Old 02-01-2012, 10:54 AM   #1
DJ-of-E
DJ-of-E's Avatar
DJ-of-E is an unknown quantity at this point
Brembo vs Wilwood bbk?
Hello, I'm deciding upon a bbk to use for auto-x and weekend warrior track use to replace my RPS13 front brakes. Which is better (other than Z32 brakes in the front)?
Brembo from Z1motorsports? Brembo 240sx Front Brake Upgrade Package
Wilwood from Fastbrakes?
Brake Kits - Performance Pads, Rotors, Calipers & Brake Upgrades
Originally Posted by ocn View Post
its not "DRIFT" tax its a "IDIOT" tax Period!
DJ-of-E is offline   Reply With Quote
Old 02-01-2012, 06:49 PM   #2
DJ-of-E
DJ-of-E's Avatar
No opinions?
Old 02-01-2012, 06:51 PM   #3
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
What's wrong with z32 brakes?
Old 02-01-2012, 06:52 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
It doesnt matter...either one will be overkill for the car. If you tell me that you'll leave the rears stock, I'll die laughing.
CLICK HERE!!!
Old 02-01-2012, 06:57 PM   #5
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
Either of them are good, but if you are serious about racing, you will need to be able to adjust them.
and yeah, don't leave the back alone. If you get massive brakes like Stoptech in the front, you will lock the front, and your back end will want to kick out. Dangerous.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 02-01-2012, 07:27 PM   #6
tacotacotaco
tacotacotaco's Avatar
tacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfection
Send a message via AIM to tacotacotaco
i vote for the wilwood superlites with the def hat. Super cheap replacement rotors and save a lot of unsprung weight.
tacotacotaco is offline   Reply With Quote
Old 02-01-2012, 07:31 PM   #7
DJ-of-E
DJ-of-E's Avatar
I'm already part hunting for Z32 rears. Already got e-brake assembly with cables attached from a '93 300zx 2+2. Now I'm hunting for calipers on junk yards and then rebuild them.
Old 02-01-2012, 08:18 PM   #8
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
auto cross usually does not exceed 2nd gear speeds. i don`t think you need to upgrade to more than high performance pads and rotors with silicone brake fluid. also, a bbk will give you more unsprung weight due to larger rotors and may cause you more acceleration time. also they require 17 inch wheels. 16 or even 15 inch wheels are probably better for auto cross.
rcdad123 is offline   Reply With Quote
Old 02-02-2012, 03:43 AM   #9
fliprayzin240sx
Personally, get Z32 rears and BMC, then slap some R33 brakes up front. Then slap some Hawk pads and be done with it. Even that is more than enough to lock the wheels on a lighter S13.
CLICK HERE!!!
Old 02-02-2012, 08:25 AM   #10
e1_griego
e1_griego's Avatar
Trader Rating: (24)
This, but I'm still not seeing what the problem with front z brakes is?
Old 02-02-2012, 10:02 AM   #11
Croustibat
1/Heavy
2/Expensive
3/Old and used
i went wilwood a long time ago. for the price of a Z32 brake disc, you get a pair of wilwood discs. Same goes for the brake pads, you get 2 sets for less than 100$, and wilwood brake pads are usually twice as thick as other manufacturers. As for the weight, a pair of wilwoods weights less than ONE z32 front caliper.
My current polymatrix brake pads are half used ... and they still have more life left than my brand new ebc yellowstuff (which are crappy pads, dont use them, mine went straight to the bin after a couple of weeks)
Old 02-02-2012, 10:04 AM   #12
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Yeah, I know, I just bought wilwoods lol
But aluminum z32 brakes aren't *that* heavy, but yeah the rotor is.
And rebuild kits are cheap and easy. For autox I don't think it's 100% worth it just for the weight, unless you're planning on winning Street Mod.
Old 02-03-2012, 11:52 PM   #13
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
Glad I found this thread, I have been doing research on Brake upgrades, without going BBK, I am using low disk wheels, and cant go bbk route..
I saw the wilwood option, but still not sure if it would clear low disk leon hardritt ordens....
another thing I have been wanting to look into is the double caliper option, my friend is doing it to the rear of his Is300 and I really like the idea.
I still haven't seen it done to a 240 yet though
btw there is already a brake swap thread, this one should merge with that one:
http://zilvia.net/f/chat/431549-brak...ml#post4499515
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 02-04-2012, 12:58 PM   #14
DJ-of-E
DJ-of-E's Avatar
For the 240sx, you need to get someone who knows their stuff an fabricate a bracket. I know there's one for the rear, but never made for the front.
