Old 12-21-2011, 05:21 PM   #1
EnemyS15
EnemyS15 is an unknown quantity at this point
Sr starting problems
Motor - s14 blacktop
Car - Zenki Se
Problem - Turn the key to start the car and car doesn't start. Electric fans turn on, all electrical components turn on, when I turn the key over the car doesn't turn over and the electrical components briefly turn off and then back on. All I hear is a clicking sound from the starter relay switch by the fuses. I hook the battery up to a battery charger for a bit, nothing works.
Ive checked:
fuses
grounds
relays
battery
I am pretty sure it is the starter, but wanna get a second opinion before I go take it out.
Thanks for any help
EnemyS15 is offline   Reply With Quote
Old 12-21-2011, 06:38 PM   #2
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
Try jumping the starter manually. Can you pop the clutch to get the car running?
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 12-21-2011, 08:00 PM   #3
EnemyS15
yeah i popped the clutch and it started...
Old 12-22-2011, 08:52 PM   #4
EvoVIII808
sounds like starter to me..
Old 12-22-2011, 09:26 PM   #5
project_silvia
project_silvia is an unknown quantity at this point
starter for sure lol its an easy install i just did mine
project_silvia is offline   Reply With Quote
Old 12-23-2011, 06:10 PM   #6
EvoVIII808
i might need to get one also.. Where did you get it from?
Old 12-23-2011, 06:58 PM   #7
EnemyS15
For sale section. Had around 12 offers within the day. all reasonably priced.
Old 12-23-2011, 09:28 PM   #8
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
you can do a starter swap if you are on a budget sohc/dohc starter + sr20
Old 12-23-2011, 09:39 PM   #9
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
no, 1st check your ignition, if not, try checking your ground.
I've been having the same issue for 2 years and using my remote start to start the car. I'm on my third starter now. I've not have time to chase the problem. I heard Nissan ignition could lead to this problem.
Hope you can find this out.
Btw, I'm using Mishimoto starter. They offer lifetime warranty, definitely nothing can't beat it!
dongoesby is offline   Reply With Quote
Old 02-19-2012, 11:43 AM   #10
jdunkz
jdunkz is an unknown quantity at this point
Clean your battery posts then tighten them down good. Check all your connections between starter and battery, Alot of times it's just a loose connection that seems like it would be tight enough. Try jumping your starter with jumper cables if it cranks your starter is fine its just not getting the amperage needed to crank it
jdunkz is offline   Reply With Quote
Old 02-20-2012, 06:13 PM   #11
EnemyS15
It was the starter...
Old 02-20-2012, 07:00 PM   #12
cbcm2435
cbcm2435's Avatar
cbcm2435 is an unknown quantity at this point
was it the brushes? because i thought mine was bad before and the connection between the solenoid and the starter motor was all corroded, cleaned it up and it works great
cbcm2435 is offline   Reply With Quote
Old 02-21-2012, 05:57 AM   #13
EnemyS15
My starter selenoid went bad. Replaced it with a ka one and it worked fine
Old 02-21-2012, 06:14 PM   #14
cam3ron4
cam3ron4 is an unknown quantity at this point
Is the think in the starter turning
cam3ron4 is offline   Reply With Quote
