Old 11-20-2011, 12:46 AM   #1
rongfk
rongfk's Avatar
rongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond reputerongfk has a reputation beyond repute
Question For SALE, turbo built ae86
-SOLD-
update 9/12/13 - back up for sale...offer up, car runs and drives, tags paid up just passed star smog.....haha. put down 150hp on the dyno @ 5psi due to a boost issue at the time of the tune. so it could use a retune if you want to see its full potential. serious offers email me if interested [email protected]
9/26/13 boost issue solved: I'm running a sr20 redtop Garrett t25 with the waste gate relocated to the rear of the compressor housing for this setup. the mounting holes on the front of the compressor were never capped off. not it boosts fine. (cant believe the shop I hade working out the ecu and tune couldn't figure this out)
QUICK WALK AROUND VIDEO (this is when I first got it back)
http://www.youtube.com/watch?v=OTJEeyrCr08
the body and paint are the worst part of the car so she's no 2000 plus cream puff, just recently learned it has a small oil leak some where, probably just need to clean, pinpoint, and tighten a bolt/nut or something.
This has been my build for the last 3 years and now that I'm about 90% done. I'm thinking I may need something a lil more practical for a daily, especially with two kids. there is nothing wrong with it and I'd hate to let it go before I really get to enjoy it, but i thought i'd test the waters a bit before i commite to getting rid of it. ive invested alot of time and money into this car. So I'm really looking for an 04-06 Subaru wrx, I feel a tune able 4-door is just right for my situation. So here is my car and ill try and update with more pictures later. also considering trades for mid sized suv's with low milage.
have near 15,000 into so far, so if id have to put a price it would be $13k obo, AS IS.
1985 toyota corolla gt-s
its a factory gts hatch "ae88 vin" non sunroof model
clean title and current registration. just smogged
-freshly built, not even broken In yet, 7-rib 4agze longblock with new everything, it has a new full engine gasket set, new japanese nippon piston rings, new acl race bearings (main, rod, & thrust), rebuilt gze head (large port), new hks 2.0mm head gasket, new arp head stud and rod bolt kit, new race copper freez plugs, new water pump, new timing belt, new oil pump, new edis-4 coil pack, new ignition cables, etc. "this motor is fully capeable of well over 200hp+
engine set up:
-garrett rebuilt t25 with internal waste gate s13
-custom fabricated intake manifold w/ 80mm throutle body
-custom turbo piping
-hks style manifold
-hks copy blow off valve
-megan down pipe
-sard fpr
-fuel pressure gauge
-walbro fuel pump
-big front mount intercooler
-460cc injectors
-koyo aluminum radiator with an electric fan
-big oil cooler with dual electric fans
-Oil relocation kit
-samco blue radiator hoses
-ZackLee Clear cam cover
-hks adjustible cam gears (old school purple/blue)
-TODA-R 264 cams 7.9 lift in/ex
-manual boost controller
-aluminum oil catch can
-New megan engine mount
-new megan tranny mount
-new brake master cylinder
standalone ecu:
-also have a new megasquirt 2 3.0 with new custom engine harness adapted for ford edis-4 setup.
-Zeitronix zt-2 wideband with bosh Sensor
Transmission:
-good working factory t50 tranny, no grinds, wines, or anything
-new front and rear oil seals
-has a new stage 3 racing clutch with ceramic & kevlar 6 puck disk and aggressive pressure plate
-New drive shaft caster bearing
Exhaust:
-5zigen fireball catback (under diff)
-new high flow cat and resonater
has a nice tone to it
Interior:
-factory kouki gts front and rear panels re-upholstered in black suede/vinyl
-re-upholstered in black suede/vinyl front & rear seats with a factory gts patterns. front seats are celica/supra which are like the OEM gts seats but better, they are redone to match the rears with an oem corolla gts pattern.
-rare black oem headliner and rear hatch card in black suede
-black dash /a red dash Mat
-rare jdm digital cluster set up fully functional w/24609 km on it which is 15000 miles
-rare center arm rest redone to match the seat fabric.
-nardi classic steering wheel black with brushed aluminum also has a red steering wheel cover
-personal hub adapter
-quick release
-rare nardi/personal red teq horn button
-oem gts shift knob redone with a red teq button to match the steering wheel
-wink mirror
-power mirrors
-Rare oem Toyota power windows and switches
-power door locks with an oem switch
-digital afr gauge
-autometer boost gauge
-oil preassure gauge
-water temp gauge
-apexi turbo timer
-new jdm early c's short throw shifter w/ suede boot
-aluminum race pedal pads
-aluminum e-brake/drift button
-super rare black trd 4-point harness x2
-C-pillar bar
-new small race batterie
-Black body support/harness bar
-new heavy duty hatch shocks
Sounds:
-kenwood cd player ***lost the face, needs radio.
