Old 01-10-2012, 06:22 PM   #1
mgnfcnt978
mgnfcnt978 is an unknown quantity at this point
Dif fan controller problem
So I have looked through mulitple thereads around here still cannot find the answer. I have a DIF fan controller with 2 flexalite fans on my sr20. Yesterday my fan#1 decided not to shut off at all. Usually it shuts off roghly 20 sec after the car is off. I have looked through the wiring and checked all the groudns and power and wiring to the temp sensor. Everything is absolutely normal. It worked with no issues for a year and a half before this incident. Any suggestions what can it be? If i pull the fuse out on the power wire fan shuts off but if i try to put it in it comes on? What are the settings you guys run your controllers usually and what can triger the problem?
mgnfcnt978 is offline   Reply With Quote
Old 01-10-2012, 06:42 PM   #2
Sileighty_85
Sileighty_85's Avatar
The FAL's pull too much Amperage for the Version D Controller so Its melting the Relays inside causing them to stay on.
You need to upgrade to the DIF PWM controller since Its reated at 60 amps
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-10-2012, 08:03 PM   #3
Boost_Fiend
Boost_Fiend is an unknown quantity at this point
^^ same thing happened to mine. biggest waste of $70 or however much it was.
Boost_Fiend is offline   Reply With Quote
Old 01-10-2012, 08:13 PM   #4
mgnfcnt978
sounds like it might be the answer i dont have fals though but it is weird they worked absolutely fine for over a year whats the the best setting i should set for fan 2 at least temporarily while ill work something out for a solution
Old 01-10-2012, 08:16 PM   #5
mgnfcnt978
btw when i took mine apart nothing looked to be melted
Old 01-10-2012, 08:18 PM   #6
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
this is all you need to have a electric fan working properly without crap electronic components that take up too much space and end up failing.
SPAL USA
very simple installation, and works without fail. like a OEM setup. if you feel you MUST have control you can even add a switch so you can turn the fans on manually.
rebornS14 is offline   Reply With Quote
Old 01-10-2012, 08:49 PM   #7
Sileighty_85
How does that work?
後輪駆動車1番
1986 SR86 - 200ish
Old 01-10-2012, 08:57 PM   #8
mgnfcnt978
My bad i thought fal as a brand of fans or whatever it is
I have these with a dif controller
Old 01-10-2012, 09:02 PM   #9
Sileighty_85
gotcha, Bur yeah like I said, they pull too much. Version D is rated at 25Amps and FAL's pull like 28Amps.
Its not much over it so I will slowly kill it depending on how long the Fans Cycle
a buddy of mine that had the same issue.
I then bought this one and havent had an issue since
http://www.frsport.com/DIF-10005-The...r_p_10337.html
後輪駆動車1番
1986 SR86 - 200ish
Old 01-11-2012, 05:10 AM   #10
bb4_96
bb4_96 is an unknown quantity at this point
SPAL USA
The reference data in that link is the shit! Buy a couple relays and make your own multiple fan kit for ~$20
bb4_96 is offline   Reply With Quote
Old 01-11-2012, 11:19 AM   #11
rebornS14
rebornS14's Avatar
yeah thats what i did. i have a bunch of relays at my work. i didnt even know they made harness kits until i needed to make another of the same setup and was on that website to buy another sensor.
Old 01-11-2012, 11:56 AM   #12
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
http://zilvia.net/f/chat/258542-mish...ml#post4093049
mattack69 is offline   Reply With Quote
Old 01-11-2012, 03:18 PM   #13
Chaluska
id never go with any trashy mishitmoto fans,
if im going with an electric fan, i only stick with OEM.. Altima/maxima/taurus fan..
mishitmoto / fal / isis do not pull enough air to accurately keep the engine cool in the long run
Old 01-11-2012, 05:23 PM   #14
Sileighty_85
FAL's Pull enough air to keep my RB25 cool
後輪駆動車1番
1986 SR86 - 200ish
Old 03-12-2012, 04:52 AM   #15
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
I know this thread is over 2-months old but my questions pertains exactly to this and figured I'd just bump the one already made.
I was wondering if you can mod/replace the 12A Relay in the DiF Ver.D Controller with something bigger like 20+A's.
Like say having Wires with pins or probes in the original 12A Relay sockets and run them External to run a 20+ Relay? Or is it possible to find the same style relay in a 20+? Would the PCB/Socket it's self be able to handle the higher current.
Just a though as I already have FAL's (Not installed, waiting to go in) and I wanna wire it with a Controller and I have found a DiF Ver.D for cheap.
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 03-12-2012, 08:43 AM   #16
Sileighty_85
You can run external relays and have the DIF controller trigger the External Relays on and off
後輪駆動車1番
1986 SR86 - 200ish
Old 03-12-2012, 08:46 AM   #17
Chaluska
My setup...
the dif is turning on the 30 amp relays, which are fused.. it has been bulletproof for the last 6 months, and is going to get re-wired, and used in my VH swap
