Old 02-23-2012, 06:00 PM   #1
240zach
240zach's Avatar
240zach is an unknown quantity at this point
s14 s14 lights and engine sputter problem, no idea what it is
s14, s13sr20det, basic mods; fmic, 3 inch exhaust, coilovers, electric fans, boost gauge. just a btw.
so i went to go drive the car when all the sudden out of the blue the tach started to freak out, along with everylight in the car (gauge cluster boost gauge, radio) and my headlights and taillights all flickered and with the flickering my engine sputters as well. but only when im driving it...when the car is still and idling it is perfect..
i have no idean what can control all of these things..
i have checked my battery terminals and that was fine, and my wire harness isnt rubbed through at all.. so if someone can help? has this happened to anyone before?
ive read that it could be an alternator that idk how it could be that cause when the cars not in motion it is completely fine. i also checked my fuse box and all my relays checked out good as well.
anyone have any ideas?
240zach is offline   Reply With Quote
Old 02-24-2012, 12:55 PM   #2
240zach
240zach's Avatar
Anyone have an idea?
Old 02-25-2012, 08:44 PM   #3
Taylor008
Taylor008 is an unknown quantity at this point
Unplug your speed sensor and see if you can drive it.
Taylor008 is offline   Reply With Quote
Old 02-26-2012, 06:10 PM   #4
240zach
240zach's Avatar
my speed sensor wasent plugged in in the first place. lol
Old 02-26-2012, 06:11 PM   #5
240zach
240zach's Avatar
but speed sensor only controls the mph guage not the rpm gauge
Old 02-26-2012, 06:51 PM   #6
Tarrbaby
Tarrbaby is an unknown quantity at this point
sounds like an earth problem. I would check all the main earths in the engine bay and then once you have checked/fixed them, if its still doing it will need to pull up some of your carpet and or interior panels and check the body earths to.
Tarrbaby is offline   Reply With Quote
Old 02-26-2012, 08:44 PM   #7
240zach
240zach's Avatar
idk if its that though, i never changed any grounds or modified any grounds, i read that it happens if an alt starts to go bad, so im going to replace my alternator and see if it is fixed..hopefully it is..lol
Old 02-26-2012, 08:50 PM   #8
EnemyS15
EnemyS15 is an unknown quantity at this point
It seems like a loose ground to me. Check em before spending the loot on new parts. My 2c
EnemyS15 is offline   Reply With Quote
Old 02-27-2012, 01:35 AM   #9
240zach
240zach's Avatar
Can one ground be effecting all my lights, tach, and engine sputter?
Old 02-27-2012, 02:05 AM   #10
240Chance
240Chance's Avatar
240Chance is an unknown quantity at this point
check you alternator make sure its charging. might tweek out from on and off charging.
240Chance is offline   Reply With Quote
Old 02-27-2012, 09:44 AM   #11
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
Im having some of the same symptoms in mine too. Gonna try replacing the ECU and see if that works. Also some zilvian told me to check some of the wiring behind the cluster and around the steering column.
Kaifd3s is offline   Reply With Quote
Old 02-27-2012, 10:55 AM   #12
240zach
240zach's Avatar
Around the steering column? I feel like chance is on the right track, and nice job copying my name. Haha, jk I love u chance. And I need too I'm taking it to a shop soon and check it, then get it repaired to 105 amps
Old 02-27-2012, 11:01 AM   #13
240zach
240zach's Avatar
But let me know after u change ur ecu if its still there. I thought it had something to do with the wire harness cabin plug thing that u have to plug in and tighten it down with that lever, I thought it was loose which could have caused it but it wasent. Lol
Old 02-27-2012, 02:10 PM   #14
Taylor008
This one time after a swap, I didn't tighten down the bolt on the alternator. I would drive it and it would Buck from serious power loss, then run fine. Check for corrosion on the alternator connection thing that's like an O and you put it over the bolt and tighten down the nut. Dont know how else to describe this... lol.
Old 03-05-2012, 11:20 PM   #15
240zach
240zach's Avatar
you mean where i tighten the ground?
flickering lights, s14, sr20det
