Old 01-11-2012, 04:09 AM   #1
240sxdriftin
Trader Rating: (25)
240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of
Feedback Score: 25 reviews
Pro-Am S13 Coupe from Dayton build
Well I'm awfully bored at work, and I figured I'd share the build on my 240sx over the last year and season of drifting in the 2011 Midwest Drift Union FD Pro-Am series... And also begin the build for the 2012 season.
So the chassis is a 93 coupe, very rust free from Georgia. Sunroof-less and no power options. I picked up as pretty much a bare shell in rough shape from someone who didn't really know what they were doing.
The full list of end modifications on this car ended up being this..
Engine:
SR20 Redtop motor
S15 dual BB turbo
Deatchwerks 550cc injectors
Z32 maf
Hybrid Dynamics ROM tuned ecu
Apexi intake
Koyo Radiator
Samco hoses
PBM Highmount intercooler
Walbro 255 fuel pump
Tomei turbo elbow
Greddy downpipe
ISIS 4in dual tip catback
Circuit sports stainless turbo lines
Dual electric fans
ACT 6 puck clutch
TODA racing lightweight flywheel
Suspension/ Chassis:
Custom 6pt roll cage FD spec
Fortune Auto 500 coilovers
Fortune Auto tension rods
SPL parts toe, RUCA, and traction rods
SPL parts solid subframe bushings
Solid engine and trans mounts
Energy suspension bushing kit
Tein inner/outer tie rods with spacer
S14 front suspension and 5 lugs all around
Interior:
2 Bride vios III knock offs
2 Takata harnesses
Nagisa rails
NRG deep suede wheel/ thin hub/ QR
Prosport 60mm gauges boost/oil press/water temp
Greddy profec b spec 2
kept the dash/ carpet and door panels in
exterior:
BN type 2 knock off front bumper and sides
Uras style rear bumper
Uras GT WING
Origin 40mm front fenders
Origin 50mm rear overs
Knock off roof wing
H4 lights with 16000k pink HID's
Teal green metallic paint
Origin smoked tails
ebay ganador style mirros
Brakes/ wheels:
Z32 front brake conversion
Circuit sports drilled/slotted rotors
Hawk HPS pads all around
Agency power lines all around
Racing Logic Hydraulic E-brake
18x10/ 18x11.5 Work Emitz
18x10 FR500's
18x10.5 RPF1's
18x10.5 Varrstoens
I think that covers all the bases of what was done to this car. So here we go build time woooo...
Picked the car up in March, and took it straight to getting caged.
First picture of the car, as I began stripping it out to get prepared for the cage, at this point it still has the previous owners 5 lug on it, that goes away soon.
Car totally stripped out and ready for cage fitting. Good Friend of mine did this cage, I helped a little bit.
At the end of the day looking very haggard.
Started Collecting some parts...
More cage stuff.
New subframe ready to go in.
Test fitting seat before finishing cage
Put a better front crossmember in than the busted up one that came with the car. along with the steering rack bushings.
Then the cage was finished so I took the car back to my garage and got to work on other fun things.
Like re cutting the awful cut fenders
Testing the overs and painting the cage.
Chopped up the front to fit the PBM Highmount
Tossed the motor in
Cut up the dashboard and shoved it in
Mounted the Hydro
Put some more of the motor together
Z brakes, extended studs, fortune auto parts
Put my door panels in with a little bit of dremel trimming
Mounted a fender and the 326 power wing so I could see it all together for once
These tips are large!
Test fitted one of the emitz.
I failed at taking pictures of all the rear suspension and links cause it was all boring and black. So I got tires mounted... 235/40 on an 11.5 lol...
Had to grind nissan off the calipers to fit the wheels, even with a 12mm spacer
Then Got everything buttoned up and lowered it onto 4 wheels for pretty much the first time ever... for me. Things fell right into place.
The next day rolled it out into the sunlight to stare at.
The interior all buttoned up and finished
Then took the car to the alignment shop... horrible specs -6 camber front and -5... that was when I knew the emitz had to go soon. But not yet!
IG: @bwagg88
240sxdriftin is offline   Reply With Quote
Old 01-11-2012, 04:10 AM   #2
240sxdriftin
Trader Rating: (25)
Drove it out to a car meet for the first time
Getting ready to go out for the first event up in clio michigan at round 2 for MDU.
