Old 12-10-2011, 02:15 PM   #1
Chad Dugan
Chad Dugan's Avatar
Chad Dugan is an unknown quantity at this point
Chad Dugan S14 drift car build (kouki/racecar)
Hello!
I started this build 2.5 years ago, didn't exactly know where it would go, had not decided on what chassis I was going to use, but I had my first motor built at Canadian Cylinder Head (Graham) in Toronto. I had 3 S14's before deciding that I would use my 97 chassis to turn into a full racecar.
Built S14 SR, good for around 500hp -
Engine specs -
S14 SR (eliminated VVT) (Originally from Varun VHC Performance 5-6 years ago)
S13 intake cam gear
BC 264 cams
BC SS intake and exhaust valves
BC valve springs and retainers
HKS rocker arm stoppers
CCH ported head
Apexi 1.1mm HG
Oversized Wiesco pistons
Crower rods
ARP rod, mains, clutch, and head studs
ATI crank pulley
New oil pump (modified)
New water pump (VHC Performance)
Greddy oil pan
ACL race bearings
New timing chain with metal guide
Bings polished pulley set
New accessory belts
New alternator
Fuel -
-8 steel braided feed and return lines
Nismo 740cc Injectors
Bosch 044 pump
2x Aeromotive filters
Tomei FPR
15 Gal fuel cell with sending unit
EMS and Electronics -
Vipec V44 universal ECU
Racepak IQ3 with Vipec integration cable
Splitfire DIS 4 coilpacks
Yellow top battery
Painless chassis & custom engine harness
Custom fuse box and switch panel
AEM wideband 02
Drive train -
Exedy Hyper single clutch
Custom 1 piece drive shaft
SR20 transmission (VHC Performance)
Solid transmission mount and motor mounts
B&M short shifter
Welded diff
Solid subframe bushings
Chassis and Suspension -
Bride seats
Sparco Rails
Vertex style headlights
Vented carbon hood
GP sports aero
30mm wide front fenders
30MM rear over fenders
Aerocatch hood pins
Lexan rear windows
New glass front windshield
MA Motorsports AWESOMETRON 5000 super angle knuckles
MA Motorsports modified LCA's
SPL outter tie rods
TEIN inner tie rods
SPL RUCAS Nismo rear LCA
New ball joints front and rear
TEIN HA 16 way coilovers
Cusco TC rods
Custom power brace
TEIN camber plates
Brakes -
Z32 front brakes
Braided lines front and rear
Brembo rotors front and rear
4x Z32 rear calipers
Dual rear caliper brackets
CNC hydro E brake
CNC prop valve
Wheels -
Enkei RPF1 18x10.5+15 rear 18x9.5+15 fronts
I'm sure there is much much more I am missing, but here are some pics - enjoy!
I started the tear down at home in the garage with minimal space and gathering tools as I went along -
Spot weld removal of the front end, and test fit some areo -
Got the car over to a friends house for some heavy fabrication work -
Started on the front end before getting into the cage or rear tube -
We decided to go with a fully removable front end for easy access at the track for any work needed - and for simple replacement in case of a crash -
Installed some areocatch pins since we had no more rad support -
Trimming the front fenders
Test fitment of corner lights
Lower rad support removable tabs
Started on fitting the lights and bumper
Light bar finished ready to be fully welded up
Started gathering material for the rest of the car
We got the main hoop finished, and decided to gusset it to the chassis -
We later decided the main hoop could be higher for head room clearance -
So we boxed it up and got it exactly where we wanted -
Removed the side gussets and now they weren't needed
Started working on front window gussets
Clean tig welds in between each gusset for added stiffness
Break time....
Looking clean and good head room now -
After cutting and fitting each and every bar we could with the material we had, we labeled everything to be finalized and welded the next day
Fitment is everything
Lots of bars added, and started on a rear firewall
Fast forward and we have got the rear end semi finished and making sure everything fits properly
Got the car back home for some more body work and paint
Got the car over to my buddies barn and started to strip the chassis down for paint
Test fitting over fenders for the last time before finalizing them
Put the clutch and transmission on with the one piece shaft and got the engine in quick.
Driver side complete
Fast forward again, gave the engine bay a quick cover and clear before mounting the engine -
Getting there
I will give updates as I progress over this winter!
Thanks, Chad Dugan
Chad Dugan is offline   Reply With Quote
Old 12-10-2011, 02:42 PM   #2
lilrussian
lilrussian is an unknown quantity at this point
O______o
Nice.
This is very interesting.
I don't think I've seen so many tubes in one post haha
Subscribed and gonna follow this!
Don't forget to update
lilrussian is offline   Reply With Quote
Old 12-10-2011, 03:33 PM   #3
tricky_ab
tricky_ab's Avatar
Aw Yeah! Man, there's some nice builds going down in the GTA. I love it!
I'll be watching this one for sure!!!
Old 12-10-2011, 03:37 PM   #4
Edwin562
Edwin562's Avatar
Nice progress.... loving it.... keep up the good work
Old 12-10-2011, 03:58 PM   #5
Purestock240
Purestock240 is an unknown quantity at this point
seen this on SON, looks good so far
Purestock240 is offline   Reply With Quote
Old 12-10-2011, 04:11 PM   #6
qwerth
qwerth's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
keep up the awesome work man!
