Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 02-22-2012, 08:52 AM   #1141
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
i had to remove my sway bar for who knows what reason,....but figured id try it without it.....and with both daily driving and a couple track days,...cant tell ya I noticed a difference really.....lol
i threw it back on, and still didnt notice much. So either im not that intune with my car,. or my set up isnt 'advanced' enough for it to matter yet
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 02-22-2012, 12:39 PM   #1142
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
Originally Posted by Brian View Post
what the heck is double clutch
Double clutching is when say you're making a 3/2 downshift, 1)brake 2)clutch in 3)neutral 4)clutch out 5)heel&toe throttle blip 6)clutch in 7)2nd gear 8)clutch out. Basically its rev matching the input shaft of the transmission as well as the motor by performing the heel and toe when the car is in neutral with the clutch in. Completely pointless in a modern tranny w/synchros.
pacotaco345 is offline   Reply With Quote
Old 02-22-2012, 12:46 PM   #1143
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
^^^^that what i have done but i got problem with understeer and turbo laggy..
PIN GIO 2 is offline   Reply With Quote
Old 02-22-2012, 06:25 PM   #1144
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
That was my thought but apparently couple here have made it sound like some sort of technique. It just prolongs the car from being in gear putting power down.
iamtheyi is offline   Reply With Quote
Old 02-22-2012, 07:50 PM   #1145
chiboy002
its not in what you can feel, its what you can do
it was sarcasm d00d
street dancer.
GLEAM
Old 02-22-2012, 11:15 PM   #1146
pacotaco345
Originally Posted by chiboy002 View Post
it was sarcasm d00d
I'll leave now...
Old 02-22-2012, 11:42 PM   #1147
chiboy002
hey
dont sweat it, pal
street dancer.
GLEAM
Old 02-23-2012, 08:31 AM   #1148
conrad_s13.5
what should i be able to do without a swaybar?
more bite up front??
cONtRol FReAkS
Old 02-23-2012, 09:09 AM   #1149
chiboy002
as hamburg said, the front will be able to grip more without a sway bar. grip drivers do the opposite of what we do, they may take off the rear so that it grips more there
what this means is if you enter all nasty-like, where you would normally have lower traction, the absence of a sway bar will allow the front tires to hug the road more independently
street dancer.
GLEAM
Old 02-23-2012, 01:05 PM   #1150
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Just keep the stock front swaybar. Chances are the end link bushings are so old that it does not do anything suspension-wise, but it makes for a great oil pan protector.
Old 02-24-2012, 07:09 AM   #1151
Chad@CTI
Chad@CTI is an unknown quantity at this point
If you're really looking to get the most out of a setup, soft spring rates with an adjustable sway bar front and rear are where it's at.
Especially if you have a good bit of steering angle and power, You can fine tune the car with the sway bars.
Adjust your sidebite, how much angle you can pull at a certain speed, all sorts of things, I'd highly recommend investing in a set of adjustable sway bars.
Obviously it's all a mix between dampening, tire, tire pressure, spring rates, and sway bars, but the cars going the fastest with the most angle retain sway bar, invest in the adjustability, and have pretty soft spring rates.
And Conrad, if you can't feel a difference, it's probably a mix between your coilovers, your bushings, and that stock sway. I wouldn't worry about your driving, or not feeling the car, you've been driving long enough to notice a difference. If you don't immediately feel it, something is up.
With a front sway you are going to get less body roll, which means less understeer, and when tuned right, means a good amount of front grip. There are lots of other factors too!
Chad@CTI is offline   Reply With Quote
Old 02-24-2012, 08:32 AM   #1152
chiboy002
what if you adjust the sway bar one side differently than the other?
will that mean you get understeer one direction and oversteer the other?
street dancer.
GLEAM
Old 02-24-2012, 08:37 AM   #1153
conrad_s13.5
^ awesome thorough info!
im trying to fine tune my set up,. but going to the extreme in either direction seems to be the only way i feel the differences, and then just work off that.
cONtRol FReAkS
Old 02-24-2012, 02:42 PM   #1154
Chad@CTI
If you adjust the sway bar on one side and not the other, it doesn't affect one side differently than the other, all you're doing is changing the overall stiffness in the sway bar.
Old 02-26-2012, 08:51 PM   #1155
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Has anyone ran the Hankook Ventus V12 tires out back? I am still on the look out for a replacement for the Ventus HRIIs I ran last year. They lasted so long and were so consistent, I'd like to get something similar, I'm pissed they don't make them anymore.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 03-05-2012, 03:54 PM   #1156
epik1
epik1 is an unknown quantity at this point
I've searched google as well as sparsely throughout this thread, so /flamesuit on.
