Old 09-22-2011, 04:35 PM   #1
Phatsilvia
Phatsilvia is an unknown quantity at this point
S13 Sr20det motor and engine parts for sale
Hey guys im parting out my motor, i have a bunch of parts kicking around for sale heres a small list if theres anything else you would like let me know and ill check if i have it thanks.
Engine block with crank($350)
Head($200)
alternator and brackets($100)
New timing chain assembly and tensioner(only 1000km)($100)
Cam Angle Sensor($100)
oil pump($100)
Drifting oil pan($100)
Starter($100)
High flow fuel rail($100)
Venom 800cc injectors(only 1000km $350)
Idle Air Control Valve($50)
Rocker Arm Stoppers(2 sets)($50 each)
Painted white valve cover($150)
Coils (4)($100)
Crank/water pump pulleys($50)
Knock Sensor($50)
ECU 2 of them($200 each)
AEM EMS series 2 (30-6601)($1500)
Air to water intercooler set up includes intake manifold, top mount turbo manifold, turbo, water tank, water pump, heat exchanger, intercooler, 3 inch downpipe.($2000)
Ogura Racing Clutch and flightweight flywheel-$650
Synapse BOV like new-$150
synapse wastegate like new-$150
A/C pump with braket wokrs-$100
Power steering pump(2)-$100 each
this is the car all these parts came out of
If theres anything else please let me know
Phatsilvia is offline
Old 09-22-2011, 06:16 PM   #2
1slicktwo4oh
Trader Rating: (45)
1slicktwo4oh is an unknown quantity at this point
Feedback Score: 45 reviews
anything wrong w/ the head, no tick,?????
1slicktwo4oh is offline
Old 09-22-2011, 08:03 PM   #3
Phatsilvia
no nothing wrong with the car the engine was running when I took it out just decided to upgrade thats all
Old 09-25-2011, 07:36 PM   #4
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
Has the motor been torn down yet? Presuming that it didn't fail before disassembly and the parts are near new, I am curious about the oil pump (front engine cover) and timing chain set/guides/tensioner.
Seraphim38 is offline
Old 09-25-2011, 09:26 PM   #5
Phatsilvia
Yes the motor has been completely torn down but like I said it was running when I took it out, the oil pump is the stock one that came in the car originally. The car is from japan and is the stock sr20 that came in it , this motor has 150000km and the timing chain set is brand new maybe 1000km on it
Old 09-26-2011, 02:32 AM   #6
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
could you send me more specs on the air to water intercooler setup with pics of heat exchanger, pump, ect. also, specs on the size of heat exchanger, size of water to air intercooler, ect. thanks.
https://instagram.com/eck_matthew/
Imarvin240 is offline
Old 09-26-2011, 06:00 AM   #7
theboy
theboy is an unknown quantity at this point
how much for the power steering pump bracket/tensioner/bolts shipped to 61073?
theboy is offline
Old 09-26-2011, 06:15 AM   #8
Phatsilvia
150$ shipped and I can ship it out to you Wednesday
Old 09-26-2011, 06:21 AM   #9
Phatsilvia
And I forgot to mention that the timing chain assembly is an OEM Nissan part
Old 09-26-2011, 06:43 AM   #10
Phatsilvia
The water to air set up is amazing it's way more efficient than the conventional front mount. The turbo side of the intercooler gets so hot that you can't touch it and then after it goes threw the intercooler the intake side is cold and you can touch it and leave your hand on it and it doesn't get hot. The set up comes with a custom built top mount manifold ceramic coated, custom built 3inch downpipe, greddy knock off intake manifold customized with a 3 inch throttle body, the water pump is a electric Bosch water pump, water tank which holds all the cold water/coolant, t3/t4 gt30 chinabob turbo customized with a 3inch outlet and ceramic coated exhaust housing. I'm just at work right now I will get you the specs on the heat exchanger and intercooler and will also send you pics of everything. The intercooler is in the picture above.
Old 09-26-2011, 06:46 AM   #11
jbretz
jbretz is an unknown quantity at this point
radiator? valve cover and catch can setup with lines?
jbretz is offline
Old 09-26-2011, 07:37 AM   #12
Phatsilvia
I don't have a spare rad for sale, I do have the valve cover and catch can set up still for sale. The way I have my catch can set up tho is I have two one way AN fittings in my exhaust at a 45 and it's like a whistle and sucks the air out, it's popular on alot of racecars. For the whole set up with valve cover I would be looking for 300$ and the valve cover has a brand new gasket that I put in when I put the car back together not even 1000km on it. Im just at work right now but I'll get you pictures of those AN fittings and hose.
Old 09-28-2011, 03:15 PM   #13
Phatsilvia
These are those AN fitting i was talking about
And here are the AN fittings welded in the valve cover
Old 10-03-2011, 06:10 PM   #14
Phatsilvia
Hey just an update I sold the head so it no longer available, and also I have a few new parts for sale.
Ignitor card-100$
Maf sensor-100$
Aem wideband like new maybe 1000km on it-100$
Old 10-11-2011, 11:59 PM   #15
dragooner00
dragooner00 is an unknown quantity at this point
interested in the block shipped to 61880, everything is there correct? all i need is to mount a head on it and get my transmission bolted up plus hoses etc and the whole asembly is good to go?
dragooner00 is offline
Old 10-12-2011, 12:48 AM   #16
blades13.5
blades13.5's Avatar
blades13.5 is an unknown quantity at this point
what ecu's u have? (w/ tune info)
blades13.5 is offline
Old 10-12-2011, 11:00 AM   #17
Phatsilvia
Yes I can ship to you I'll get you a price on how much it would be, everything is there. The only thing is you would need to replace the rod bearings, two of them were wore out but never hurt the crank any. I also have ARP Head studs that were hardly used maybe 1000km on them that I would sell for 100$.
Old 10-12-2011, 11:06 AM   #18
Phatsilvia
I have two sr20det ecus, one is for a red top and one for black top. I was using the black top one in my redtop for over a year they are the same. And I have the Aem ems ecu for complete stand alone. The stock ecus have stock tunes on them.
The sticker on the redtop ecu has these numbers on it
E5
23710 50F05
A18-C80 G26
The black top ecu I don't know because the sticker was all faded
Old 10-12-2011, 09:58 PM   #19
Future240
Future Moderator
Future240's Avatar
Ignitor card-100$
Maf sensor-100$
http://zilvia.net/rules.html
Thread Bumping
You may only bump your thread TWICE. That is not 2 times a day, or two times a week. TWICE only.
A bump is constituted as any unnecessary post you make in your sale thread. This can include:
“Bump”
“To the top”
“All Pms Responded to”
“Price Drop”
Etc, etc, etc
You should utilize the PM system to answer potential buyer's questions, and you can edit your initial post to reflect any detail updates, or price changes.
Originally Posted by ThatGuy
Future240 is offline
