![]() Join Date: Oct 2006
Enkei RPF1 DIY center caps
For those of you with RPF1's you know by now how FUGLY the center caps are. Fake carbon fiber sticker with red writing on it, they're about as attractive as a "Type-HAR" badge if you ask me.
I've been wanting to find another center cap that was about the same size, noticed a lot of Honda guys are running 2003-2006 Accord center caps, that's all well and good but I have a 1997 S14. . . At a friends houes the other day and noticed what he had done for center caps and it's so easy and cheap that I had to share! First, go to Lowe's or Home Depot or any hardware store for that matter, find the electrical section and you'll find these circular metal plugs that are made for plugging electical conduit or electrical boxes. I found them for 0.77 each. First thing I did was scuff up the galvanized coating on them, then sprayed three layers of primer, then three layers of silver gray metallic (I'm sure this paint won't last forever, but this was strictly for testing a color match) I had laying around from a model car I built. The color is pretty close, the only thing I might add will be some Enkei logo's I'll have printed up at a local viynl shop, I think that'll really finish them off! I've attached a pic of them in primer, then painted and installed. Hope you guys find this useful! If you have any questions feel free to PM me. -Matt |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
How do you secure it in place?
powder-coated.com - I do Custom Powder Coating |
cool idea man. ive been trying to figure out what other center caps i could use for my 18x8.5 and 18x10.5 rpf1 since i dont have any on them atm.
i will definitely look into this. them enkei rpfl center caps cost an arm and leg to get. |
Its called a 'Knock-out plug" and they simply have like 8 little teeth on the other side and u can bend them out just a little and they will hold securely to you wheel. I just bought 4 of them for my 17x9.5 MB Battles. And I had to use a 2" knock out plug for them. So thats probably the size that everyone needs.
Yes! They come in several sizes, but 2" is what I used, they have 8 prongs on the back that secure it in place, just bend them out a little bit and they pop right into place.
and are but ugly no less. |
I never had them so not 100% on which year. I do know they fit after a little grinding of the tabs- I tried one on my rpfs at one point; someone was using the xterra caps on their rotas and let me test fit. I was going to do it but since I just got the classics in it's not worth bothering with though!
#15 |
![]() Join Date: Aug 2008
Reminds me of my days at the electrical contractor I used to work for. I would definitely put a logo or something on them since the center of the wheel looks so odd. It's a nice way to cover up the hub seal. Plus, I'm sure you could secure them with a silicone sealant as well as the tabs to keep excess moisture from seeping in.
#19 |
![]() Join Date: Jun 2003
Trader Rating: (130)
useful thread is useful.
if we still had rep, i would give you some OP |
#21 |
![]() Join Date: Nov 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
If this works with my Nismo LMGT4 wheels, I will love you guys long time. Only thing is, my LM's look threaded.
KA-T ![]() |
#22 |
They should still work, not sure what diameter the hole is, but the caps come different sizes, 1", 1.5", and 2" so you should be covered. As far as the centers looking threaded that shouldn't affect anything, it'll give the prongs something to hold on to actually, must make sure to bend them out a little so they stay snug.
#23 |
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
If people want to cover the ac holes on the s14 firewall i was able to fit a 1.5 inch for the bigger hole and i tried using a 1in but it was to small for the other ac hole and the 1 1/4 was to big to fit, by just a bit. I am just going to glue that one on after i remove the prongs
#24 | |
Guest
Posts: n/a
you realize nissan sold a plug for that? |
#27 |
#29 |
Super old thread, but since it is the same subject, I'll post on here instead of making new thread about it.
I have the 18x9.5+15 and 18x10+38 with no spacers on S14. So, I went ahead and ordered this center caps in hopes that it'll fit. http://www.ebay.com/itm/301051102149...84.m1423.l2649 And they do indeed fit very well on the wheel. I was a bit worried about the front because of the spacing of front bearing nut cover and the wheel, but it fits just fine. But I have SBC finish so silver and Honda symbol wasn't fitting right with me. So I went ahead and tried to replicate the so called SBC finish. I sanded the caps down to plastic, sprayed it with silver, than used Duplicolor Shadow effects spray kit. ![]() And well, I have tried this on chrome plastic before I did this, and after it was cured, it turned green, not remembering that I sprayed it anyways. This is how it looked right after I got done with the clear coat. ![]() Looked decent, more like graphite finish than the "black chrome" i was going for. anyways, it turned green when it was cured. it looked too funny on the wheel and I had chrome vinal sheet laying around, intended for model air planes(super thin, strong, and light), and tried to cover the cap with that, but had trouble wrapping it around the sides of the cap. Plan failed, so I will just paint them gloss black with clear coat and put them on the wheel for the mean time. How ever, I am not really digging the idea of plane black, I'd rather have chrome center cap so I went digging for different center caps on ebay and found few that I know will fit the wheel given the measurements were correct off the listings. http://www.ebay.com/itm/181233037778...84.m1423.l2649 ^that took a bit of digging to find with no casting lines from the ridges on the back side.. and also found this one. http://www.ebay.com/itm/181331134022...S:1123&vxp=mtr ^now, I know it says BBS and all that, but I do like the over all shape and finish of the cap, so I sent the seller a msg asking if they sell exact same cap with no logo, if not how the "BBS" logo is put on the cap to see if the logo can be removed with out damaging the polished finish. waiting to hear back from the seller on it. Will update accordingly about the cap logo and when I put the current caps on the wheel after paint.
#30 |
Well, few things happened today. Painted my current existing center caps gloss black using Rusolium.
![]() ^After 3 layers of paint layed on, super glossy! But..we all know what paint lies when it first gets sprayed on. So, this is 3 hours later. ![]() ok, super promising! now, I did get a response back from the seller, super good news. The emblem is just a simple sticker, and the round disc aluminum that's double side taped on. the seller agreed to sell the cap with out the logo applied to the cap. So I'll be ordering this very soon. Keep you all posted.
