Old 03-17-2004, 02:31 PM   #1
Natty
Natty is an unknown quantity at this point
Does this look like normal tire wear to you?
Okay, I have Bridgestone Potenza RE950's with around 3,000 miles on them. Not autocrossing or hard driving yet. Not lowered or anything. They are directional tires. I just got them aligned, rotated, and balanced for the first time since I put them on. Cold air pressure was a bit low at 26, however. I'll fix that right now actually.
The file labeled "front" are now on the front, they used to be on the backs. I don't think they are worn too bad.
The pic labeled "back" is now on back, used to be on the front. These ones look pretty worn to me. Look particulary on the side of the tread, looks sort of cracked up. It was always aligned, but I know my tie rods ends and TC rods, along with bearings or rotors are causing some shimmy when braking and crusiign at 55mph.
Maybe I'm just being paranoid, but the set that used to be up front looks alot more worn for only 3k miles.
Edit: Front.jpg is on the left, Back.jpg is on the right.
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 03-17-2004, 03:06 PM   #2
nissandrift
nissandrift is an unknown quantity at this point
Send a message via AIM to nissandrift
I don't know anything about the wear, but I planned on buying those tires in a few weeks. Whats your opinion on them, besies the odd wear pattern?
nissandrift is offline   Reply With Quote
Old 03-17-2004, 03:17 PM   #3
mrmephistopheles
mrmephistopheles's Avatar
you doing hard driving or experiencing understeer?
Old 03-17-2004, 04:41 PM   #4
Natty
No understeer or hard driving. I babied them and broke them in nicely.
I like them so far. Little road noise, a pretty smooth ride, good grip (for an all season) and great wet traction (for an all season). If you don't need wet traction, find some RE930's, they have better dry traction, but not so good wet traction. The RE950's are supposed to last a while, but I guess we'll see.
I'm not sure if this is an odd wear pattern. Hopefully not
Old 03-17-2004, 05:34 PM   #5
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
maybe the shocks or bushings are sagging like on my car and starting to show tire wear....Thats what it was for me last spring anyhow....see the pic attached...I still havent fixed it but when I do the bushings Im hoping it will stop (i have new tires now but youll see from the pic)
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 03-17-2004, 06:22 PM   #6
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
I don't know if it's just me but it seems like you're making a big deal outta nothing. Looks fine to me, don't worry about it and just drive.
-Juan
240Stilo is offline   Reply With Quote
Old 03-17-2004, 06:24 PM   #7
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
maybe excessive toe in?? anyways.. doesnt look too bad.. i wouldnt worry bout it
Grant is offline   Reply With Quote
Old 03-17-2004, 06:51 PM   #8
rednerd
rednerd is an unknown quantity at this point
If your alignment is good (implying ball joints and tie rods), I'd put money on your struts. My BMW had similar scalp marks because of worn struts.
rednerd is offline   Reply With Quote
Old 03-17-2004, 07:38 PM   #9
96twofourty
96twofourty is an unknown quantity at this point
do a shock test (push on all 4 corners of the car and see which shock/s are out)
96twofourty is offline   Reply With Quote
Old 03-17-2004, 09:20 PM   #10
Rexbo
Rexbo is making a name for him/her selfRexbo is making a name for him/her self
Send a message via AIM to Rexbo Send a message via MSN to Rexbo
I used to have re950s on my old car, and those were the best tires i've ever owned! They almost have more grip in the rain than they do when its dry! I did notice a little side wear on them at first, like you had, then it went away as the tire wore down. Don't worry about it man, they're awesome tires and you'll never have a problem with them, other than a little bit of chunking if you drift hard.
Rexbo is offline   Reply With Quote
Old 03-17-2004, 09:40 PM   #11
gogeeta13
gogeeta13 is an unknown quantity at this point
Send a message via AIM to gogeeta13
WHat bushings do that? My tires wear like that too!
1996 Maxima 5 speed
1993 Altima SE
1993 240sx Base - SOLD
[Blacktop and such]
1992 240sx Base - SOLD
[Road Race/Auto X Beast]
1993 240sx Hicas - SOLD
2001 Xterra SE V6 4x4 5 speed - SOLD
gogeeta13 is offline   Reply With Quote
Old 03-17-2004, 10:00 PM   #12
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
Those tires look barely broken in. I have 1200 miles on my Azenis Sports and they're already scuffed, scraped, and feathered. (I need to rotate them, I know.) However, I hardly drive nicely.
