PowerFC Turbo/Injector Downgrade Question
S14 SR which is currently tuned with a PowerFC D-Jetro (map sensor)for this setup:
GT2871R .86AR 850cc Injectors Megan SS manifold I'm switching to the following setup: S15 Turbo 525cc Injectors (STI) Stock Manifold Obviously I will need a tune for this to run well after all the changes. My question is: do you think I can get the car running well enough to drive it(out of boost) to a tuner 100 miles away? If so, what values in the PowerFC can I adjust to correct the injector difference since that is my main concern. 7/6/12 Update: To anyone who ends up searching for this and is curious of the result, the injector scaling worked perfectly and the car runs fine. Simply all I did was scale the injectors based on the new size. New size is 525cc, stock is 370cc. Divide 370 by 525 and you get ~71%. That is the value I used on the PowerFC and the car is running great. Heading to the tuner this weekend for fine tuning.
S13 Coupe SR20DET Last edited by hstylez; 07-06-2012 at 07:40 AM.. |
![]() Join Date: Aug 2011
You can, but this requires a wideband lambda sensor. You could just try multiplying injection time by 2, it will be safe. They may have similar latency, but if it bogs down on idle try changing the latency to a lower value.
I dont know how you do that on a powerFc though. |
#3 | |
S13 Coupe SR20DET |
May I ask why you are downgrading? also you can try finding an s15 power fc stock settings to match it up. Im runnning a d jetro also on an s14sr with stock almost everything lol.
#5 | |
Your timing and fueling maps depend on engine load, running a smaller turbo will just prevent from using the "highest" part of the maps, so timing wont be a problem. You could pull 2° if you feel the need to be safer. |
#6 | ||
S13 Coupe SR20DET |
You can adjust the injector duty percentage on the Power FC commander or using Datalogit. It's under the settings. Just monitor the AFR if you can as mentioned and you should be fine off boost.
#8 | |
![]() Join Date: Mar 2006
You don't need Dataogit to do this, you can very easily do this from the commander under Settings\Injector
Daily driven |
#12 | |
#13 | |
I have my AFR's setup to be in the 15.5-16.0 range under vacuum (enough vacuum to cruise at 75-80 in 5th gear without accelerating) then tapering down to 13.5 or 14.0 at 0 boost.........works really well, I get awesome gas mileage and never any knock. Don't have an EGT gauge but can't imagine that this is a problem at all
Daily driven |
#14 | |
![]() Join Date: Jul 2005
#15 |
the factory ecu also runs 10.1 or richer on 13 psi and holds that afr from the second it makes boost. everyone knows factory ecus are very safe and designed to be reliable for 99% of the factory engines at the cost of peak power.
#16 |
Yeah, whats wrong with that? How much power do we lose for that safety? I am not saying dump 10:1 at 13psi- but a little safety net during spool is not a bad thing.
#17 |
I agree with the safety net thing, but I don't thing 13.5 is an issue at 0 bosot. I've never once gotten ANY knock.....then again, maybe my timing at that level of manifold pressure is very conservative....?
Daily driven |
#18 | |
I was just pointing out a margin of safety- something that we like to keep as large as possible, right?- that is nearly free to own (nearly: you DO pay for the extra fuel). Not many margins of safety are free, for instance forged pistons are added to an engine to increase safety margin sometimes at the cost of performance). But they are far from "free". |
#19 | |
now, in a completely unrelated side story, my AFRs for boost >14 psi are literally in the low 10s. now THAT has gotta be costing me something, right? Still haven't gotten around to bringing them more into the 11.5 range
Daily driven |
#20 |
Is the fact that I'm going from a tubular SS manifold to stock a cause for concern? If I was running a MAF I wouldn't be concerned at all however I'm running the Power FC with the MAP setup..
S13 Coupe SR20DET |
