Old 01-20-2012, 02:42 PM   #1
danman
danman is an unknown quantity at this point
s14 clutch problem help please
I got a 95 stock 240sx. My clutch pedal wont go bak up wen i change gears it would jus stay down any opinions on wats going on???
danman is offline   Reply With Quote
Old 01-20-2012, 02:51 PM   #2
jefferz
jefferz's Avatar
jefferz is an unknown quantity at this point
when it is stuck down is the car still in neutral or does it release the pressure and engage if not?
if you push it and it staying engaged check the clutch pedal assembly it might be binding if not replace your slave and master its like $25 bucks total at an auto parts store.
S13 Coupe, S14 Kouki
Crew Chief jeff Jones Racing
jefferz is offline   Reply With Quote
Old 01-20-2012, 06:46 PM   #3
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
i paid 26 bucks for my clutch master cylinder. i don`t know any place that sells slave and master cylinder for 25 bucks. but yeah, check those. if the fluid is really dark or its empty, you`ll need em. also, don`t be surprised if you need both the master and the slave cylinders at the same time.
rcdad123 is offline   Reply With Quote
Old 01-20-2012, 07:14 PM   #4
Tokona-x
Tokona-x's Avatar
Trader Rating: (140)
Tokona-x is an unknown quantity at this point
Feedback Score: 140 reviews
Send a message via Yahoo to Tokona-x
I had a similar problem, I would have to move it back up with my foot lol ... I checked it all out and it was the mc it was leaking past the firewall into the car. I swapped the mc and it fixed my problem. Check your level if it's changing you got a leak
I have five speed bolts if you need any
Custom 2+2 E brake Cable brackets sold here!!!!!
Tokona-x is offline   Reply With Quote
Old 01-20-2012, 08:00 PM   #5
Eramo323
Trader Rating: (22)
Eramo323 is an unknown quantity at this point
Feedback Score: 22 reviews
Send a message via AIM to Eramo323
Remove the clutch damper !
Eramo323 is offline   Reply With Quote
Old 01-28-2012, 05:52 PM   #6
iBlaze240
iBlaze240 is an unknown quantity at this point
Remove the clutch dampener and connect the line from the master straight to the slave cylinder and flush and bleed with new fluid.
iBlaze240 is offline   Reply With Quote
Old 01-28-2012, 06:00 PM   #7
jr_ss
How about we try bleeding the clutch before throwing parts at it? Verify that something is bad, before replacing all of them. Remove the clutch damper and rebleed... Then come back with more information.
Old 01-28-2012, 07:24 PM   #8
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
yeah there is prob air in there if you still have the clutch damper get rid of that shit it loves to just trap air bubbles inside!
s13 @ fullboost is offline   Reply With Quote
