Old 09-17-2011, 03:18 PM   #1
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
problem with coilover install
ok i got a set of kei offices a few weeks ago and i attempted to do the whole coilover install yesterday. i started at the front. i got the passenger side out with no problems and fitted the coilover in and everything.
then i got to the drivers side......
basically i ended up with this
see that bottom bolt on the strut attached to the spindle? would. not. budge. at one point the whole assembly was stuck in the position you see right now. the bolt was i guess pinning it in this position. me and some friends tried everything to try and get that bolt out. we pb blastered the hell out of it, we even ran to the auto store and got like a 24' half inch breaker bar. the socket skipped over the edges of that bolt.
so i called it a night and decided to deal with it in the morning. this morning i tried some more things like moving the strut around to see if i can release the pressure, but that didnt work. it was however able to move again for some reason (in and out) so i could re-align it back to its original position, which is what i decided to do since i couldnt get it off. so i took the c/o out from the passenger side and put on the original struts and bolted everything back up. now that bolt on the drivers side is still in there and wont move at all, but i was able to get that assembly back in place and bolted up at the top so i could still drive the car (i was in a friends garage and i didnt want to leave it there).
now fellow zilvians i need your input. i was thinking 2 choices...one, i could power saw that 2-bolt bracket connected to the strut off, then take the spindle off and see if i can work on it to get the bolt off. OR i can just get another spindle (bolts as well) and replace that spindle, just take whats on there completely off so i wont have to cut anything. what do you guys think?? any better ideas? advice? i really want to put these coilovers on lol, any help is appreciated. thanks
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline   Reply With Quote
Old 09-17-2011, 03:19 PM   #2
rob22
rob22's Avatar
Trader Rating: (50)
rob22 is an unknown quantity at this point
Feedback Score: 50 reviews
pics not working for me.
wtb s14 roof wing/spoiler! pm me
rob22 is offline   Reply With Quote
Old 09-17-2011, 03:39 PM   #3
Edwin562
Edwin562's Avatar
yep, pic not working
Old 09-17-2011, 06:25 PM   #4
DenkiMan!
DenkiMan!'s Avatar
oh my bad, it should be working now
Old 09-17-2011, 06:33 PM   #5
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
detach the anti roll bar.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 09-17-2011, 07:26 PM   #6
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
That. It pushes the lower control arm up and it pushes the control arm even higher because the other side is a lot lower.
chituntang is offline   Reply With Quote
Old 09-17-2011, 07:32 PM   #7
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
OR
make sure the other side of the car is off the ground and the car isnt tweaked.
i will add this pisses me off everytime i need to install fronts
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 09-18-2011, 07:50 AM   #8
Phatsilvia
Phatsilvia is an unknown quantity at this point
You need to compress the strut so it takes the pressure off the bolt if you have a jack, jack up on the hub to relieve pressure
Phatsilvia is offline   Reply With Quote
Old 09-18-2011, 07:57 AM   #9
Airborne711
Airborne711 is an unknown quantity at this point
sway bar, easy.
Airborne711 is offline   Reply With Quote
Old 09-18-2011, 08:30 AM   #10
siksyndicate
siksyndicate is an unknown quantity at this point
^ is the right answer
siksyndicate is offline   Reply With Quote
Old 09-18-2011, 09:02 AM   #11
562nissan
562nissan's Avatar
562nissan is an unknown quantity at this point
Use your newly acquired breaker bar and stick it between the bottom of the coilover and the spindle and pull up. The bolt will practically fall out. Funny, this same thing happened to me and a friend. There is something different about the driver front suspension that causes this.
562nissan is offline   Reply With Quote
Old 09-18-2011, 09:51 AM   #12
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
+1 on popping the sway bar off...
That should cause the whole LCA and knuckle assembly to droop down.
CLICK HERE!!!
Old 09-18-2011, 12:47 PM   #13
DenkiMan!
DenkiMan!'s Avatar
i did try jacking up the hub to compress the spring, but the bolt didnt even budge.
i also had the car evenly sitting on jackstands at the front. the reason why i didnt pop the sway bar off was because when i was looking at alot of numerous install threads, no one really did that. i heard before it makes it easier but not completely necessary
will probably have another go at it sometime this week. thanks for the help
Old 09-25-2011, 08:53 PM   #14
DenkiMan!
