.. tomorow ill try it.. but i just wanna know if someone know if have a difference
haha by the way.. sorry for my english im from QuébeC
