Old 02-05-2012, 04:39 PM   #1
2stepGoesPowPow
2stepGoesPowPow's Avatar
2stepGoesPowPow is an unknown quantity at this point
Question Rush racing Antilag VS Bee-r Rev Limiter VS WOT Box
ok, SO.. Im looking for a system that is most beneficial for speed & can shoot flames for fun occasionally. I've tried researching all the products above but would like some opinions before i make my decision. Bee-r seems cool because it has more settings then the rush system. however the WOT box [wide open throttle box] which allows you to keep the gas peddle at WOT as you shift seems to be the best as you can hold most of your boost as you shift.. this would be my first anti lag/2step ever and its going on my redtop SR.
WOT BOX:wotbox - www2
Rush Racing Anti-Lag:Rush Racing Development - Antilag Launch Control Units
Bee-r Rev Limiter:Bee-R Rev Limiter
2stepGoesPowPow is offline   Reply With Quote
Old 02-05-2012, 10:36 PM   #2
harrypotter
harrypotter is an unknown quantity at this point
None of those are a true anti lag system, they are for show or WOT shifts. To have a rally style anti lag you would need a turbo and manifold that could take the abuse. Just copy what Dent Sport Garage has done to their SR20.
Anti lag
How Anti-Lag Systems Work - autoevolution
Dent Sport
240RS Maxi – DSG - DENT Sport Garage
http://imageshack.us/photo/my-images/842/zilviasig.jpg/
harrypotter is offline   Reply With Quote
Old 02-06-2012, 12:08 AM   #3
2stepGoesPowPow
Anti lag
Dent Sport
So your saying the rush antilag and bee-r are for show, but at least the WOT box for wide open shifts actually does something to make you faster w/ WOT shifts rite? Also what exactly are you suggesting i copy from dent... The whole build...? Lol
Old 02-06-2012, 12:27 AM   #4
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
Anti lag
Dent Sport
He never even mentioned what turbo or manifold he had? So how do you know what he has cant take the abuse.To the OP Basically all it really is cutting ignition and not fuel at what ever rpm you have it set at, are there better systems out there then what you posted Yes there are but there pricey. You need to ask yourself what am I using the car for? what are my priorities? and most importantly do I have the money to maintain the car with this kind of a system since you will be murdering your turbo. It is extreamly hard on the turbo.
s13 @ fullboost is offline   Reply With Quote
Old 02-06-2012, 12:52 AM   #5
Functiontheory
Functiontheory's Avatar
Functiontheory is an unknown quantity at this point
Oh man. Sounds like you want one for the wrong reason. Only having a redtop and assuming you have it pretty much stock, none of these are going to make your sr any faster. Just be forewarned this post is going to cause some drama. Do yourself a favor and just don't get any of these you are just going to wreck your motor.
check out my functional car blog,
http://www.FUNCTIONTHEORY.com
Functiontheory is offline   Reply With Quote
Old 02-06-2012, 12:56 AM   #6
slider2828
slider2828's Avatar
I wonder if the WOT Box really works with no lift shifting... that is kewl..
Turn and Burn!
Old 02-06-2012, 02:43 AM   #7
TheRealSy90
TheRealSy90's Avatar
I no lift shift my Sr all the fucking time with none of that crap, don't shift like a damn grandma and smack the limiter once when you shift, holds boost and all that shit. Don't waste your money on stupid crap.
Such a good signature.
Old 02-06-2012, 07:37 AM   #8
harrypotter
Originally Posted by s13 @ fullboost View Post
He never even mentioned what turbo or manifold he had?...
Some things you just know!
Old 02-06-2012, 02:07 PM   #9
!Zar!
!Zar!'s Avatar
You can set the BEE*R limiter for flat shifting as long as you wire it to the clutch instead of the hand brake.
I have a BEE*R limiter because it makes cool sounds and drifting more exciting.
That's all I care about.
Old 02-06-2012, 02:11 PM   #10
Envy
Envy's Avatar
Envy is an unknown quantity at this point
Send a message via AIM to Envy Send a message via MSN to Envy
Like other have said if you have an antilag or similar system make sure the turbo and manifold can handle it. I would worry more about the turbo myself as antilag can be very hard on the exhaust turbine if this is just for show you might want to skip over it. I don't believe the stock redtop t25's were built for that type of punishment. Also remember that these systems (if I am thinking of what you are talking about) were designed and derived from rally cars which have the budget to replace turbo's when they blow out and only have to run for hours not years.
Edit: ( I think the OP might be talking about a two-step not an antilag I am not completely sure at this point)
Envy is offline   Reply With Quote
Old 02-06-2012, 03:08 PM   #11
cotbu
cotbu's Avatar
I have the rush racing unit, and I use it to try and get an advantage over higher Hp'd and Awd cars. With boost set at 14psi I was able to leave the line with 11-12psi not an anti-lag system, launch control Hmmmmmmm OKay when you slip the clutch properly it's very effective.
