Old 02-07-2012, 08:00 PM   #1
freeagent3117
freeagent3117's Avatar
freeagent3117 is an unknown quantity at this point
Push Thru Probe for efans
wheres the best place for me to put a push thru type probe in the radiator for my e-fans? It installs just like the zip ties.
freeagent3117 is offline   Reply With Quote
Old 02-08-2012, 12:42 AM   #2
freeagent3117
Ayy come on 72 views with no reply?
Old 02-08-2012, 12:49 AM   #3
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
wherever it fits and mates up with the correct holes on your e-fans. It's not rocket science.
Brain Surgeon - That Mitchell & Webb Look , Series 3 - BBC Two - YouTube
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 02-08-2012, 01:02 AM   #4
freeagent3117
Thanks for the help asshole but I'm not talking about the fans. Its a probe like you'd put up your ass that slides thru the radiator fins and senses the temp to tell the fans to come on. I would like to know where the prode should go on the radiator.
Sent from my SCH-I500 using Tapatalk
Old 02-08-2012, 01:15 AM   #5
cotbu
cotbu's Avatar
Next to the radiator inlet, s13 sr upper radiator inlet.
Old 02-08-2012, 01:24 AM   #6
snafupossum
snafupossum is an unknown quantity at this point
^this
But really it can go anywhere but that's the ideal place.
snafupossum is offline   Reply With Quote
Old 02-08-2012, 01:44 AM   #7
freeagent3117
That's what I thought at first too. But then its just cooling the water at the hottest spot instead of the water going into the engine. But idk. Thanks for help guys!!!
Old 02-08-2012, 02:19 AM   #8
cotbu
cotbu's Avatar
Water in the radiator cools the engine, the temperature probe for you fans, say turn on the fan because the engine is getting hot. Your aftermarket temp gauge lets you know what the temperature of the engine is. example 185f engine temps fans come on at 186f
The fan(s) on the radiator help extract heat from the water, when the radiator and air alone don't remove enough heat. (normal driving or at idle)
The only argument ever really made about temp probes and sensors is their location. I have my water temp probe in the upper radiator hose (s13 sr) I have the fan controller probe next to the upper radiator inlet. My temps from the stock ecu temp sensor, and my aftermarket gauge match exactly. My fans turn on at the same temperature every time. Your probably still confused at how it works!
Old 02-08-2012, 03:50 AM   #9
freeagent3117
No I get it but just wanted to make sure. Thanks for a explanation!
