Old 11-22-2011, 02:08 AM   #1
colombianbryan
colombianbryan's Avatar
colombianbryan is an unknown quantity at this point
Need help please! Urgent!!!
Ok now from the beginning. My car was running perfectly fine before i did anything. i have a zenki 240 with an s14 sr20det blacktop. i decided to upgrade my injectors to 480cc oem s15 injectors. installation was easy but when i turned on my car is idled like shit. gave it time but nothing so im guessing i need a tune. i decided to go back to the 370cc oem injectors and now it wont start... the fuel pump turns on and all the fuses and grounds are fine. it sounds like it wants to start but nothing. it turns over but wont crank. Please help!!!!!
I love drifting into curbs and guardrails
colombianbryan is offline   Reply With Quote
Old 11-22-2011, 02:48 AM   #2
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
explain 'sounds like it wants to start', aka, the starter works fine, fuel pump primes, but nothing else? try priming the fuel pump a couple times, aka, turn key part way on, then off, then try starting.
...you could 'floor it' and just let it keep turning over till it catches.
btw, you can't just throw larger injectors and have it work. I highly recommend people get wide-band, and standalone if they can afford it. Anything less is really a band-aid.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 11-22-2011, 07:40 AM   #3
colombianbryan
yea i realized that the hard way haha but i've tried that and nothing! and what i mean is that the starter is good and the engine i turning over and if i hold it it would sound like it cranks and than dies but that barely even lasts a second.. any other advice?
Old 11-22-2011, 08:36 AM   #4
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Its flooded. Pull out the spark plug, disconnect the injectors and crank it
R@ddy is offline   Reply With Quote
Old 11-22-2011, 08:41 AM   #5
colombianbryan
so am i supposed to start it with no spark plugs or injectors in?
Old 11-22-2011, 08:56 AM   #6
colombianbryan
also do i take out the actual spark plug or just the plug?? and do i crank it on while its all of??
Old 11-22-2011, 09:06 AM   #7
R@ddy
Trader Rating: (32)
Just to "un-flood" your engine. Go back to 370cc until you get a tune
Old 11-22-2011, 09:16 AM   #8
colombianbryan
yea im doing that now. but its kind of a pain in the ass to remove injectors from an s14. i have to take out the plenum. so could i be able to only take out the spark plugs and fuel pump fuse to drain it out?
Old 11-22-2011, 11:05 AM   #9
colombianbryan
i did it and its started to shoot out fuel from the fuel rail. should i disconnect the fuel pump fuse?
Old 11-22-2011, 11:31 AM   #10
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
you do not take the injectors out!!! you unplug the elecrical connector so they do not squirt. you also take all of the spark plugs completelly out to vent the fuel out of the cylinders when you crank it.
one thing alot of people dont seem to know is that if you take out the spark plugs and un plug the Cam Angle Sensor the fuel injectors will not squirt and the coils will not try to fire. you can clear the cylinders this way.
the whole point of what you are trying to do is to get all of the excess fuel that is puddled up in the cylinders out so that the engine will fire up.
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 11-22-2011, 11:43 AM   #11
landins13
landins13's Avatar
btw this should have taught you something very important.
NO HANDS IN PANTS!!
Old 11-22-2011, 11:57 AM   #12
colombianbryan
yea i know but i wanted to do a little upgrade. i was being careless and forgetting that i need a tune to do this.. but i took out the spark plugs off and the injectors already so i was cranking it and watching gas just shoot out the cylinders. so now im waiting a couple hours until everything is completely drained out! my biggest concern is if i should have the fuel pump fuse in or out while doing this..???
Old 11-22-2011, 12:32 PM   #13
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
omfg this is about the same thing i just posted on that other thread for.. in order to un-flood your motor unplug the injectors, crank it till it catches, plug them back in and start the car. its not that hard, you don't need to pull the spark plugs out or anything either.
pacotaco345 is offline   Reply With Quote
Old 11-22-2011, 12:41 PM   #14
colombianbryan
well i cant try anything now im not around my car. but you are the only one that says i can leave the spark plugs in...
Old 11-22-2011, 01:01 PM   #15
Darren
Darren's Avatar
Darren is an unknown quantity at this point
well, the gas needs to be removed from the cylnders, so yeah, you should have a heat source, the motor will just run itself out of fuel and then you can plug in your injectors and you should be able to start it without problem...
Darren is offline   Reply With Quote
Old 11-22-2011, 01:04 PM   #16
Frankz91
Frankz91's Avatar
Frankz91 is an unknown quantity at this point
HELP
I just dropped my 240 on Eibach Springs 2 in drop
idk wat should i get camber kit or wat
Frankz91 is offline   Reply With Quote
Old 11-22-2011, 01:08 PM   #17
steve shadows
steve shadows's Avatar
Just take out the spark plugs and unplug the injectors then crank the motor to dry out...sounds like you may have mis-used or re-used the bad or previous injector o rings, or they werent put in right maybe...If you need a base map for the 850s let me know also. Hopefully works out
Like Me on FaceBook !
Old 11-22-2011, 01:22 PM   #18
colombianbryan
yea i have taken out the the injectors and spark plugs. i also got new o-rings so i plan to replace them all tonight and hopefully drive my car again.