This is now may 14th, I got the car beginning of March...
At the first event up in Clio Michigan. It was a bad day for drifting, The morning started off with pooring rain and 40's with lots of wind. So getting soaked and freezing while getting the cars ready and teched. It ended up stopping raining just before my run group, and then dried off later in the day but was still cold and windy.
Had some fun when we got home
Got back from the event and went back to work on the car, getting the headlights mounted and then the bumper fitted. after testing the bumper, I new I needed a good bracket to make it look right.
After seeing it all together I figured I needed to paint it all one color, so it was time for some primer. Again I slacked with taking pictures of prep and all that but here it is in primer.
About a week of driving around like that and I was over it and ready to get it all one color!! So I took it all apart and proceeded to do just that! First time spraying base/clear..
And then... PAINT!!!
Took it home asap to put it all together and stare at it with the emitz on it haha...
Got tired of that saggy bumper now that the car was painted...
IG: @bwagg88
Old 01-11-2012, 04:11 AM   #3
240sxdriftin
Trader Rating: (25)
So Then it was off to the next round of MDU along with a small parking lot event the day before... Not many pictures at this event my photographer wasn't able to make it.
After that event on a fast track, I realized it was time for the Emitz to go and for some lightweight reasonable sized wheels to come into my life before the next event. This is when my pictures get really off. I bought a set of 18x10.5 rpf1s and a set of 18x10.5 varrstoens, painted them all hot pink and stickered up the car to get ready for round 4 MDU in Nashville tn at an amazing track and facility
Home from that event.. Bought a new house... Moved the car in
Bought a Uras GT wing...
More stickers, and drove Street Life Tour... Barely any pictures of that but car looked dumb at that event anyways...
Went and drove another parking lot event in indy..
And then that was all the events for the season.. Drove the car around a little...
Then the last thing I did before tearing it down was lower it a bunch haha...
And thats the last it looked like before going into the garage to go under the knife again... Its currently torn back down. Getting a new engine power plant with 400 na whp... Front tubs, knuckles, Interior fully paint matched along with front end and engine bay, hood vent, and a matching BN rear bumper. Then most likely a vinyl wrap. But all my money is going towards this new engine setup...
I Just really enjoyed last season and had a lot of fun, and wanted to share it with you all.
Stay tuned I will start updating this thread with new stuff on the car as it starts happening this winter preparing for 2012 drift season.
-Thanks!!
IG: @bwagg88
Old 01-11-2012, 04:33 AM   #4
Strizi
Strizi is an unknown quantity at this point
Nice Car man
Strizi is offline   Reply With Quote
Old 01-11-2012, 04:39 AM   #5
Landberg
Landberg is an unknown quantity at this point
Other than that it needs its 326 wing back on it's just awesome!
What color is that?
landberk at wordpress
Landberg is offline   Reply With Quote
Old 01-11-2012, 05:34 AM   #6
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
nice man super nice...
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 01-11-2012, 07:21 AM   #7
7evil
7evil's Avatar
7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough
extra cool Nissan!
七転び八起き
7evil is offline   Reply With Quote
Old 01-11-2012, 07:47 AM   #8
hammy
hammy is an unknown quantity at this point
Love the color scheme! good work
hammy is offline   Reply With Quote
Old 01-11-2012, 08:22 AM   #9
txrxs
txrxs's Avatar
txrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfection
Guess you win this one bwag.
DRIFTINDY
txrxs is offline   Reply With Quote
Old 01-11-2012, 08:50 AM   #10
alexanderig
alexanderig is an unknown quantity at this point
always admired your car nice build. and im guessing 400whp na will be a ls? if so congrats and thats going to be sick
alexanderig is offline   Reply With Quote
Old 01-11-2012, 09:13 AM   #11
Darren
Darren's Avatar
Darren is an unknown quantity at this point
What color is that?
I agree totally with this, looked amazing!
Darren is offline   Reply With Quote
Old 01-11-2012, 09:30 AM   #12
OBEEWON
OBEEWON's Avatar
You build good cars boss.
I gotta say getting rid of the Emitz made me real sad.
