Old 12-22-2011, 09:59 PM   #1
OoAtreyuloO
OoAtreyuloO's Avatar
OoAtreyuloO is an unknown quantity at this point
s13 Starter and alternator Draining batt.
Ok so im stumped and I have checked all previous possibilities.
Like the title states the Starter, alternator, battery fuses (kick panel) , and fuses in the main fuse box. all show on with a tester when the car is off.
This started happening all of a sudden.
Ive checked the ECU by disconnecting it and it still stayed on.
so than i removed my my ignition switch and it still stayed on....
cars stock i have no clue what it could be.
New ground cable and alternator and starter and batt.
some one shed some light im tired of disconnecting the batt.
OoAtreyuloO is offline   Reply With Quote
Old 12-22-2011, 10:20 PM   #2
Sileighty_85
Sileighty_85's Avatar
So Your getting 12V at the big wires on the alt and battery? .....Thats normal
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-22-2011, 10:25 PM   #3
OoAtreyuloO
12v while the car is off is normal?
Old 12-22-2011, 10:31 PM   #4
Sileighty_85
youp those wires are connected directly to the battery
後輪駆動車1番
1986 SR86 - 200ish
Old 12-22-2011, 10:34 PM   #5
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
around 12V while its off is normal.
Check grounds?
Fuck electricity.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 12-23-2011, 10:53 AM   #6
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
so is it actually draining the battery? if you have a drain, do a parasitic drain test. hook up your voltmeter test leads according to the manufacturer`s manual and then start pulling fuses one by one until the drain goes down or completely gone. if you pull the radio fuse out and the drain goes down, the drain is somewhere in that circuit. but on the older cars, a few circuit uses the same fuse. so it might not just be the radio. you have to look on the FSM and see what circuits use what fuses. also, a little drain is normal due to clock, radio memory, etc. but if you have more than .035 amp, something is staying on. newer cars can draw twice as much as that due to all kinds of computers in them. good luck.
rcdad123 is offline   Reply With Quote
Old 12-23-2011, 11:38 AM   #7
OoAtreyuloO
Thanx ill recheck it today ... I just gad the impression,that all components turned off when a car is switched off