Don't worry about the wear, it's fine... although after 3k miles, there actually should be more wear, pansy!
Kidding.
KA24DESOneThree is offline   Reply With Quote
Old 03-17-2004, 11:31 PM   #13
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
nothing wrong.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 03-17-2004, 11:58 PM   #14
twitchy
twitchy's Avatar
im thinking if your control arm bushings are shot they would cause saggage and tire wear...maybe im wrong
Old 03-18-2004, 01:51 PM   #15
Dream240
Dream240's Avatar
Alright I can't believe no one else caught this, it's the one thing you actually mentioned. The air pressure. Trust me, that wear is from too little tire pressure, Basically, when you're underinflated, you get sagging on the edges of any radial tubless tire. Actually right where your marks are. There's extra strain on your tires at that point causing the scraping, especially when you turn. No matter how easy you turn, your pushing that edge hard against the pavement when you run 26 PSI. I run my car at 33 psi, and I really wouldn't recommend anything lower than 30 psi. This wear is not too bad and since you said you aired them up you should be good. Just remember to check them at least once a week, maybe twice.
The one thing I see alot of guys forgetting is tire pressure!! Why God Why!!!
Especially when you start driving hard, then you really gotta have good pressure otherwise your tires won't last you one trip around the neighboorhood. Hope this helps!!
Old 03-18-2004, 03:17 PM   #16
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
that looks normal, i wouldn't stress over it. Since u just got an alingment done, i wouldn't worry about anything.
tire pressure is crucial and u should keep it at recommended psi, however it looks to me that, that is not caused by low tire pressure. If it were caused by low tire pressure, it would be a larger area worn down.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 03-18-2004, 06:56 PM   #17
kpxchonnom
kpxchonnom's Avatar
kpxchonnom is an unknown quantity at this point
Send a message via AIM to kpxchonnom
did u bent ur caster arm? get that checked
GunMetal 90 240sx FB (RPS13)
Tein He's front,back level 12(very stiff) Tein TieRod, End
Watanabe(polished lip, black center)with GTZ
kpxchonnom is offline   Reply With Quote
Old 03-18-2004, 10:09 PM   #18
KA24DESOneThree
I run 39psi front and 37psi rear on my Falkens. It still seems a bit low, i might try 41psi front and 38psi rear to try and increase grip.
Dream240 is right about tire pressure; by running it that low, you're folding the tire over onto the sidewall whilst under cornering loads, thus wearing the outer edges of your treadblocks prematurely. (The premature wear has not happened yet, but will with time.) Also, your tires will squirm and fold so much that handling predictability and ultimate grip will suffer.
Increase the air pressure in your tires. If your car has oversteering tendencies, run higher pressure in the front than in the rear; reverse for understeering tendencies. You'll probably have to play with pressures, too low and you'll have excessive wear on the edges, and too high and you'll have excessive wear in the center.
Old 03-18-2004, 10:12 PM   #19
epoxy_nc
epoxy_nc is an unknown quantity at this point
those dires are AWESOME.. they last forever ... even if you have fun on them.
i like the 930s as well... both are a great traction tire and last a decent while as well.
epoxy
sr20det powered '93 coupe se
epoxy_nc is offline   Reply With Quote
Old 03-21-2004, 03:51 PM   #20
Natty
Do you like the 950s or 930s better?
Thanks again for the input. I'm now running 36psi when hot, but I'm playing around with it to find a nice balance.
Old 03-22-2004, 02:11 AM   #21
bigjasoni
bigjasoni's Avatar
bigjasoni is an unknown quantity at this point
Send a message via Yahoo to bigjasoni
Listen to dream240. Sometimes we get too technical, and overlook the more simple things involved with owning cars. I once half way tore apart a 4g63T trying to figure out why my Talon wouldnt go. I had a disconnected plug right on top of the engine right in front of my face. Tire wear doesnt seem serious at first, but give it a couple thousand miles, and see what happens.
bigjasoni is offline   Reply With Quote
