Old 01-30-2012, 09:21 PM   #1
gue399108
gue399108 is an unknown quantity at this point
Clutch Pedal
i just bought a 1993 nissan 240sx and i needed a slave cylinder for it so i bought a new one and put it in and bled it and it works but when i press the pedal down it comes up by itself but towards its way up it stops a little after the clutch engages so i have to use my foot to bring the pedal all the way up. Any ideas on what this might be?
gue399108 is offline   Reply With Quote
Old 01-31-2012, 07:14 AM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
need to bleed it some more. get rid of the clutch damper also. it`s the part that is between the slave and the master that is bolted on the floor board.
rcdad123 is offline   Reply With Quote
Old 01-31-2012, 07:49 AM   #3
gue399108
Cool thanks. I'm gunna bleed it and remove that damper. I never knew it had one
Old 01-31-2012, 08:15 AM   #4
andrew600
ill tongue punch her fart box
andrew600's Avatar
andrew600 is an unknown quantity at this point
i would replace the whole line system with a auto to man clutch line. its works great and gives you great peice of mind. way better than multiple connections that will leak at any given moment.
andrew600 is offline   Reply With Quote
Old 01-31-2012, 08:30 AM   #5
s13turbohatch
s13turbohatch's Avatar
s13turbohatch is an unknown quantity at this point
Removing that damper is a great idea, also have you tried adjusting where the clutch engages? It probably needs bled more but adjusting the engagement is like a final touch up.
s13turbohatch is offline   Reply With Quote
Old 01-31-2012, 09:32 AM   #6
Tokona-x
Tokona-x's Avatar
Trader Rating: (140)
Tokona-x is an unknown quantity at this point
Feedback Score: 140 reviews
Send a message via Yahoo to Tokona-x
+1 for removing the clutch damper
I have five speed bolts if you need any
Custom 2+2 E brake Cable brackets sold here!!!!!
Tokona-x is offline   Reply With Quote
Old 01-31-2012, 09:18 PM   #7
gue399108
No i haven't tried to adjust it but im going to bleed it first and then remove the damper and if i feel i need to then ill adjust it. Thanks everyone.
Old 02-01-2012, 06:57 PM   #8
andrew600
andrew600's Avatar
you will need to bleed it again if you bleed it first then remove the damper.
Old 02-01-2012, 08:23 PM   #9
s13turbohatch
Yeah you need to remove it first, and if your car is super low don't just leave it hanging there like i did, i can't reach it and forget to remove it everytime i jack up the car.
