Old 02-29-2012, 01:04 AM   #1
Mamba240
Mamba240 is an unknown quantity at this point
Question about Steering Wheel.
Hows it going fam. I just had a quick question about my steering wheel. I have a 96 240sx and whenever I go on the highway my steering wheel will tend to vibrate to an extent whenever it hits a small bump. Likewise after a while of driving when I turn the steering wheel left or right it will make a howling noise.
My question is it my tie rod on the steering wheel itself? I recently had a wheel alignment on the car. I dont know what else it could be. Any help would be appreciated, Im new here as well so please no hate. Thanks in advance.
Mamba240 is offline   Reply With Quote
Old 02-29-2012, 01:26 AM   #2
lude4life13
lude4life13 is an unknown quantity at this point
Try finding out if a wheel bearing is bad.
lude4life13 is offline   Reply With Quote
Old 02-29-2012, 10:19 AM   #3
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
the howling noise is coming from the power steering pump. the vibration could be a few things. inspect rack and pinion mounting bushings and inner and outer tie rods.
rcdad123 is offline   Reply With Quote
Old 02-29-2012, 04:19 PM   #4
Mamba240
Thanks for the opinion guys. @rcdad123 - Yeahh I suspected that it would be the power steering pump. I thought I had a leak from the power steering, but I checked it out and still have sufficient amount of power steering fluid left.
Old 02-29-2012, 04:22 PM   #5
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
check ball joints, wheel bearing as mentioned and also rack mounts make sure there tight check all front suspension make sure nothing is bent also the front subframe could have shifted causing your alignment so go out of wack there all possibility's
s13 @ fullboost is offline   Reply With Quote
Old 02-29-2012, 04:26 PM   #6
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
Jack the car up so its safe, then manhandle your wheels and see if they are 'shifty' or have any clunking noises. You should also visually inspect the front subframe to the wheels for any wear.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 02-29-2012, 04:38 PM   #7
Mamba240
Thanks again. I actually got into a fender bender on the passenger side thats why. So these possibilities might be it. It just weird that the howling noises only come when Im about to park my car or pull in for a small turn.