-pioneer and kenwood speakers front and rear
-orion amp pushing 2 10" kicker woofers in a custom box
*system sounds great!
Body:
has a crapy white paint job, worse than an earl schibe quality(has some dents , dings, and scratches)
-trd hatch wing
-rare twincam 16v badge
-molded side skirts (already done when i got the car)
-custom metal drop vented hood
-jdm whiteline taillights upgraded to full LED
-jdm window trueno visors painted black
-kouki modified vertex style front bumper
-kouki new oem bumper signal lights with modified signal switch to work them correctly
-kouki eye lids and corner lights
-Upgraded headlights to HID's
-Kouki oem style fiberglass rear bumper
-shaved passanger door lock
-shaved hatch lock
-Fender lips are rolled and flared to the max
-shaved antenna
-shaved rear 1/4 panel lights
-hi-tech lock setup on drivers door
-square fog lights with amber glass lenses with oem jdm fog light switch
Suspension:
-Custom camber plate and coilovers suspension set up in the front
-cut megan springs in the rear
-new full kit polyeurothane front and rear bushing kit "red"
-kyb agx front & rear adjustable shocks
-battle version adjustable tie rod ends
-new megan RCA's
-new adjustable tension rods
-battle version adjustible 4- links
-battle version adjustible lateral rod/pan hard bar
-new godspeed sway bars
-kazz 2way LSD
-New drilled/slotted brembo rotors
-new ceramic pads
Rims:
15x9 -35 all around with new falcon 195/50/15's american racing centerlines copy rims painted white with chrome and red teq emblem center caps and wheel locks
extras:
-oem zeinki complete body decal kit (for when you repaint it)
-thule bike rack
- will give a bunch of ae86 stuff along with it.
im sure there is some stuff i forgot to add..
the car has been sitting so its real dirty...
for sale: http://www.zilvia.net/f/showthread.php?t=193169
-1990 s13 hb w/all jdm 180sx goodies... gone to fresno
-1985 ae86 gts turbo... going threw a heart transplant
-1963 euro ragtop bug... asleep in the garage
Luv 2 Build, Luv 2 Show, Luv 2 Cruise!....
rongfk is offline   Reply With Quote
Old 11-20-2011, 02:31 AM   #2
limited240
limited240's Avatar
limited240 is an unknown quantity at this point
The engine looks like a mini-me 2jz must be fun to drive GLWS
limited240 is offline   Reply With Quote
Old 11-20-2011, 04:27 AM   #3
rb26detzenkiedition
rb26detzenkiedition is an unknown quantity at this point
thanks for this... i made a messy GLWS!
rb26detzenkiedition is offline   Reply With Quote
Old 11-20-2011, 08:11 AM   #4
LeaS13Zenki
LeaS13Zenki's Avatar
LeaS13Zenki is an unknown quantity at this point
damn love your car bro clean !
free bump glws!
LeaS13Zenki is offline   Reply With Quote
Old 11-20-2011, 07:33 PM   #5
Phobia Gold
Phobia Gold is an unknown quantity at this point
Trade ? Long shot. Beautiful car by the way http://zilvia.net/f/cars-sale/415646...ade-o-b-o.html
Phobia Gold is offline   Reply With Quote
Old 11-20-2011, 09:00 PM   #6
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
sweet ride, looks clean. GLWS!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 11-20-2011, 09:16 PM   #7
Sharks240
Sharks240 is an unknown quantity at this point
would you trade for a datsun 510?
Sharks240 is offline   Reply With Quote
Old 11-20-2011, 09:38 PM   #8
edwin23457
edwin23457's Avatar
edwin23457 is an unknown quantity at this point
Long shot, but down for a 93 s13ka hatch ? can send pics if interested
edwin23457 is offline   Reply With Quote
Old 11-20-2011, 10:44 PM   #9
Quban.Russian mx73
Quban.Russian mx73's Avatar
Quban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfectionQuban.Russian mx73 is close to perfection
Trade ?
http://zilvia.net/f/cars-sale/419558...miles-f-t.html
Violent Running Tribe if you haven't seen us youll hear us coming !
Quban.Russian mx73 is offline   Reply With Quote
Old 11-21-2011, 06:12 AM   #10
ST(I)mpreza
ST(I)mpreza's Avatar
ST(I)mpreza is an unknown quantity at this point
pretty clean nice ae, frr BUMP!
ST(I)mpreza is offline   Reply With Quote
Old 11-21-2011, 03:32 PM   #11
qt_240
qt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really nice
What is your asking price?
Dorimonster.blogspot.com
qt_240 is offline   Reply With Quote
Old 11-21-2011, 04:28 PM   #12
PhatSheep
PhatSheep is an unknown quantity at this point
omg so beautiful.... i think i just sharted. soooooo pretty omg.
look at those jdm bumpers and lights..