Old 01-11-2012, 09:41 AM   #13
RHDphil
RHDphil is an unknown quantity at this point
sweet build
RHDphil is offline   Reply With Quote
Old 01-11-2012, 11:17 AM   #14
d-man478
d-man478 is an unknown quantity at this point
sick build. it is very similar to my pro-am build, which gives me a lot of inspiration. Can't wait to see what you have in store this year!
d-man478 is offline   Reply With Quote
Old 01-11-2012, 11:17 AM   #15
tricky_ab
tricky_ab's Avatar
I like what you've done! It's just the pick me up I needed...I'm sick as a dog, stuck at work.
Old 01-11-2012, 11:36 AM   #16
nathanong87
nathanong87's Avatar
best move was selling the emitz
natelife.tumblr.com
Old 01-11-2012, 11:37 AM   #17
vhamey
vhamey is an unknown quantity at this point
Nice car! How did the paint go for you? Considering trying to paint my S13.
vhamey is offline   Reply With Quote
Old 01-11-2012, 11:54 AM   #18
towlie
Nice dude.
Old 01-11-2012, 03:11 PM   #19
240sxdriftin
Trader Rating: (25)
Thanks for all the positive comments guys, means a lot to me!!
The paint color is a teal green metallic from paintforcars.com nothing fancy. Painting it actually went a lot easier than I had thought, it's not perfect but its a track car so its good enough.
Lots of work in store still for the 2012 season, working on getting my two tone coupe finished first then I'll be focused back on this car again.
IG: @bwagg88
Old 01-11-2012, 03:22 PM   #20
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
What color is that?
I'm looking forward to see what you have in store for it next!
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 01-11-2012, 03:25 PM   #21
240sxdriftin
Trader Rating: (25)
I know I should have kept it
IG: @bwagg88
Old 01-11-2012, 03:38 PM   #22
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
Looking good
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 01-11-2012, 03:54 PM   #23
silviasteve
silviasteve's Avatar
silviasteve is an unknown quantity at this point
So solid. I wanna shoot some photos of this thing when its back up and running!
silviasteve is offline   Reply With Quote
Old 01-11-2012, 04:04 PM   #24
jubee
jubee is an unknown quantity at this point
glad you ditched the wing, mad the car look 100x's better.
keep up the good work
jubee is offline   Reply With Quote
Old 01-18-2012, 03:40 AM   #25
240sxdriftin
Trader Rating: (25)
Thanks dooods
sad to see it sitting out in the snow
Its gotta sit outside while I finish this two tone thing...
soon as I sell my WRX lots of things will be happening... needs to be soon...
IG: @bwagg88
Old 01-18-2012, 03:35 PM   #26
fallen_51
fallen_51's Avatar
fallen_51 is an unknown quantity at this point
Makes me proud to be from dayton !!!! Keep up the awesomeness !!!
fallen_51 is offline   Reply With Quote
Old 01-19-2012, 09:35 AM   #27
Johnny_K
Johnny_K is an unknown quantity at this point
Very nice, im building something similiar for the 2012 drift season and plan on drifting in some of the MDU events.
Question on the hydro setup.
1 - Did you find where the rear brake line ran into the brake master cylinder
2 - unscrew that line
3 - run a stainless steel line from one of the hydro ebrake fitting to the master cylinder where you unscrewed the rear brake line from
4 - then run another stainless line from the other fitting of the hydro to the line that your removed from the brake master?
Hope that made sense.
Johnny_K is offline   Reply With Quote
Old 01-19-2012, 10:57 AM   #28
sterlinge
sterlinge's Avatar
sterlinge is an unknown quantity at this point
Nice car looked Badass with the emitz. What is your new alignment specs?
sterlinge is offline   Reply With Quote
Old 01-19-2012, 11:28 AM   #29
BHG
BHG is an unknown quantity at this point
Does it make me a ricer for liking the car more unpainted?
This car is sweet man. Make sure to avoid the walls for the love of all the Zilvian's.
Did you sell the Emitz or just put'em in storage?
BHG is offline   Reply With Quote
Old 01-19-2012, 01:47 PM   #30
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
before paint, i thought cool ...after paint, i thought awesome!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
