Old 09-10-2011, 08:25 AM   #1
Breakbeat93
Breakbeat93 is an unknown quantity at this point
S14 sr super high afr PLEASE HELP
I just got my s14 sr in and running. Feels strong, and I hear no detonation, but my afr is at 16-18 at wot until about 4500 rpm. Then it comes down to about 13.5 and goes down to about 12 by redline. The o2 is mounted right under the shifter. Walbro pump, z32 filter, 3 inch catless exhaust, front mount, s14 mafs, stock ecu tune. I have a cheap pos fuel pressure gauge showing about 50lbs at idle and jumps to 60 when I pull the throttle. I don't wanna pop my engine before I even get to use it. PLEASE HELP!
EDIT: I'm reading up to about 6 psi at the manifold while my afr is still buried in the red
Breakbeat93 is offline   Reply With Quote
Old 09-10-2011, 06:47 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You double checked your timing and made sure its not advanced? Also, if everything is stock, kick the FPR down to 40 psi with out a vacuum source hooked up to.
CLICK HERE!!!
Old 09-10-2011, 07:18 PM   #3
fufanu180
fufanu180's Avatar
fufanu180 is an unknown quantity at this point
At stock that's what the fuel pressure should be at? 40lbs?
fufanu180 is offline   Reply With Quote
Old 09-10-2011, 07:54 PM   #4
Breakbeat93
Stock should be 43. I pulled vac from my fpr. No change
Old 09-24-2011, 09:08 PM   #5
fufanu180
fufanu180's Avatar
Pulling the vacuum line will cause it to rise to like 48 correct?
On the s14 sr20det, the vacuum hose comes from the port off the intake manifold or the throttle body?
CenTex240