My setup:
S14
-KA24DE mystery mileage, but hasn't given me any issues burns a little oil , no noises. AEM intake..lol
-OEM Exedy clutch with decent life left
-mystery diff, I've yet to try a burn out and I keep on getting told different things from people who've driven my car
-Z32 brakes all around (EBC GD rotors + Hawk HP+ pads) w/working e-brake. SS lines.
-doing solid diff and subframe bushings this season
-OEM 16" wheels, good condition Firestone Firehawks up front, some beat up almost dead tires in the rear
-some 11 yr old Tein coils, rears are blown or seized, rear is mad bouncy.
my question: will I be able to learn to drift on the track?
I understand there will be countless spin outs, and I can play with tire pressures.
which leads to another question, portable tire pumps??
I've tried a few that I got for free and they shat on me lol.
/FRRRAMESUITONN
Thanks
edit: and I stripped out the rear interior and trunk...well the trunk came stripped so yeah lol.
epik1 is offline   Reply With Quote
Old 03-05-2012, 10:46 PM   #1157
LockOn!
LockOn!'s Avatar
LockOn! is making a name for him/her selfLockOn! is making a name for him/her selfLockOn! is making a name for him/her self
Diff, check. clutch, check. ebrake, check.
Yes. Drive the piss out of it like you don't care what happens. You'll learn.
The best thing for me when I was learning was doing ride-alongs with more experienced drivers, then trying to copy them.
You dont need to play with air pressures. Just set the front to factory and air the rear up to A BILLION (like 55). Release air for more grip as you get better.
And yes, portable tire pumps are boss. The only reason I dont have one is because my friend does lol.
LockOn! is offline   Reply With Quote
Old 03-05-2012, 10:53 PM   #1158
epik1
:O A straight answer to what I consider a frequently asked question on Zilvia!?
I tip my hat to you sir, for your courtesy and your tips lol!
Old 03-05-2012, 11:21 PM   #1159
chiboy002
advan ad08 on a stock ka
overkill or not? i'll prolly go ahead and buy it regardless but just want some input
is having too grippy of front tires a bad thing? i would assume not unless im doing some crazy 4-wheel drifting but im not
street dancer.
GLEAM
Old 03-06-2012, 02:32 AM   #1160
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
Ive 2 pairs of 225/45/17 Heat Cycled but still very meaty AO48's on the Front and its my most favorite setup to date. Had 235 N3000's out back. Clutch kicks weren't mandatory. Just a quick jerk of the wheel and I would he sideways. I'm sure the 7/6 springs play a big part in that.
I'm also going for a pair of 205/50 AD08's soon. Hoping to get the feel of that grip I had without paying the price for them.
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 03-06-2012, 03:10 AM   #1161
chiboy002
cool
i'll do that then, thanks!
street dancer.
GLEAM
Old 03-07-2012, 05:38 PM   #1162
fckillerbee
fckillerbee's Avatar
grippy front tires on a ka is a blessing. Probably my favorite setup.
Old 03-08-2012, 12:03 AM   #1163
chiboy002
fate has been sealed
street dancer.
GLEAM
Old 03-08-2012, 11:10 AM   #1164
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
I remember the first time I put tar Specs on the front of my car.
WHOA. it was so weird.
I think that I slipped the front tires a lot because of my entry style, so when I got the brand new Star Specs, they were NOT interested in slipping at all.
http://bhworld.wordpress.com/
Old 03-08-2012, 04:37 PM   #1165
fckillerbee
yeah I went from Federal 595 RS to 595 SS, then to Star specs, and then tried Nankang NS 2. its amazing how different they were. I enjoy the cheaper front tires for normal drifting. the 4wheel slide is pretty fun, but no bueno for tandem...need that front grip to have a fine line ;D
Old 03-08-2012, 05:04 PM   #1166
KA240SX808
KA240SX808's Avatar
What did you think of the RS's?
Old 03-08-2012, 05:09 PM   #1167
fckillerbee
I really liked them. I probably prefer those over the Star Specs for drifting. the Star specs had to be heated up a little before getting good front grip. Reminded me of the Hankook RS-2's.
I'm actually buying my first Azenis 615k's here shortly. Pretty excited to run them on the front. Heard great things from the Falken bros.
Old 03-08-2012, 10:11 PM   #1168
KA240SX808
KA240SX808's Avatar
Yeah that's what I read. The Auto-X guys like the RS's cause there sticky from the get go. Hows the Treadlife?
I would go with the Z1's or 615's but I wanted specifically a 205/50/17 so that only left me with the AD08's being affordable.
Old 03-09-2012, 04:50 PM   #1169
fckillerbee
I don't know, I tend to wear through tires because I daily drove the car with -5 degrees of camber. lol. Last a year worth of daily/track use.
Old 03-10-2012, 02:10 PM   #1170
ka-titties
ka-titties is an unknown quantity at this point
RS3's are excellent. I drove my buddy's wrx at an autox on 255 rs3's all around and the thing had grip for days.
ka-titties is offline   Reply With Quote
