Old 12-29-2011, 03:17 PM   #1
Silvi
Silvi is an unknown quantity at this point
SR20DET - GT2876R vs GT2871R
Hi,
are the difference between 2876.86 and 2871.64 are really so serious?
I need boost from low as possible RPM(Drifting)
Thanks
Silvi is offline   Reply With Quote
Old 12-29-2011, 03:34 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Personally, I'd go with the 2871 .86. This coming from somebody who started on as 2871R .64 and last setup was a super laggy 3582R. Nothing that clutch kicking the car wont fix if you feel it lag coming into a turn.
CLICK HERE!!!
Old 12-29-2011, 03:36 PM   #3
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
.64 for bottom end power .86 for top end.
As far as between the two turbos, 2871.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 12-29-2011, 03:41 PM   #4
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
I would recomend a s15 spec r honestly, its super responsive and still good for 280-300whp
I have the 2871 .64, still responsive, i think it hits full boost (20psi) around 3600-3750
but i dont drift
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 12-30-2011, 12:15 AM   #5
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
The turbine is the limiting factor on the 2871 anyways, so adding a larger compressor (2876) is counter productive.
4x4le is offline   Reply With Quote
Old 12-30-2011, 07:49 AM   #6
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
2876 is too laggy as has been said above. Go with either a 2871 or go to a top feed GT3071R with external 44mm wastegate if you want response and more power than a 2871 can deliver
Seraphim38 is offline   Reply With Quote
Old 12-31-2011, 02:11 AM   #7
fliprayzin240sx
Only catch with a 3071R setup, start buying up spare trannies...SR trannies start showing they're made out of glass with 3071 setup since you're pushing over 400hp.
CLICK HERE!!!
Old 12-31-2011, 09:25 AM   #8
cotbu
cotbu's Avatar
I had the 2876 turbo and I didn't mind the lag, but on my setup it was violent, on off switch type of power, seriously violent. I probably could have tuned it, but I didn't like the feeling at all. It was ebay turbo housings with garret 2540 center. I hate that turbo and don't miss it. sold it for a stack!
Old 03-30-2012, 01:12 AM   #9
Silvi
Bump with new question
I hit 0.5 bar at 3500 RPM and full boost 1.5 bar at about 4500 with 2876 .86.
I found a Rear AR .64 For the 2876-
What will be the difference with 2876.64 campared the 2871.64?
It will be easier and cheaper to change only the AR instead looking for new turbo.
So your opinion is important before purchasing one of them:P
Thanks!
Old 03-30-2012, 03:43 PM   #10
TFD
TFD is an unknown quantity at this point
Fullboost difference with the 2871 turbo is about 500 rpm (.64 = 3700 rpm, .86 = 4200 rpm)
Would be simular difference for the 2876 I reckon.
JDMstyle-Driftstyle-Dish-Stickerbomb-Stretch-Bye Bye Kitty...
TFD is offline   Reply With Quote
Old 03-30-2012, 04:07 PM   #11
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
My 2876 .64 makes full boost (14psi) at around 3800-4k.
Old 04-02-2012, 03:35 PM   #12
Silvi
so i guess with 22 psi it will be the same?(4500 rpm at full boost)
22 psi at 3700 sounds great!
Old 04-04-2012, 09:42 PM   #13
fliprayzin240sx
Who tuned it? It can be tuned to hit boost sooner but you'll lose some top end power. Thats what happened with my GT3581, it was an on/off switch with the first tune I had. Had somebody else retune the car to build up spool sooner and it made some difference as far as response.
CLICK HERE!!!
Old 04-04-2012, 11:14 PM   #14
usdm180sx
usdm180sx's Avatar
HKS GT-RS if you can afford it =)
-Norm!
Old 04-05-2012, 07:30 PM   #15
4x4le
4x4le's Avatar
I know electronically you can tune to make it spool faster but doing that shouldnt make you loose any top end at all.
Did you play with the cam gears? That can cause the powerband to shift.
Old 04-05-2012, 07:59 PM   #16
Silvi
I dont really care about high end - Im looking for faster spool.
I have the original S15 cams.
What will be the real difference between GT2871.64 and 2876.64?
Is it worth to buy an 2871.64 instead of 76 if it much earlier spool?
Old 04-05-2012, 08:09 PM   #17
4x4le
4x4le's Avatar
the 2876 is a waste of a turbo. The demise of the 2871 is the 28 turbine, with the 30 turbine the 71 compressor 3071 makes more power. Using a bigger compressor on the smaller turbine dont make much sense
Old 04-05-2012, 08:21 PM   #18
cotbu
cotbu's Avatar
I agree!!!!!!!