DenkiMan!'s Avatar
bringing this back from the dead.
this weekend i attempted another swing at this stupid bolt. i basically removed the sway bar and the bolt still wouldnt come out. i also tried compressing the strut a little more, but it wont come out, not even a little. the whole spindle assembly rotates forward and back like its supposed to, but the bolt moves with spindle instead of independently, i guess its just seized in there. im thinking about just replacing that spindle, just take it off with the strut on it and bolt another one up and go that route.
Old 09-25-2011, 09:07 PM   #15
chituntang
Having the jack too high/low will push the bolt against top/bottom of the hole. You have to hit the sweet spot in the middle. If the bolt is loose, you should be able to use a wrench and spin it. If it is not loose, use a hammer. It works wonders...
Old 09-25-2011, 09:13 PM   #16
nemcho
nemcho is an unknown quantity at this point
I just bang it with a hammer and a screwdriver. Not the best way but it works and I managed to not strip the bolt everytime. But I', sure you already thought about or tried that. The jack technique helps to. Or anything that can shake the coilover up and down.
nemcho is offline   Reply With Quote
Old 09-25-2011, 09:13 PM   #17
Taylor008
Taylor008 is an unknown quantity at this point
BFH.
mslghslhgshg
Taylor008 is offline   Reply With Quote
Old 09-25-2011, 09:13 PM   #18
DenkiMan!
DenkiMan!'s Avatar
i did all of that the first time i tried getting that bolt out. in my first post i said i used a breaker bar and that didnt work at all. hammer didnt do the job either. i tried a whole bunch of different heights with compressing the strut and it wont come out
Old 09-25-2011, 09:22 PM   #19
delado
delado's Avatar
delado is an unknown quantity at this point
Ok so this is the point where you grab a hammer and fling it across the windshield
delado is offline   Reply With Quote
Old 09-25-2011, 09:29 PM   #20
Phatsilvia
Have you tried heating up the bolt with a set of torches???
Old 09-25-2011, 09:35 PM   #21
nemcho
sometime at this point I just put both bolts back on the bottom sleeve and also put the 3 top nuts back (even tho there are not suppose to be out at this point). Then I try to take the bottom bolt first by banging with a hammer and screwdriver and leave the screwdriver there at its place and then I take the top bolt out. The screwdriver will be easy to take of then.
Old 09-26-2011, 12:04 AM   #22
chituntang
I guess you need to take the brake off and beat the living crap out of the bolt then...
Old 09-26-2011, 12:41 AM   #23
d r i f t swift
d r i f t swift's Avatar
d r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the roughd r i f t swift is a jewel in the rough
id take the hub/ brake caliper/ rotor off. take the spindle along with the strut off of the lca and take it off the car so you can get a real swing with a huge sledgehammer. or find somewhere who has a press and press that stupid bolt out.
rip bobby.. you will be missed..
d r i f t swift is offline   Reply With Quote
Old 09-26-2011, 12:49 AM   #24
aKaFlipSide
aKaFlipSide is an unknown quantity at this point
I would jus beat the hell out of it.
aKaFlipSide is offline   Reply With Quote
Old 09-26-2011, 10:53 AM   #25
DenkiMan!
DenkiMan!'s Avatar
havnt tried that yet, no access to a blow torch at the moment
tried, no luck
im thinking about doing this, just get a spare spindle for insurance lol
Old 09-26-2011, 11:52 AM   #26
Phatsilvia
A propane torch might work I've never tried using one before just always had access to torches
Old 09-26-2011, 12:41 PM   #27
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
torch and hammer, i'm gonna blame your puny strength and being timid on this one, just beat the crap out of the bolt. I have yet to be defeated by any piece of hardware, its either coming out by force or in pieces..
good luck
nismoracingsx is offline   Reply With Quote
Old 09-27-2011, 11:28 AM   #28
DenkiMan!
DenkiMan!'s Avatar
good luck
there is some truth to this haha, but the main reason for that is due to the amount of stuff in the way from getting a good wack at it. thats why ill probably take the spindle off and go to work on it. ill try and update this weekend.
Old 09-27-2011, 11:35 AM   #29
takyo_style
takyo_style is an unknown quantity at this point
usa a hammer!
takyo_style is offline   Reply With Quote
Old 09-27-2011, 11:45 AM   #30
drift_king
drift_king's Avatar
drift_king is an unknown quantity at this point
bigger hammer
drift_king is offline   Reply With Quote
