Old 02-21-2012, 08:00 PM   #1
Keefs240sx
Keefs240sx is an unknown quantity at this point
Sr20det stock is hesitate when you give throttle
Car hesitate when you give it throttle tried 2 different ecu's an mafs what else could it be ?
Keefs240sx is offline   Reply With Quote
Old 02-21-2012, 08:19 PM   #2
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Does your stock rubber intake tube have a spring in it? If not it can collapse under boost.
take your spark plug gap down to .028 and check your coil packs as well
what fuel pump are you running?
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 02-21-2012, 08:21 PM   #3
Swifty
Swifty's Avatar
Trader Rating: (29)
Swifty is an unknown quantity at this point
Feedback Score: 29 reviews
Possible weak fuel pump.
Swifty is offline   Reply With Quote
Old 02-21-2012, 08:28 PM   #4
Keefs240sx
Stock fuel pump an will get plugs in the morn. Any other things to check for .
Forgot turbo is after market external gate
Haven't moved it out the driveway yet trying see why it's super hesitate my street is a busy one trying not get stuck in road lol
Old 02-21-2012, 10:16 PM   #5
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Has it always been like this? But I would definitely get a walbro in that tank. They're inexpensive.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 02-22-2012, 06:22 AM   #6
Keefs240sx
I jus got the motor swapped over into my s14 chassis
Old 02-22-2012, 12:37 PM   #7
ma.jomaa
ma.jomaa's Avatar
ma.jomaa is an unknown quantity at this point
Sounds like not enough spark is coming through, I had that happening to my SR and it was loose ground cable, check your power cables and change ur plugs hopefully that will take care of it, oh and check if any of the intercooler pipes came off that could be it too
ma.jomaa is offline   Reply With Quote
Old 02-22-2012, 04:44 PM   #8
Croustibat
If it accelerates if you gently give throttle, but not when you hit it hard, it usually is a weak fuel pump. If it does it all the time, usually a boost leak. And if it does not go above 2500 rpm, it is a MAF related problem (limp mode) => check your MAF wiring .
Old 02-22-2012, 05:32 PM   #9
Keefs240sx
It's when you try to rev it's hesitate an it's a wire specialties harness too. Maf wiring what do I need to look for?
Old 02-22-2012, 06:26 PM   #10
Jake1992
Jake1992's Avatar
Jake1992 is an unknown quantity at this point
does it even pass certain rpms ? i had a bad 02 sensor then it started sputtering at 2000 to 2500 and wouldnt go forward , got stuck in traffic also....
switched to my power fc ecu , and turned off 02 control.... and it works good , exepct my fuel economy has gone reall bad
Jake1992 is offline   Reply With Quote
Old 02-22-2012, 06:41 PM   #11
Keefs240sx
New plugs an checked grounds, It won't even go to 1500-2500 an wants to die after it tries to idle back down after a rev really frustrated with it first sr20 I've ever messed with need all the help I can get?
Also I have a skinny o2 sensor is there one I can interchange with. .? If this ones bad?
Old 02-23-2012, 06:23 AM   #12
Jake1992
Jake1992's Avatar
i was misfiring up badly .... i have a pretty thick one on my turbo elbow...
Old 02-23-2012, 08:05 AM   #13
Keefs240sx
What are you talkin bout?
Anyone any idea need to get my car driving taking days off work to speed up progress so need it fixed
Old 02-23-2012, 08:56 AM   #14
Jake1992
Jake1992's Avatar
The o2 sensor... that led my car not reving and misfiring..
Old 02-23-2012, 09:22 AM   #15
Edwin562
Edwin562's Avatar
if engine starts, what is the RPMS at idle?
Old 02-23-2012, 09:40 AM   #16
Keefs240sx
I would say right below 1k so 800-900 it idles an cranks fine jus not able to rev
Old 02-23-2012, 09:52 AM   #17
Croustibat
still going for weak fuel pump and / or boost leak somewhere, and a big one. You sure of all your plumbings ?
try revving the car from engine bay, very gently on the throttle . if it revs, it surely is the fuel pump. If it does not, boost leak. And it could really be both. MAF systems cant work properly with a boost leak.
Old 02-23-2012, 04:11 PM   #18
Keefs240sx
I have been revving from throttle in the bay it wil rev but very hesitate an sluggish t bolts on all piping but I'll double check the leaks an get a fuel pump
Old 02-24-2012, 12:47 PM   #19
StryfeS13
It's Always Broken.
StryfeS13's Avatar
So your turbo setup is not stock, and you have a motor that needs a lot more fuel than your KA ever did, and you have a stock fuel pump? You need to either buy/borrow a walbro from a friend and see if it solves your problem.
Do you have a boost gauge? You can tell if you have a leak if you have a boost gauge..
Test for boost leaks by using smoke or a DIY tester with a pvc end cap and air compressor (you can find it on the forums)
Gotta love Zilvia.
Old 02-24-2012, 04:20 PM   #20
Keefs240sx
Ok yes done a leak test an I think my bov is shot an stuck open . Fuel pump on order
Old 02-24-2012, 04:28 PM   #21
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Is it an ebay BOV?
Recirculate it
Gotta love Zilvia.
Old 03-12-2012, 03:48 PM   #22
Keefs240sx
Got rid of throttle hesitation now when I rev it back fires an goes to about 2000-2500 rpms what can cause this ? Limp mode on ecu? If how you fix it?
Old 03-28-2013, 09:07 PM   #23
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i am having hesitation problems as well. i will use all the answers here.
but to op. i dont know if you ever get to fix but can you rev the car pass 3k? if not could be a maf problem.
Old 03-28-2013, 10:16 PM   #24
Chaluska
have you tried a 3rd MAF? the SR maf's seem to be junk, it might possible that you got 2 bad ones
Old 03-28-2013, 10:17 PM   #25
Chaluska
if its only hesitating when u give it any throttle, id check your TPS voltage. and tps voltage at the ecu
