Old 10-17-2011, 08:54 PM   #1
jesse1984
jesse1984 is an unknown quantity at this point
Arrow Flushing Power Steering system...just bought the car..it has wrong fluid help!!!!!!
just bought the car. has a P/S fluid leak. after searching on here to fix/find/even rebuild pump...i found that it is suppose to have ATF not power steering fluid. so i need to know how to flush the system so i can fill it with ATF and see if that is what's leaking and then figure out how to fix it. i just hope it hasnt F'd up the R&P. Thanks in advace.
jesse1984 is offline   Reply With Quote
Old 11-07-2011, 03:08 PM   #2
sidelight
sidelight's Avatar
sidelight is an unknown quantity at this point
under the steering fluid resevior, there is a black hose, a screw on clip at the top.
Another clip at the end of the black hose.
Loosen the clip to where you can yank the black hose off.
1 Put a gallon pan under the steering reseviour. A lot of cardboard under the whole front.
incase you live in apartments
2 Take of the black hose and let all the dark fluid out
3 NEVER STEER THE WHEEL WITH NO FLUID IN THE RESEVOUR
endtime fighter is I and a few others
sidelight is offline   Reply With Quote
Old 11-10-2011, 01:41 PM   #3
jesse1984
sounds good ill be working on this once i figure out what rong with my #1 Cyl..check out the thread and see what you think
Old 11-11-2011, 10:26 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I took off the reservoir and dumped it out. Refilled with ATF fluid and some more thickener, just keep topping it off until you bleed out all the old fluid.
CLICK HERE!!!
