WOW addicted
![]() Join Date: Dec 2001
for reference, My engine tested with 165psi +/-1psi accross the board, and had 3% leakdown. I've got a 110K miles, and plan to turbo mine. An accountant owned it before me that didn't even know it was RWD, and drove it for 90,000 miles!
#5 | |
![]() Join Date: Nov 2003
#7 | |
WOW addicted
Yeah, just do a good check out of the motor. If you do go through with it, you might consider doing a solid tune up on it. new gaskets all the way around.
My turbo SOHC has 145k+ i run 5 psi daily, turn it to 8 once and a while. Just change your oil often/check often and it should be set. Make sure you get a good dyno tune also.
-John
SOHC KAT, 6 psi... |
![]() Join Date: Dec 2002
DO IT. You'll never go back. Be sure to have an extra 5 or 6 bills in case the motor DOES decide to go.
BETTER YET, Get another KA and build the bottom end and wait for the motor to go.
![]() Join Date: Jan 2003
Deffinitly get another motor just incase the other ones goes. Mine went with only 74k on it. You can find another engine for quite cheap, usually around 150 if you look for a while.
96' SE Turbo'd Super 60, S-AFC, SMIC, 370cc Injectors, Open Air BOV, Warblo 255 pump, Stage 3 Clutch Kyb agx, Sportline Springs Full body kit, Bomex rear, Drift sides, r34 front gunmetal rims, yok tires |
![]() Join Date: Sep 2003
got mine with 132K on it still on the original clutch. previous owner didnt know the difference between it and an altima except this had 2 less doors.
Hi |
