Old 10-28-2011, 08:07 PM   #1
evoLuzN
evoLuzN is an unknown quantity at this point
Need someone to come fix my car!
Make the story short, car just got tuned. The next day, it barely run! Here is the problem, when I step on the gas, I can hear the turbo spooling, air intake sucking in air but the car don't go! I did double check on all the piping, looks fine. Did talk to the tuner, telling me might be the boost leak or vacuum which I think it is. Before I tow back to the tuner, I need a local hobbyist that familiar with my new built Sr20det, give it a shot. We can work out a small amount of price, I'm located at Silver Spring, MD. Please text 862-368-triple three 8.
Title "local forum guy, able to help fixing your sr20. SOS!! help out guys~!!*
MOD:
-SR20DET Redtop Powder Coated Blue
-700 Miles on Rebuild
-Apexi Power FC with Commander
-GT30 Set at 11 LBS....
-Moroso Oil Pan
-Tubular Manifold
-MeganRacing Turbo Elbow
-Apexi 3 Inch Downpipe
-Apexi Catback N1
-HKS Wastegate Actuator
-Stainless Steel Turbo Lines
-Greddy BOV
-Greddy FMIC
-Greddy Intake Manifold
-Aftermarket Fuel Rail with Nismo 740CC Injectors
-Z32 MAF
-Z32 Fuel Filter
-Stainless Fuel Lines Front to Rear
-Aeromotive Fuel Pressure Regulator
-Nismo Motor & Transmission Mounts
-Koyo Radiator with One Slim Fan
-New Water Pump
-New Oil Pump
-All new hoses and belts
-Circuit Sports Catch Can
-Spec Stage3 Clutch
-Spec Flywheel
evoLuzN is offline   Reply With Quote
Old 10-28-2011, 08:36 PM   #2
Nimso
Nimso's Avatar
Nimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud ofNimso has much to be proud of
hey, this might help you. go to youtube, type in this "boost leak testing 101: building the tool." go buy all of that stuff from the hardware store/auto parts store. it shouldnt cost you more than 30 bucks. then you just hook it up to where your air filter goes (to the turbo or pipe going to the turbo) and then fill it with compressed air like you would a tire, and listen for the leaks. thats what i did and i was able to fix a bunch of leaks that way. hope this helps, and good luck!
Nimso is offline   Reply With Quote
Old 10-29-2011, 01:30 PM   #3
evoLuzN
ya I saw that part too.. and the one with two Australian accent one. The thing is, I don't have completed tools to do all those. Just want to see if any local guy able to help out a bit!
Check me out from evo forum
forums.evolutionm.net/itrader.php?u=50754
Old 10-29-2011, 01:43 PM   #4
z32ttvert
z32ttvert is an unknown quantity at this point
check the couplers to your intercooler. As boost goes up, they often slip off.
z32ttvert is offline   Reply With Quote
Old 10-29-2011, 01:47 PM   #5
evoLuzN
Seems fine.. possible of BOV gone bad?
Old 10-30-2011, 03:19 PM   #6
evoLuzN
anyone able to help me out!? bump bump...
Old 10-30-2011, 04:11 PM   #7
Nimso
Nimso's Avatar
if you lived in arizona, i would totally help you out...i just built a boost leak tester and i have a bunch of tools/air tank in my garage hopefully someone in maryland can help this guy out!
Old 10-30-2011, 04:32 PM   #8
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
why is this in the FS section?
idahotuner is offline   Reply With Quote
Old 10-30-2011, 04:34 PM   #9
Nimso
Nimso's Avatar
not sure...maybe hes selling his body in exchange for help with his car?