Old 12-10-2011, 04:43 PM   #7
ezza
ezza's Avatar
ezza is an unknown quantity at this point
nice work! cant wait to see it done
ezza is offline   Reply With Quote
Old 12-10-2011, 04:49 PM   #8
frizzle
In time-out for misbehaving.
Trader Rating: (45)
frizzle is on the path to ruinfrizzle is on the path to ruinfrizzle is on the path to ruin
Feedback Score: 45 reviews
Looking good! I wish my motor was built : (
frizzle is offline   Reply With Quote
Old 12-10-2011, 05:54 PM   #9
RoXiE.S14
RoXiE.S14's Avatar
RoXiE.S14 is an unknown quantity at this point
Very interesting! I'll be following, keep those updates coming!
RoXiE.S14 is offline   Reply With Quote
Old 12-10-2011, 07:46 PM   #10
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
Looking awesome! you dont see many people chopping and tubing the rear of the car.
Marcus is offline   Reply With Quote
Old 12-10-2011, 08:50 PM   #11
JDM SPUG
JDM SPUG is an unknown quantity at this point
Looking good
JDM SPUG is offline   Reply With Quote
Old 12-10-2011, 09:34 PM   #12
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
Intense build. In for this
Sumslapper is offline   Reply With Quote
Old 12-11-2011, 07:47 AM   #13
Royal_T
Royal_T's Avatar
Royal_T is an unknown quantity at this point
Man there are some sick builds going on lately... I am glad to see that people are taking these types of steeps in building a car...
Love the work bro, keep it coming
http://zilvia.net/advertise.html
Royal_T is offline   Reply With Quote
Old 12-11-2011, 08:20 AM   #14
tricky_ab
tricky_ab's Avatar
Thanks God for reals...
Old 12-11-2011, 09:25 AM   #15
roland
roland's Avatar
roland is an unknown quantity at this point
Good build keep it up
roland is offline   Reply With Quote
Old 12-11-2011, 01:14 PM   #16
Chad Dugan
Chad Dugan's Avatar
Thank you so much for the great feedback!! I thought this was a cool shot of stitch welding the front strut towers -
I bought a converted harness off a friend over a year ago which was modified a few times for some changes which were hard to sort out, but with the help of a few wiring gurus we did the get the engine turned over!
This was one section of spaghetti that had to be cleaned up. Now that everything is sorted out, and the engine does run, it's time to clean up and Raychem the rest of the harness.
Old 12-11-2011, 03:15 PM   #17
STR8E180
STR8E180 is an unknown quantity at this point
any more updates?
STR8E180 is offline   Reply With Quote
Old 12-29-2011, 12:23 AM   #18
IrishCarBombCHI
IrishCarBombCHI is an unknown quantity at this point
your front end is what I dream about having done to mine. subscribed please keep updating
IrishCarBombCHI is offline   Reply With Quote
Old 12-29-2011, 06:01 AM   #19
bb4_96
bb4_96 is an unknown quantity at this point
[QUOTE=Chad Dugan;4401267]
[QUOTE]
someone hacked the fuck out of your fuse box man. good luck!
bb4_96 is offline   Reply With Quote
Old 12-29-2011, 06:16 AM   #20
Chad Dugan
Chad Dugan's Avatar
that's the engine harness dude, no fuse box action yet!
I should have some more pics later next week! Thanks for looking.
Old 12-29-2011, 07:36 AM   #21
bb4_96
then what's that black box with all the splices? I'm confused.
Old 12-30-2011, 06:06 AM   #22
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
Great work man... Your planning on grip or drift?
Originally Posted by shiftdrift View Post
you running on hopes and dreams?
HPKMotorsports3 is offline   Reply With Quote
Old 12-30-2011, 10:45 AM   #23
Tubasteve1
Tubasteve1 is an unknown quantity at this point
Wow a serious build for sure!!
Tubasteve1 is offline   Reply With Quote
Old 12-30-2011, 09:47 PM   #24
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
good job feller
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 02-24-2012, 10:18 PM   #25
Chad Dugan
Chad Dugan's Avatar
Paint process
Having trouble loading my video to here via photobucket, if anyone can help me I can have it on tonight
Old 02-24-2012, 10:29 PM   #26
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
awesomeness i like how your doing your own cage, super mice weldds
bova17 is offline   Reply With Quote
Old 02-24-2012, 10:34 PM   #27
Om1kron
Om1kron's Avatar
I like this thread
Wayne Edwards
https://om1kron.blogspot.com
Old 02-24-2012, 11:04 PM   #28
STL240SXDRIFT
STL240SXDRIFT's Avatar
STL240SXDRIFT is an unknown quantity at this point
Yes...body work done correctly! Nice!
STL240SXDRIFT is offline   Reply With Quote
Old 02-25-2012, 06:43 AM   #29
tricky_ab
tricky_ab's Avatar
This is looking really good! What colour have you selected?
Old 02-25-2012, 09:25 AM   #30
Royal_T
Royal_T's Avatar
Can't wait to see some color on this thing
