Old 02-19-2012, 06:37 PM   #1
c_mancuyas8
c_mancuyas8's Avatar
c_mancuyas8 is an unknown quantity at this point
Not starting after rebuild
Rebuilt my head this weekend and my car is not starting. Replace spark plugs, distributer, rotor. Im getting spark at the coil and I know Im getting fuel because its all over the plugs. Initially I thought the distributor was in backwards but when switched around still nothing. The engine will turn over but not start. Any help would be greatly appreciated. Thanks- Chris
Edit: Before pulling the head i had 170 across all four cylinders. Now I have 0? Any ideas?
c_mancuyas8 is offline   Reply With Quote
Old 02-20-2012, 09:48 AM   #2
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
If the cam timing is right then I'd say you messed up somewhere with your valves. Is it 0 on all four? Your valves might not be seating properly.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 02-20-2012, 04:27 PM   #3
c_mancuyas8
Yes it is zero on all four. Im guessing Im going to need to pull the head back off
UPDATE!!!!
This issue is getting more and more confusing. The cams and cam gears seem to be spot on with timing.
Today I set crank at tdc by the timing marks on idler pulley and distributor rotor. Upon taking the valve cover off and looking at the cam gears everything seems to be exactly where they should be heres pics.
At tdc this is what cam gears look like. I marked the dimples with white out as well as the chain when i pull them thats why its white.
Heres the cam orientation at tdc from exhaust side
I have no clue what to do next :/
Old 02-20-2012, 07:11 PM   #4
cbcm2435
cbcm2435's Avatar
cbcm2435 is an unknown quantity at this point
were the white marks on the gears and chain lined up when you took them off?
cbcm2435 is offline   Reply With Quote
Old 02-20-2012, 07:21 PM   #5
c_mancuyas8
Yes I marked the chain and the cam gear when I pulled it off to keep time.
Old 02-20-2012, 07:31 PM   #6
cbcm2435
cbcm2435's Avatar
did you have cyl 1 a tdc when you re installed everything. if cylinder one is at tdc all your cam timing marks should be lined up
Old 02-20-2012, 07:48 PM   #7
c_mancuyas8
Yeah it was at tdc set it by timing mark on idler pulley and verified at dist rotor before pulling it out. Ive done this several times before which is why i'm so stumped.
Old 02-20-2012, 08:15 PM   #8
cbcm2435
cbcm2435's Avatar
you could always do a leak down test and see where the air is leaking out at, it sounds like you are going to have to pull your head back off though
Old 02-20-2012, 08:23 PM   #9
c_mancuyas8
I hate to say it but Im sure Im going to also :/
Old 02-21-2012, 12:04 AM   #10
Dark Spec
Dark Spec's Avatar
Dark Spec is an unknown quantity at this point
ive had this problem before and yeah it has to do with timing not being set right and i too think you are going to have to pull the head again, i did....
Dark Spec is offline   Reply With Quote
Old 02-21-2012, 12:12 AM   #11
c_mancuyas8
Theres one major thing that i have no idea how I looked over but I didnt set valve lash :/ (Member on ka-t.org suggested that) Thats the first thing Im goin to do tomorow and Ill report back with what Ive found.
Old 02-21-2012, 12:16 AM   #12
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
wow I'm having the same issue I'm doing a compression and leak down test tomorrow, if all goes bad I'm throwing this ka away just gonna go sr again
Old 02-21-2012, 12:24 AM   #13
c_mancuyas8
NOOOOOOOO! Dont do it what all have you done?
Old 02-22-2012, 01:07 AM   #14
Pro ViZIon
Pro ViZIon's Avatar
It's definitely valves. The timing wouldn't affect the compression that much. If it was that bad you'd be taking out the valves.
Old 02-22-2012, 09:30 PM   #15
CleanAndLegit
Trader Rating: (55)
compression was about 70-90 across all 4 might be valves took it to a shop they better fix it
Old 02-22-2012, 09:52 PM   #16
c_mancuyas8
I hope they do!
I think I figured out my problem :/ Never again will I work on my engine for more than 12hrs at a time. Being rediculously tired is no way to work on a car.
Lol so I put my valve spring retainers in upside down. I didnt even know they would fit like that, but bc they did they stuck up past the valve stem and created a clearance issue keeping all my valves apartially opened. Ill be the first to say.. Im an idiot!
Old 02-23-2012, 01:05 PM   #17
Pro ViZIon
Pro ViZIon's Avatar
Lol. I knew it was something like that.
Old 02-24-2012, 11:18 AM   #18
project-c2
project-c2 is an unknown quantity at this point
IDK if it makes a difference, but my green/blue painted cam is on my exhaust. That's the way mine was when I disassembled it.
project-c2 is offline   Reply With Quote
Old 02-25-2012, 10:30 AM   #19
Pro ViZIon
Pro ViZIon's Avatar
If it's an S13 motor then it does matter, the cams are 240/248. If S14 probably not, the cams are 232/232.
Old 02-26-2012, 07:16 PM   #20
TJM240
TJM240 is an unknown quantity at this point
Good job getting it right.
TJM240 is offline   Reply With Quote