PhatSheep is offline   Reply With Quote
Old 11-28-2011, 01:40 PM   #13
rongfk
rongfk's Avatar
thanks for the positive comments.
Old 11-28-2011, 02:36 PM   #14
turkey
turkey's Avatar
turkey is an unknown quantity at this point
interested in a clean 4 door lexus Ls400 perfect for your 2 kids let me know 805-757-2579
turkey is offline   Reply With Quote
Old 11-28-2011, 03:01 PM   #15
dirtythirty
dirtythirty is an unknown quantity at this point
trade you for my BMW E36 4dr? let me know if you have any interest.
dirtythirty is offline   Reply With Quote
Old 11-29-2011, 08:39 AM   #16
rongfk
rongfk's Avatar
sorry im stuck on subaru, or possibly a mid sized suv.
Old 11-30-2011, 07:10 PM   #17
Jonathan Rivera
Jonathan Rivera's Avatar
Jonathan Rivera is an unknown quantity at this point
seen this car in person, i see you rebuilt the t25 i traded you for the suede interior on my hatch ,,, DONT SELL IT MAN!
Jonathan Rivera is offline   Reply With Quote
Old 03-23-2012, 03:58 AM   #18
gwmike
gwmike is an unknown quantity at this point
is this car still for sale?
gwmike is offline   Reply With Quote
Old 03-23-2012, 07:40 AM   #19
Eww Evo
Eww Evo's Avatar
Eww Evo is a well-known jackass
Sweet ride!! I would love to trade my 06 WRX for this 86 Glws
Eww Evo is offline   Reply With Quote
Old 03-23-2012, 07:56 AM   #20
Eww Evo
Eww Evo's Avatar
Thinking about it, i really would enjoy having a 86
Old 03-23-2012, 03:32 PM   #21
rongfk
rongfk's Avatar
Eww Evo,
post up some pictures and specs on your car.
since the post ive got some god speed sways, front and rear, adjustible 4-links and panhard bar, megan rca's, adjustible tension rods, adjustible kyb agx front and rear, and a few other things. just need to install it. oh and it still had 0 miles on the car. just started working on it again. lol
Old 03-23-2012, 06:40 PM   #22
gwmike
Trade for a 2001 limited ford explorer? Its a mid size suv haha.
Old 03-24-2012, 01:28 PM   #23
Eg_type_r
Eg_type_r is an unknown quantity at this point
so jelly clean 86
Eg_type_r is offline   Reply With Quote
Old 05-11-2012, 12:46 PM   #24
Stanced
Stanced's Avatar
Stanced is an unknown quantity at this point
still for sale? and would you be willing to ship it? pm if interested
WHAT WHEEL GAP??
Stanced is offline   Reply With Quote
Old 05-11-2012, 01:17 PM   #25
yvang07
yvang07's Avatar
yvang07 is an unknown quantity at this point
seriously clean build and quality car OP, personally I'd take that mofo to the grave with me lol, hope you find what you're looking for and again, awesome ass car.
yvang07 is offline   Reply With Quote
Old 05-14-2012, 10:28 AM   #26
rongfk
rongfk's Avatar
Thanks, since my last response on this thread ive re-upholstered the door panels to match the seats, installed a rare new teq shift knob to match the rare nardi horn button got a custom intake manifold made for it along with a supra throutle body 60mm, a rare ae86 digital cluster setup installed, rare oem ae86 power window switches, mounted the rear bumper, installed and blead the breakes, replaces the a/c face plate with a new oem one, replaced the signal switch, light switch, wiper switch with some oem mint ones, modified and installed a thule roof bike rack. Also planning on installing all the suspension stuff soon, so i can get an alignment done. Bealieve it or not, i have well over 12k invested (stopped keeping track after that much) and just keep investing lol. Parts for these cars arent cheep and in most cases hard to come by. As far as a price, i dont think i would take anything less than 12k, but if you can come close i might consider it. Im sure if i itemize the car and everythin it has, it will come out to more than that.
here are a few pictures:
Old 05-21-2012, 09:18 AM   #27
rongfk
rongfk's Avatar
update: got the engine bay nice and tight with the new custome intake mani with 80mm T/B...
Old 05-21-2012, 10:04 AM   #28
FCricky
FCricky's Avatar
FCricky is an unknown quantity at this point
PM an asking price man i like what im seeing and would like to have it sitting in my drive way already
FCricky is offline   Reply With Quote
Old 05-21-2012, 12:54 PM   #29
Pendulum
Pendulum is an unknown quantity at this point
Does A/C work?
Pendulum is offline   Reply With Quote
Old 05-21-2012, 01:11 PM   #30
rongfk
rongfk's Avatar
Sorry no a/c, just have to roll the power windows down.
