Old 12-30-2011, 12:42 PM   #1
nissan240syan
nissan240syan's Avatar
nissan240syan can only hope to improve
Where does this hook up ?????
So after searching for weeks where this damn clip goes ive decided im blind and retarded and need your help zilvia ! There are four wires coming from the lower harness and alternator so it has to do something with the charge because my alternator is in great shape and works but doesnt do its job due to this wiring. Heres 2 pics of the wires and clip if anyone knows where it connects please let me know ! or since the wiring is somewhat sloppy it may be completly done wrong and there shouldnt be this connector. I bought the car swapped and im trying to clean it up a bit. ANY Advice is much appreciated. RED TOP SR20
nissan240syan is offline   Reply With Quote
Old 12-30-2011, 01:02 PM   #2
DinoMan
DinoMan is an unknown quantity at this point
Looks and sounds like maybe it goes to your fusebox. S13 or s14? sr im assuming?
DinoMan is offline   Reply With Quote
Old 12-30-2011, 05:51 PM   #3
nissan240syan
yea its a redtop sr in a s13 hatch. I dont think i have any connections like that in the fuse box though just fuses
Old 12-30-2011, 06:27 PM   #4
EnemyS15
EnemyS15 is an unknown quantity at this point
My guess = Looks like the connector/plug that goes into the alt.
Survey sayssssssss??????
EnemyS15 is offline   Reply With Quote
Old 12-30-2011, 07:01 PM   #5
two40silvia
two40silvia is an unknown quantity at this point
it's definitely not for the alternator. it looks like one of the transmission sensors plugs.
two40silvia is offline   Reply With Quote
Old 12-30-2011, 07:06 PM   #6
Sileighty_85
Sileighty_85's Avatar
That white/Red Stripe wire is the Alt Charge light wire.
If that one is not connected the Alt will not charge
Does your speedo work as well? Those look like the Speedo wires as well
was your chassis a Auto? If so you need to convert the auto harness
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-30-2011, 07:12 PM   #7
DinoMan
My bad i meant underneath your fusebox. Make sure its not one of the plugs underneath that plug into the box itself.
Old 12-30-2011, 07:15 PM   #8
Gold Zenki
Gold Zenki is an unknown quantity at this point
possibly one of the ones to the tranny harness mentioned above
Gold Zenki is offline   Reply With Quote
Old 12-30-2011, 07:16 PM   #9
nissan240syan
definetly not the alternator plug i have that hooked up forsure. My speedometer and tach both work. I bought the car swapped with this wiring mess even though it runs fine just doesnt charge the battery so it eats through them. Looks like the car is original 5 speed too.
Old 12-30-2011, 08:07 PM   #10
Sileighty_85
Dude Thats the plug for your Alt Warning and Speedo and Oil Pressure Switch.
Your Wiring is just really fucked up
They probably wired the speedo at the first plug comming off the speedo
後輪駆動車1番
1986 SR86 - 200ish
Old 12-30-2011, 09:48 PM   #11
nissan240syan
I just cant figure out where the damn white and red should connect so the alternator does its work. It definetly doesnt belong in that shit that connects to nowhere ? I fucking hate wires !!!!
Old 12-30-2011, 09:50 PM   #12
Sileighty_85
The FSM shows you where it connects to, but the plug will connect to around the fuse box on the passenger side strut tower
後輪駆動車1番
1986 SR86 - 200ish
Old 12-30-2011, 10:08 PM   #13
nissan240syan
Ill give it a shot tomorrow when its light. Much thanks for the help !