Everyone keeps saying these are not true anti-lags system and that is ture, so why may I ask is it that you think the damage a real anti-lag system causes will be caused by these units. We aren't dumping continuous amount of fuel into the turbine housing or manifold. The worst case I can think of off hand is, if your base timing is wrong then yeah maybe. And I'm not saying they are safe for your engine or turbo, I'm am saying, that these don't operate like true anti-lag system so why compare the stress level to one another? The sound is more scarier, than the damage being caused.
You can wire the RR unit as a no lift shift option too, It's just that you launch would be set at the same RPM that you normal shift at. You wire the trigger to both clutch switches.
Old 02-06-2012, 05:40 PM   #12
2stepGoesPowPow
How long you been using the RR unit & what damages have you experienced?
Also I'm planning to run this setup on a 2871 375hp setup
Old 02-06-2012, 05:45 PM   #13
2stepGoesPowPow
Any damages caused by the BEE*R also why do you say it makes drifting more exciting?, cause instead of the needle slowly bouncing off redline it 2 steps? hahah
Old 02-06-2012, 05:57 PM   #14
TheRealSy90
Don't waste your money on this crap you can wot shift without it!
Old 02-06-2012, 06:03 PM   #15
Dark Spec
Dark Spec's Avatar
Dark Spec is an unknown quantity at this point
ive had the Bee*R for a hole yeah with plenty of abuse and didnt damage turbo nor manifold but my engine is built and on the stock manifold and stock but rebuilt T25 when all was put together...it works for me, does build boost of the line and makes drifting interesting...I love it but wouldn't mind trying the WOT box
Dark Spec is offline   Reply With Quote
Old 02-06-2012, 06:06 PM   #16
2stepGoesPowPow
Im scared it might blow holes in my tomei manifold
Old 02-06-2012, 06:32 PM   #17
Dark Spec
Dark Spec's Avatar
mmmm naaaaa, check it out at the start of vid....i was trying to blow my tires when they were getting ready to go after a wile of drifting so i can change to another set
CCM11 Drifting (Low Quality) - YouTube
Old 02-06-2012, 06:49 PM   #18
2stepGoesPowPow
nice hahah u shoulda went 2560 instead of rebuilding the t25 tho
Old 02-06-2012, 07:14 PM   #19
Dark Spec
Dark Spec's Avatar
well it was just to break in the motor and whatnot the car is now down for upgrades, bigger turbo, nisstune, vmount and all the goodies..
Old 02-06-2012, 07:25 PM   #20
TheRealSy90
I see what you did there haha.
Old 02-06-2012, 07:25 PM   #21
2stepGoesPowPow
i have a garrett 2560r for sale in the marketplace section, 400 + shipping
Old 02-06-2012, 07:27 PM   #22
Dark Spec
Dark Spec's Avatar
mmmm im aiming for something more like a GT30 at least im aiming for 500-550 HP
Old 02-06-2012, 07:33 PM   #23
2stepGoesPowPow
WDF lmao, i was thinking of going full race GT30 in the future if i still wanna dump money into my car but thats crazy.
Old 02-06-2012, 08:02 PM   #24
Dark Spec
Dark Spec's Avatar
crazy y???
Old 02-06-2012, 08:05 PM   #25
!Zar!
!Zar!'s Avatar
It sounds awesome and makes flames and explosions all rad like.
Thus making drifting more exciting.
Something Formula-D lacks.
Old 02-06-2012, 08:40 PM   #26
2stepGoesPowPow
crazy y???
b/c a full race setup is like 4k lol
Old 02-06-2012, 08:41 PM   #27
2stepGoesPowPow
lmao true, i wonder if theres a diff between 2 step w/ pump gas vs 2 step w/ e85
Old 02-06-2012, 09:10 PM   #28
TheRealSy90
I honestly doubt it... It's fuel.
Old 02-06-2012, 09:50 PM   #29
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
i used to drag race in the all motor class back in the day and if you did not speed shift (shifting at WOT), you are more likely going to lose the race. i was driving a Honda CRX and i would shift at 9,200 rpm and it would hit 10,200 before i was able to release the clutch completely. we did not have a WOT box or anything like that. you just slam on the clutch and release really really fast. also used to drag race a turbo acura that had a MSD DIS 2 that had 3 rev settings(burn out, launch, and redline). i would engage the 2 step for launch as soon as the 2nd staging lights come on. i would usually see 5-7 psi before launching.
rcdad123 is offline   Reply With Quote
Old 02-07-2012, 01:23 AM   #30
cotbu
cotbu's Avatar
Since September 2010
When I first got it, I played with it a lot. Mostly on back roads trying to get it right. It's set at 4500rpm now, but 5500rpm is where it makes me a supppa star!
Pissed off neighbors, Angry Vette owners confused cats, dogs and squirrels.
If you mean engine damage or turbo damage none as of lately, but i did just break my drive shaft, probably from years of abuse and not the massive 350ft I be puttin down.
my power and torque, at the time was 355hp and 310ft deep 12's on a good day! Stock internals and greddy easy cams + rocker arm stoppers
2 step, launch control, rev limiter
