Old 03-06-2012, 02:12 PM   #1
s15willy
s15willy is an unknown quantity at this point
sr20det 500whp fuel setup
currently have a bosch 044inline , which am going to run into a surge tank , which would be the best tank to run in tank , my current fuel pump in-tank crapped on me , should i just run stock fuel pump in-tank? Or run another walbro 255 in-tank? would a stock reliable fuel pump compared to a walbro in-tank effect my power goals?
s15willy is offline   Reply With Quote
Old 03-07-2012, 10:02 AM   #2
slider2828
slider2828's Avatar
If you truly going running a 500whp and road racing...
you want a low power lift pump to two bosch 044....
Read this
http://zilvia.net/f/tech-talk/417715...ight-easy.html
Turn and Burn!
Old 03-07-2012, 10:22 AM   #3
jr_ss
Walbro to a surge tank, 044 as main feed... 700hp capability.
Old 03-07-2012, 10:52 AM   #4
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
+1 more than enough to support power goals
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 03-07-2012, 11:25 AM   #5
slider2828
slider2828's Avatar
In tank walbro's for road racing definitely burn out even if you keep half a tank in there.... we need to talk about reliability here as well as in high powered vehicles are going to be affected more by these problems.
Low power lift pumps like ac delco's or what not work better and don't burn out as often.
Turn and Burn!
