removing turbo from sr20det
does anyone have a link to some step by step instructions on how to remove the stock t25 from the sr20det, i know its not very hard, but i just want to make sure i do it right.
![]() Join Date: Mar 2002
here you go:
1. find bolts 2. find appropriately sized tool to loosen bolts 3. loosen bolts 4. ??? 5. PROFIT!! it's not rocket science. |
#3 | ||
![]() Join Date: Oct 2003
oh and step 4. maybe you should pull the bolts out after you loosen them, sometimes its hard to pull the turbo off over the heads of the bolts, even if they are loose but I dunno...
![]() Join Date: Jul 2001
Sarchastic a$$holes lol. This is the short version, as I remember it. Remove heat shield 10mm bolts, remove downpipe 14mm bolts, while your down there remove the 8mm hoseclamp from the oil return line, remove oil and water lines from block with a 17mm and a 19mm socket, fluid will leak, start removing 14mm bolts that hold the manifold onto the head, and finally have lots of fun removing the hose clamp with long needlenose pliers that holds the metal water feed line into the rubber hose line, behind the head. Lift the entire assembly out. When out, bend tabs down that are on the 4 nuts holding the T25 to the manifold, remove nuts and voila! Make sure you save those tabs! They are needed when re-installing.
Thank You and Good Night. I'll be here all week.
www.enjukuracing.com |
![]() Join Date: Sep 2002
^what he said
![]() ![]() ![]() ![]() I know its dirty as chit... had exhaust leaks. gotta clean.. ![]() ![]() edited order of pics
Keeping it Godzira bishes. So I murdered another turbo Last edited by Steeles; 03-30-2004 at 11:49 AM.. |
#7 | |
man! i didnt know i was posting on fresh alloy! |
Yeah, it's a real pain in the ass. My turbo mounting gasket blew out a while back (apparantly this a problem many SR owners go through). Make sure you secure those bolts from the turbo to the manifold very well. Even with the locking plates that are suppose to hold the nuts tight, they still rattle loose somehow. Might consider a tiny spot weld on the nuts that could be broken off if you have to remove the turbo again.
no the freshalloy answer would be to click here: www.google.com
Keeping it Godzira bishes. So I murdered another turbo |
#10 | |
think trial and error is the best learning method.. that's why I'm to lazy to write out instructions on stuff like this.. wait.. did I say lazy? I meant... busy... -Kevin |
__________________ i think this is one of the funniest replies i have ever read. |
