Old 04-16-2004, 10:34 PM   #1
turboex
turboex is an unknown quantity at this point
sr20det redtop, slight throttle problem, car bucks
Ok car was fine no probs. SO installed a emanage, and z32 maf, car is still fine. Then i install greddy intake and redo the piping and now the car bucks and jerks at light throttle. I checked the tps. And im not hearing any boost leaks, but at 1000rpm (m new idle speed thanks to this problem) my vac is at 10-15 and not the normal 20. Will just a tiny vac leak cause this much of a problem?? thanks guys, its late im tired hook me up with some help. Tomorrow i may have it figured out but i figured I would ask just incase someone has had this happen to them also.
1992 240sx SE
s13 silvia frontend conversion
SR20DET, custom top mount turbo manifold, Precision SC61 turbo, blitz bov, HKS intercooler, Tial 38mm wastegate, tenzo-r shu-4's, ton of other shit. with clean new paint!
turboex is offline   Reply With Quote
Old 04-16-2004, 10:52 PM   #2
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
Minot ND.......damn that is in the middle of nowhere....
anyway...sounds like a boost leak to me...if you go WOT does you does slightly taper off as the RPMS increase
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 04-16-2004, 10:54 PM   #3
turboex
Yep soon as boost starts it almost goes away. Except when like at 1500rpm under load, then the car cant even gain speed, just sputters untill i down shift.
Oh see tonight in ND it was 50 out so it was cruze night, LOL. But none for me cause my stuffs messed up. then its suposed to snow, LOL.
1992 240sx SE
